Starting Problem
cresad
PostPosted: 19:21 - 03 Oct 2014    Post subject: Starting Problem Reply with quote
Our son went out on his bike tonight for the first time ( it's been off the road for a couple of years ) , a hongyan 125 , anyway to start with the bike ran fine - until it ran out of petrol ( he forgot to turn it on ). It restarted ok , but he stalled it when a car in front of him stopped sudenly , this is when the problem/s started.
When he tried to restart it the starter just kept going turning the engine over but not starting the bike , removing his finger from the button and it still kept going , he then turned the kill switch off - nothing happened starter still going , then the ignition - again nothing but sill going. Anyway the starter kept turning the bike over until the battery ran out of charge.
He pushed the bike back to our house , about 10 -15 mins away , where I found I could bump start the bike and would run fine but with no ignition , neutral or brake lights working. Once we got it back home properly went to take bettery out and found it was red hot to the point of being too hot carry , even now an hour and a half later it's still warm.
So a couple of questions - any idea's as to what would cause it to keep turning over even with switched off and keys out ? ( thinking possably starter button or solenoid ) and do you think the battery will be ok after this ? , it's only a couple of months old at the most.
Sorry for the length just thought I'd explain as well as poss.
Thanks , Adam
Taught2BCauti...
PostPosted: 15:45 - 06 Oct 2014    Post subject: Reply with quote
I think you have more than 1 fault here - If the starter motor won't stop spinning, either the solenoid is stuck, the start button is jammed, or there's a fault in the wiring between the two.
Ignition and lights not working could be a different wiring fault or a blown fuse.
Check the battery casing on all 6 sides before you charge it, to make sure they are all smooth and flat - i.e. no cracks or bulges.
Don't re-connect the battery until you have sorted the starter problem - you will get a large spark when you try to re-connect the - lead that could cause the newly charged battery to explode.
When disconnecting the battery, always remove the - lead first and re-connect it last.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
cresad
PostPosted: 20:34 - 06 Oct 2014    Post subject: Reply with quote
Thanks for your reply , but we've A/ sorted it and B/ got an impatient son.
Seems the solenoid was stuck bypassing the switches which had drained the battery that quick that , combined with the heat it had produced , was what was stopping the lights etc.
As soon as it lost power the solenoid released itself - problem solved. Battery was ok once recharged and had no damage. New solenoid on it's way and it's been fine since , the heat hadn't damaged the battery but again new battery sat in the cupboard for when needed.
The amount of new parts on this thing is getting stupid.
Thanks again , Adam
The last post was made 12 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 1.07 - MySQL Queries: 15 - Page Size: 37.76 Kb
