gn125 tyre
dylandunphy20...
PostPosted: 19:18 - 04 Oct 2014    Post subject: gn125 tyre Reply with quote
had a little off on my gn125 it was a low side going round a roundabout.
i dont like the thin tyres on these is there ticker options im not 100% sure on putting different tyres or wheels on it.
also after the lowside i feel like the back is always trying to slip out to the left dont know if its in my head or not.. i miss my 650 cos of the big tyres but i just needed something small so i got the gn
Dylan Dunphy
Taught2BCauti...
PostPosted: 08:32 - 05 Oct 2014    Post subject: Reply with quote
I think it would be wise to stick to the manufacturer's recommendation for tyre sizes, but choose one that is suitable for the weather conditions - some are better in the dry, some are better in the wet, some are good all-round - and this is based on tread pattern and the compound used in the rubber, not necessarily the size.
I had a similar issue with the front tyre on my 125, but through trial and error found it ran much better with 2psi less than the recommended pressure.
This could be down to my pressure gauge being 2psi out, but 2psi less than it was reading before, made the bike feel much more stable.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
SQL
PostPosted: 11:29 - 05 Oct 2014    Post subject: Reply with quote
Probably the type of tyres you are using thin tyres aren't that bad at gripping
https://www.youtube.com/watch?v=7OOpE7fBw28
Robby
Dirty Old Man
PostPosted: 11:48 - 05 Oct 2014    Post subject: Reply with quote
Going for wider tyres will give you worse handling. You may get a bigger contact patch, but you only need this if the rear is spinning up on acceleration, or the front is breaking traction under braking.
More likely that you just have shit or worn out tyres. You should find a lot of confidence in new tyres from a decent manufacturer, regardless of width.
If you can get a set of Michelin M45s for your bike, I recommend them for small bikes. Good deep tread pattern so they work well in the wet or on poor road surfaces, sticky enough that they never scared me, and really cheap. I think I paid under £100 for a pair of them on a CB250RS.
If you have tubed tyres, they're easy enough to fit at home with some 9" tyre levers. Worth splashing out for new inner tubes too.
dylandunphy20...
PostPosted: 13:54 - 06 Oct 2014    Post subject: Reply with quote
the tyres are quite new they just dont feel very grippy the back always feels like its wants to slip from under me.. maybe its just in my mind haha the tyres are CST 3.50-16 58p for my gn125 2006 i cant seem to find better ones to fit
Dylan Dunphy
dylandunphy20...
PostPosted: 13:58 - 06 Oct 2014    Post subject: Reply with quote
also its tubless this tyre
Dylan Dunphy
Taught2BCauti...
PostPosted: 14:05 - 06 Oct 2014    Post subject: Reply with quote
Try it with a little less air, and again with a little more until it feels right.
I pumped up the tyres on my car at the local Tesco on Sunday morning - their gauge showed 32psi. When I got home and checked with my digital gauge, they were reading 45psi.
Only 1/2 mile, but the steering felt very light until I let them down to 32psi. Just saying.
dylandunphy20...
PostPosted: 14:43 - 06 Oct 2014    Post subject: Reply with quote
thanks everyone Smile does anyone happen to know the recommended tyre pressure for the gn125 2006 model? i dont have a manual with this so i dont know
Dylan Dunphy
Taught2BCauti...
PostPosted: 15:01 - 06 Oct 2014    Post subject: Reply with quote
Single Rider = 25psi (1.75bar) Front, 29psi (2.0bar) Rear
Rider + Pillion = 25psi (1.75bar) Front, 32psi (2.25bar) Rear
The last post was made 12 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 59.85 Kb
