Bolt stuck trying to remove front brake
Mirey
PostPosted: 10:26 - 04 Oct 2014    Post subject: Bolt stuck trying to remove front brake Reply with quote
I'm trying to replace the front tyre on my YBR but I can't get the front brake off.
No matter how hard I try, it just won't budge. It looks like the bolt is starting to deform as well...
any ideas?
https://s10.postimg.org/iw58ojkft/bolt.jpg
RhynoCZ
PostPosted: 10:34 - 04 Oct 2014    Post subject: Reply with quote
WD40, hammer it a bit, then when using the wrench don't just turn it, give it the initial impact to break the tension. Also push on the bolt when using the wrench to prevent it from ruining the head. Thumbs Up
PostPosted: 10:37 - 04 Oct 2014    Post subject: Reply with quote
Freeze and release?
Also use a proper hex socket, not one of the star type ones, it'll have far less chance of buggering the head.
It wouldn't surprise me if some nobber's used loads of locking compound on it to be fair.
c_dug
PostPosted: 10:42 - 04 Oct 2014    Post subject: Reply with quote
A six sided socket should see that off without too much hassle and you can probably pick up an individual socket from any local tool place, or maybe halfords, for a couple of quid.
If I was really worried about it rounding I would combine the six sided socket with my Impact Driver There isn't much that that combination wont see undone. Certainly it should see a calliper bolt undone.
Don't even half consider putting it back in, buy yourself a replacement for about a fiver.
Ed Case
PostPosted: 11:50 - 04 Oct 2014    Post subject: Reply with quote
The bolt is screwing into an alloy fork leg so be careful using a hammer, it's surprisingly easy to clout chunks off. A good tight-fitting socket is probably the best answer. Best of luck.
jeddy11
PostPosted: 12:23 - 04 Oct 2014    Post subject: Reply with quote
Get a set of these Thumbs Up
https://i185.photobucket.com/albums/x232/jeddy11/td_394002_bg_expset_zpsd3aaa1f8.jpg
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
kramdra
PostPosted: 14:53 - 04 Oct 2014    Post subject: Reply with quote
Bolt looks fucked, sockets not going to grip that. A chisel will - use hammer and chisel to tap it round. Waterpump pliers are also very good with rounded bolts.
Thread is on the calliper mounting bracket. You could always grind the head off, and waterpump pliers on the protruding 15mm thread.
Replace brake bolts with 12.9 grade BZP socket head bolts - they will not round off. Use blue threadlock - it does not add much to the undoing torque and also prevents corrosion.
Taught2BCauti...
PostPosted: 15:51 - 04 Oct 2014    Post subject: Reply with quote
Those Irwin Bolt Grips are awesome - I have lost most of mine now - but don't count on using the bolt again after using them!
Bolts with a large flange like that are always trouble - especially if someone has used too much Loctite on the threads, and some has got between the flange and the body.
I would try tapping the head of the bolt gently - left to right, up and down - to break the bond.
Try attaching some mole grips to the bolt head whilst heating the threaded part up with a hairdryer (a bit gay, but it works) then remove the mole grips and use the Irwins.
The mole grips act as a heat-sink, to stop the bolt getting too hot and expanding as well.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
lihp
PostPosted: 15:54 - 04 Oct 2014    Post subject: Reply with quote
Lol kramdra.
You moan about a Honda main dealers choice of parts and then you go on to give ridiculous and meaninglessly destructive advice.
kramdra
PostPosted: 16:01 - 04 Oct 2014    Post subject: Reply with quote
One assumes that OP is using the correct size. metric, 6 sided socket to begin with. One also assumes he is also trying to turn it the correct way Laughing
PhilDawson8270 wrote:
Lol kramdra.
That bolt is fucked, there is no reusing of that bolt, it doesnt matter if it is obliterated. I advised a good upgrade bolt, and an easy way to get it off.
