Swinging arm & welding (advice needed)
pepperami
PostPosted: 18:18 - 04 Oct 2014    Post subject: Swinging arm & welding (advice needed) Reply with quote
So I`m putting newer/better bits on my Superdream.
I have another swinging arm that looks? tidier and generally in better order than the swinging arm that is on the bike.
As I am going to replace the swinging arm bearings anyway I intend to use this newer? swinging arm at the same time.
HOWEVER! the newer swinging arm has a hole in it from corrosion about the length of my finger on the underside.
I have a MIG gas-less welder and was thinking of welding up the hole.
I believe it is do-able.
It`s a superdream and not a R1 so I don`t think that power/stress is going to be an issue.
I await your wisdom oh mighty and wise BCF
Fisty
PostPosted: 18:20 - 04 Oct 2014    Post subject: Reply with quote
Smiler rode one with a plated swing arm. Worked fine.
Fatter and faster than Fret
iooi
PostPosted: 18:50 - 04 Oct 2014    Post subject: Reply with quote
While you are at it. Drill a hole, tap it and add a grease nipple so you can keep the bearings well greased Thumbs Up
pepperami
PostPosted: 18:55 - 04 Oct 2014    Post subject: Reply with quote
Smile Already done Thumbs Up
The last post was made 11 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 40.46 Kb
