Suggest me a better supermoto
Bike Chat Forums Index -> Offroad & Supermoto Goto page 1, 2  Next
PostPosted: 22:55 - 05 Oct 2014    Post subject: Reply with quote
300 EXC and change for a super ped. Razz
Crz
PostPosted: 23:27 - 05 Oct 2014    Post subject: Reply with quote
Ktm smc 690?
Never owned one but judging from what I've read about them, they seem to fit your list.
Only bad thing is the price though Sad
Theory: 8/7/13 Mod 1: 26/7/13 Mod 2: 21/8/13
"Life is like a garden, plant your seed in every hole you see"
stevo as b4
PostPosted: 00:44 - 06 Oct 2014    Post subject: Reply with quote
Iain, TBH mate I think any fairly reliable road usable big single is going to struggle to really better the Duke, which is a way better road bike than many focused 4stroke motards like a YZF450F or similar. Something competition like a KTM 640 or Husaberg or Husqvarna is likely to be less roadable, less reliable and more of a pain in the arse.
Your KTM being over 50bhp should be happy with 85mph cruising, my old KMX200 was happy at 75mph, so I don't see why not.
But if your after 100mph sustained instead of a quick top speed run, and a ceiling of 120mph, I think you really need a twin cyl bike of 60-70bhp at least. Maybe even something like an SV650 with a jacked up back end, a set of supermoto forks and wheels on it as a cheap lash up that would do the job?
A CB500 twin engine in the KTM Duke chassis would provide the performance you need, or look to a bigger SM V-twin like a tatty KTM 990 or something not quite supermoto like an Aprilia dosoduro 750 or similar. Either way I think you need a 2,3, or4cyl bike? Any single pot 4stroke is not a 100mph+ sustainable bike and a 2smoke even less likely to be.
I could be talking bollocks, but even the latest KTM 690's I doubt are that great for 100mph or thereabouts, and a twin like the Husqvarna Nuda or KTM990 would be way better bikes, as would a converted or bastardised road bike. I'm sure if someone wanted to they could take something like a Honda Hornet 600and make it more supermoto wannabe with the right suspension, and asthetic mods?
PostPosted: 01:19 - 06 Oct 2014    Post subject: Reply with quote
_Iain_ wrote:
Lacks the 4-5k torque
Lacks as in 'makes loadsl?
Makes a much nicer engine sound, especially when pinned over uneven terrain.
Can stick any headlight on any bike with the right brackets (I almost had E36 BMW lights on my 690!)
Brakes will be pretty much the same (don't think yours are radial),
Speed wobble probably worse.
Anyway, it doesn't sound like you want a supermoto.
I'd suggest a naked SV650 with wide bars.
I do think Paddy needs to get a decent ride on one if he hasn't, however - 200 is much more fun Smile.
I never suffered high speed wobbles on the 690, nor on the Husaberg, which was a competition bike (in both cases with SM and enduro wheels), similarly the Duke 690 was fine. Suspect the speed wobble is a set issue.
Does it come with a FCR carb?
Still sounds like the naked SV650 will suit your needs better.
And of course, even with a faired one you can still do well in 'supermoto' if you've got the talent/balls Wink.
https://dangerismymiddlename.com/public_html/wp/wp-content/uploads/2009-Supermoto-SV650-permission-from-4theriders.com-092.jpg
PostPosted: 09:58 - 06 Oct 2014    Post subject: Reply with quote
_Iain_ wrote:
Brakes on mine are four pot Brembo's, not radially mounted though & apparently the steering wobble is pretty common on it.
And you can likely have the exact same brake on the EXC once you've got SM wheels on it.
To be clear; i don't think the EXC is a good choice. A 300 is excellent at pampering you off road, I wouldn't choose one for road fun.
Firestorm has even more boredom and even more weight.
SV offers a claimed weight at 15kg over the Duke. You can always bump the seat height and bars on the SV up a bit. Shiver another 15kg on the SV and a good few £.
Seeing that we're well beyond supermotos whatever; the question is which bits from the supermoto do you actually want?
Even upgeared, while my 690 would cruise at speed, it's far from ideal.
The taller the bike, the more hassle speed is going to be, of course.
Copycat73
PostPosted: 10:09 - 06 Oct 2014    Post subject: Reply with quote
I think supermotard wise to get the performance your after is gonna take a V twin and probably a 800cc -1000cc ;or more; motor.