As for main dealers Evil or Very Mad they serviced my rear brake 2 years ago. I knew the piston was rusting, so stripping it down to be serviced. The calliper slider bush is one solid lump of rust.. what did they lube it with, jizz? Mad
c_dug
PostPosted: 16:02 - 04 Oct 2014    Post subject: Reply with quote
A six sided socket will grip it fine. Destructive methods are a last last resort. Don't touch a hacksaw, pipegrip or powertool of any sort until you've properly exhausted all other options.
Mirey
PostPosted: 16:12 - 04 Oct 2014    Post subject: Reply with quote
I am using a six sided socket. Maybe not enough leverage. You can tell from where it's starting to wear that I'm turning it to the left.
I'll try those Irwin things.
I've tried WD40, it did sweet feck all.
Taught2BCauti...
PostPosted: 16:16 - 04 Oct 2014    Post subject: Reply with quote
Use the Irwins if everything else fails, but WD40 (or proper penetrating oil) won't work if there's Loctite on the threads.
c_dug
PostPosted: 16:30 - 04 Oct 2014    Post subject: Reply with quote
Interesting, since I bought my six sided set I've not had a rounded one yet that I couldn't get off.
Islander
PostPosted: 16:44 - 04 Oct 2014    Post subject: Reply with quote
Apply heat to the bolt first. If there's threadlock on it, that'll break the seal. The six sided socket should undo it - if you've got an impact driver then use that with the socket.
There really shouldn't be any need for destructive tactics at this stage.
kramdra
PostPosted: 17:15 - 04 Oct 2014    Post subject: Reply with quote
Irwins are destructive, and as previously noted, the bolt has already been destructed. A chisel and hammer to tap it round is equally effective, less destructive and cheaper.
www.ebay.co.uk/sch/i.html?_nkw=m8+35+bzp+12.9&_sacat=0
35-40mm is the correct length for my bike, measure the old to be sure Thumbs Up
c_dug... of the 9 bikes in your sig how may deadeded? Laughing
thomp1983
PostPosted: 18:11 - 04 Oct 2014    Post subject: Reply with quote
where are you maybe someone local can help?
J4mes
PostPosted: 19:22 - 04 Oct 2014    Post subject: Reply with quote
I normally try to tighten it first in order to break the seal, that way if it is bollocks tight and the tool slips you don't further damage the head on the edges you need to stay intact to undo it.
Shocking it can also help, so perhaps try a short ratchet handle and smack it with a mallet
Raffles
PostPosted: 19:37 - 04 Oct 2014    Post subject: Reply with quote
That's great advice....For shagging-up a ratchet.
J4mes
PostPosted: 19:48 - 04 Oct 2014    Post subject: Reply with quote
If you Need a vehicle back on the road then a damaged £10 tool is the least of your worries.
And I've never killed any of mine doing it.
CBRMAN94
PostPosted: 21:07 - 04 Oct 2014    Post subject: Reply with quote
Am i the only one who is wondering why you need to take the front brake off for a tyre change? Spindle out, Wheel out, Tyre change and stick it back in Thumbs Up
Honda CBR-RW6 (Sold) - Kawasaki GPZ500s (Sold) - Honda CG125 (Project) - Honda CB750 Cafe racer (Project) - Yamaha FZR400RR
drbaig
PostPosted: 22:03 - 04 Oct 2014    Post subject: Reply with quote
A lot of these issues happen because there is not enough leverage and a lot of force.
If I have trouble getting any bolts of these days I just go grab the breaker bar or a pipe to put over the ratchet. Every bolt comes off with ease. If only I had done this with the countless bolts I've rounded previously.
yzf 600r Very Happy
Suntan Sid
PostPosted: 23:09 - 04 Oct 2014    Post subject: Reply with quote
As DrBaig says get a decent breaker bar and 6 sided socket!
Bagged myself a second hand 2.5ft breaker bar, at the market, years ago, it laughs at bolts like that!
If you still have trouble with the breaker bar get a friend to wallop the bar/socket while you've got pressure on the bolt, should shock it enough to get it moving.
The last post was made 12 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.37 - MySQL Queries: 15 - Page Size: 128.46 Kb
