2001 Honda CG125-w Front Wheel Clicking Noise
timothygstoke...
PostPosted: 20:33 - 04 Oct 2014    Post subject: 2001 Honda CG125-w Front Wheel Clicking Noise Reply with quote
Hi all,
I came off of my bike today (3rd time in 3 months riding). Stupid roundabouts Evil or Very Mad . Anyway, on to the problem in hand... I repaired the motorbike at my granddads house (Just up the hill from me) and I rolled it home without the engine running. As I was rolling down the hill, I noticed a clicking noise coming from the front wheel.
Any ideas on what this noise is linked to?
Cheers,
Timothy
Riding a Honda CG125
cresad
PostPosted: 20:43 - 04 Oct 2014    Post subject: Reply with quote
Hi , I would guess the most obvious are anything in the wheel Embarassed Have you damaged the mudguard at all , have you check the wheel itself is running true. The other things to check depending on which side you fell are the brake disc and caliper , or the speedo unit.
Adam
RhynoCZ
PostPosted: 20:59 - 04 Oct 2014    Post subject: Reply with quote
Is the wheel moving freely? Is the steering firm in the neck?
I heard some clicking on my ZXR, found out the pads were moving in the left calliper. The plate that was supposed to hold them did not do its work. Thumbs Down
timothygstoke...
PostPosted: 21:15 - 04 Oct 2014    Post subject: Reply with quote
Adam
Hi,
My bike doesn't have a disc or calliper Embarassed The mudguard seems to be fine, and I believe the wheel is still running true. I have yet to check the speedo drive unit though.
Cheers,
Timothy
timothygstoke...
PostPosted: 21:16 - 04 Oct 2014    Post subject: Reply with quote
The steering is firm in the neck. The bike doesn't have a calliper.
Cheers,
Timothy
RhynoCZ
PostPosted: 21:25 - 04 Oct 2014    Post subject: Reply with quote
Alright, take the front wheel off then, and check the inside of the drum brake. Thumbs Up
timothygstoke...
PostPosted: 21:31 - 04 Oct 2014    Post subject: Reply with quote
Ok then, looks like im gonna have a fun day tomorrow then lol. And my brother thinks it could be the final drive chain that's clicking.
Cheers,
Timothy
RhynoCZ
PostPosted: 21:44 - 04 Oct 2014    Post subject: Reply with quote
Cheers,
Timothy
It sure could be, but you've said it was the front end, not the engine. Smile
When did you hear the clicking? Riding it or at neutral on the drive way?
timothygstoke...
PostPosted: 23:37 - 04 Oct 2014    Post subject: Reply with quote
When did you hear the clicking? Riding it or at neutral on the drive way?[/quote]
I heard it rolling down an incline on it in neutral under no power( Engine not running)
Timothy
blurredman
PostPosted: 08:32 - 05 Oct 2014    Post subject: Reply with quote
It could be the chain indeed.
However, the front drum setup of CG's, have a fair bit of free play in the toque locking mechanism slot etc. That could be banging about.
RhynoCZ
PostPosted: 11:56 - 05 Oct 2014    Post subject: Reply with quote
Mate once had a small piece of rock in the headlight cover of his CB500, after going down. It was clicking/ticking in there like it was the chain. We were both surprised a small piece of rock could get in there, yet nothing around the head light was damaged, some scratches on the side but the glass and the headlight cover were perfectly fine.
mudcow007
PostPosted: 09:27 - 06 Oct 2014    Post subject: Reply with quote
probably stupid this but......
i had issues with the speedo drive (in the front wheel) on my CG, the noise maybe coming from that?
piazza
PostPosted: 10:11 - 06 Oct 2014    Post subject: Reply with quote
Loose spoke.
Fisty: The uncle that touched you up as a child and told you not to tell anyone. That's BCF that is.
timothygstoke...
PostPosted: 13:08 - 06 Oct 2014    Post subject: Reply with quote
Hi all,
Thank you all for the suggestions. I have lubricated the chain, and I will be inspecting the other possible areas in due course. Regarding the headlight, it popped out and there is no gravel or stones in there.
Cheers,
Timothy
Dave M
PostPosted: 19:11 - 07 Oct 2014    Post subject: Reply with quote
Hi all,
Cheers,
Timothy
Take spindle out and roll it along a flat surface like coffee table etc. Could be this?
timothygstoke...
PostPosted: 20:06 - 07 Oct 2014    Post subject: Reply with quote
Hi all,
Cheers,
Timothy
Hi,
I will have a closer look at the front wheel tomorrow, as I will be changing the back tyre tomorrow as well.
Cheers,
Timothy
The last post was made 12 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 93.75 Kb