As well as bein Derived from a road machine; which would likely have better brakes and high speed stability ;rather than off road.. Thinking
caveat emptor
PostPosted: 10:27 - 06 Oct 2014    Post subject: Reply with quote
Actually, a tedium might be worth considering.
Not sure about prices on the versys/v strom 650s.
Conzar
PostPosted: 12:08 - 06 Oct 2014    Post subject: Reply with quote
What about a MK1 Bandit 1200 if you are looking at naked sv650's?
Oooooozes of Torque and Power wheelies!
Or what about a Tuono?
For what you are wanting in a supermoto its going to be a lot of money.
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
PostPosted: 12:26 - 06 Oct 2014    Post subject: Reply with quote
It depends the exact stability you want (we may be thinking different things), but it really shouldn't be a problem to get it dialed in one way or another. I didn't find the Duke 3 a problem at 107 (gearing limited).
As for grunt, a new 690 Duke R (the ones that are actually 690cc, the original were 654cc) might help, but on my 690 (which is a 654), it still isn't ideal - I suspect if you had the 'R', you'd be wanting more still.
In the end, you've got terrible aerodynamics and an engine that's far from ideal for sustained high speed.
It's not tarty enough for you I suspect and would require a bit of work, but something like this seems to meet your requirements.
https://img.photobucket.com/albums/v377/BlueLghtning/Other%20Bikes/SV650%20dual%20sported/17Cimg0957.jpg
Or you could just get a V-Strom, though it'd be heavier.
With the above, replace the subframe for an aluminum based one and a couple of lightening bits and you're probably at Duke weight levels.
PostPosted: 12:47 - 06 Oct 2014    Post subject: Reply with quote
_Iain_ wrote:
State of that Laughing
Yea, terrible to have a bike that looks the owner made it for riding Wink.
Oh and from reports I've seen, if you had the cash, the big twin KTM Duke would probably be worth a look.
PostPosted: 15:40 - 06 Oct 2014    Post subject: Reply with quote
Just stick with the Duke and don't ride above 100mph. I rarely ride over 100mph on my Street Triple anyway.
1cyl
PostPosted: 17:51 - 06 Oct 2014    Post subject: Reply with quote
Good thread folks. Epic pics, loving that 4 cylinder dirt muncher Thumbs Up
The business of turbocharging a big single has been something that I've also on occasion dwelled upon. Originally, I felt that fitting a turbo to any bike that wasn't a Busa or the like, was a bit pointless. But, since falling in love with SM's, and the characteristics of big singles, its definitely something that I'd consider for the SMC, given the cash and a few more years. Just for the grins.
Of course, I'd need a turbo expert mega genius, to help me get it looking and running like it might have popped out of a factory. And that's megabucks I don't have, or could buy 2stroke with.
On topic, Its a shame you cant stretch your budget to make an offer on a dosodurodo, or similar, which I estimate (as you've realised) to meet your exact criteria:
https://www.ebay.co.uk/itm/APRIL-DORSODURO-2008-750cc-V-TWIN-SUPERMOTO-/161442547110?pt=UK_Motorcycles&hash=item2596b9c5a6
As has been said, the 690's are great, a little improvement where you want it, but not alot. + What I consider to be "pure and wholesome SM" (900mm+ seat height and less than 150kg) is never going to be good at a 100mph+.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
stevo as b4
PostPosted: 18:13 - 06 Oct 2014    Post subject: Reply with quote
I hate to say it, but I agree with G and the bastardised SV650 or Hornet or similar?
Blandit is a heavy old bike, take away it's strong as a safe motor and it's go nothing going for it. Less style than a ZRX12 or XJR1300, and naff suspension and build quality.
Firestorm is a 190kg bike, and with renthals etc I don't think there's a lot to lose weight wise, It's going to still be a 175-180kg at best unless you fit it out with mega expensive Ti and alloy bits. It could be a poor man's Tuono though, but by the time your done spending and uprating the barely good enough brakes and suspension, you could have brought an Aprilia most likely.
I like your Duke, it's a cracking looking single, fairly light and it's in another dimension performance wise compared to say an XT660X or similar. You've got a good thing going with that bike, and if you have to slow down 10-15mph like Marjay says it's still worth the trade IMO.
A turbo on the KTM could and I'm sure would work to an extent, but I rarely see anything turbo as a good/useable daily transport vehicle, and with the KTM being a well tuned high compression single of 50-55bhp is there much head room for a turbo without grenading the motor?
I've messed with small bike's, scooter's and warm hatch car's before and lost a lot of money in the search for a bit more power and speed. I've said for a long time now after taking other's advice that tuning is only worth doing when your ride is already more than fast enough for what you want.
I know I'm going to mess with my KMX, but if and when I get a V-max I don't need 145bhp, but further tuning it can never disappoint me if I don't use all it's motor anyway.
Fladdem
PostPosted: 21:07 - 06 Oct 2014    Post subject: Reply with quote
I know what you mean, although my TTR is a far-from-super-moto, I wouldn't mind a touch more grunt so it could hold 70 comfortably, top speed is probably about 90? given enough room. Maybe not though.
I'm quite a big fan of the V-Strom. Embarassed Or getting an Africa Twin and doing this to it:
https://rossifumi46.fr/wp-content/uploads/2011/04/nuevas_fotos_moto_024.sized_.jpg
I also consider a TTR 600 and bodging some sort of fairing to it, but you could grab an XT660Z Tenere for the price of a TTR plus home-made fairing and mods, it would be easier to get the Tenere and sort out the suspension.
Really I need to get more space to store bikes. I would like a 600-650 size supermoto or even a rally raid style, a 250/300 two stroke enduro bike, a TY250, a TZR250 3XV, a CBX1000 and my H100 powered MT5, that would be quite a good garage to have.
PostPosted: 01:59 - 07 Oct 2014    Post subject: Reply with quote
Never saw particular issues with SV frames snapping in minitwins.
When you're doing wheelies for long enough to starve the front cylinder, consider worrying about it Wink.
The clutch actuator is irksome for losing bearing. Radiator might not be ideal for dumping it down on dirt, but then a tart-moto won't be either and will likely cost a lot more to 'fix up'.
Likely an SV would come with wheels, if it doesn't. SV wheels don't cost £600! Picture was just an example; I wouldn't be buying silly spoked wheels for road use. You could stick an entire KTM suspension and yolks on and it not cost £600 even with fabrication.
I was more thinking, say - £500 SV650. £250 front suspension mods + ok, don't use the SV brakes, lets go for a single R6 caliper for around £50.
Also comes with a headlight.
Again, the SV weighs 15kg more than the duke going from listed weights and you can likely reduce that difference a bit too. Africa twins are listed as an extra 40kg on that, yet make similar power to my 690, which is listed at 2/3rds of the weight of the Honda.
I entirely agree on not doing a 'project' when you can buy an off the shelf solution for similar or less.
I don't think you'll be able to find any such 'off the shelf' bike that weighs the same an an SV650 for the sort of price you could do it for.
What multi cylinder engine would 'simply' go in your KTM frame?
And while big single turbos are used for snow a bit, I can't see them offering the ride or longevity you're after, never mind, I bet a hell of a lot more complexity, hassle and possibilities to go horribly wrong.
I wouldn't take someone (who claims their bike is better than a sports bike under braking Confused) with a 136hp Duke as evidence it will handle sustained use on the road, even with a lot less boost.
Anyway; still waiting for clarification on which bits of 'supermoto' you consider important?
PostPosted: 11:04 - 07 Oct 2014    Post subject: Reply with quote
It's not just the 75hp, but that you're using it for sustained high speed - something I've found they often don't like - two big end bearings gone on singles used like that.
Despite your initial assertion, I had presumed the 'supermoto' thing was a moot point - if you wanted all the benefits of one, you wouldn't have gone for the Duke when lighter bikes are available with the same engine.
But yes; riding slower seems the most sensible option Smile.
weasley
PostPosted: 14:24 - 07 Oct 2014    Post subject: Reply with quote
_Iain_ wrote:
I want something that rides exactly like my bike, but with a little more high speed stability (without sacrificing any of that low speed agility) and a little more grunt.
KTM 990 SM(R)?
1cyl
PostPosted: 19:07 - 07 Oct 2014    Post subject: Reply with quote
Wait a cotton pickin' minute! Its a fake! Is it? Isn't it? The gixer dirt bike. The seat looks photoshop weird.
I'll be "crosser" if it is!
see what I did^ Sick Very Happy
The last post was made 11 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 154.79 Kb
