'26 Sunbeam Model 6 'Longstroke'
Davetom500
PostPosted: 08:09 - 07 Oct 2014    Post subject: '26 Sunbeam Model 6 'Longstroke' Reply with quote
Just rebuilt the engine and box, bought it last summer and it hasn't been on the road since 1952. This Model was the last sidevalve to win the TT ('22), it'll do 65-70 but it's happiest at 45-50
Aff
PostPosted: 08:12 - 07 Oct 2014    Post subject: Reply with quote
Looks awesome. Any more pictures/info from the build?
Electric Bike Project
Davetom500
PostPosted: 09:12 - 07 Oct 2014    Post subject: Reply with quote
The crank was rebuilt by Alpha, the mainshafts are riveted into the flywheels and they had moved over time causing ovality. New mainshafts were turned and hardened, then riveted back in. The big end had also moved in the flywheels so an oversized big end was made, the crank was jig bored true, and the big end fitted. I found an old VW piston that was an 80 thou oversize so that was adapted and fitted. The carb is an AMAC ( pre Amal) TT, which us basically a needleless racing carb from the 20's. Vintage carb expert Martyn Bratby converted it so it uses needles and jets from Amal Concentrics, making tuning a lot easier
Davetom500
PostPosted: 09:20 - 07 Oct 2014    Post subject: Reply with quote
AMAC TT 25
PostPosted: 10:11 - 07 Oct 2014    Post subject: Reply with quote
Subframe's bent......oh wait!
Joking aside, that's a little beauty. It'd be great to hear that it was back on the road after half a century of lay-up.
Did you do anything to prevent similar wear again in the crank assembly?
PostPosted: 11:41 - 07 Oct 2014    Post subject: Reply with quote
Cool as penguin piss. Thumbs Up
Davetom500
PostPosted: 12:16 - 07 Oct 2014    Post subject: Reply with quote
Max at Alpha reckons the crank will outlive me ( I'm 45).! Hopefully with modern materials and being a one off build compared to production line tolerances, it should stay together. It won't get as much abuse as it probably got for the first 20 yrs of its life, though I do like to use it as it's maker intended..😄
PostPosted: 12:33 - 07 Oct 2014    Post subject: Reply with quote
That's just lovely Thumbs Up
RhynoCZ
PostPosted: 12:36 - 07 Oct 2014    Post subject: Reply with quote
Beautiful piece of machinery. Smile
Might be a stupid one but, how fast does it actually go?
Davetom500
PostPosted: 13:00 - 07 Oct 2014    Post subject: Reply with quote
I've clocked 60 on my phone, it's barely done 1000miles since rebuild though, I got it on the road at the end of May. I did the Banbury Run and also last weeks ' Levis Cup Trial' , which is a 100 mile road trial. It should do 65-70 without a problem, and with different cams and no silencer 75-80, although I won't be trying that as at 79x105 bore and stroke, it's not really meant to be revved to death !
sickpup
Old Timer
PostPosted: 16:32 - 07 Oct 2014    Post subject: Reply with quote
Thought I would link up all the photos for you just to make things easier for people to see.
https://www.bikechatforums.com/download.php?id=93835
https://www.bikechatforums.com/download.php?id=93836
https://www.bikechatforums.com/download.php?id=93838
Lovely bike you have there. I've only ever seen the Sunbeam S7 and S8 so this is a nice treat.
Davetom500
PostPosted: 17:09 - 07 Oct 2014    Post subject: Reply with quote
Thanks Sickpup..
Pre '37 Sunbeams are known as Marston Sunbeams after John Marston, the founder. In '37, they were bought out by AMC, then Bsa in '43. There are different owners clubs for Marston and non Marston 'beams. They were considered by many to be more of a 'Rolls Royce' of motorcycling than Brough Superiors, because Sunbeam made virtually everything in-house. Every Marston Sunbeam that left the factory had the tank lined in Gold leaf
bypass2
PostPosted: 17:45 - 07 Oct 2014    Post subject: Reply with quote
Thats a nice bike.
CHR15
Turbo nutter bastard
PostPosted: 20:36 - 07 Oct 2014    Post subject: Reply with quote
got any more pictures of the engine internals?
pepperami
PostPosted: 21:23 - 07 Oct 2014    Post subject: Reply with quote
NO! Mr CHR15 , you cannot put a turbo on it! Wink
Davetom500
PostPosted: 21:30 - 07 Oct 2014    Post subject: Reply with quote
Timing Chest..Basically inlet and exh cams, with followers sat on top, then push rods on top of that, going through housing to tappets under the valves... Apologies they're a bit low res, struggling with resizing a bit !
Davetom500
PostPosted: 21:36 - 07 Oct 2014    Post subject: Reply with quote
One piece head and barrel. Barrel is a blind hole- watch your local reborers eyes roll when you show them that..😀
Davetom500
PostPosted: 21:39 - 07 Oct 2014    Post subject: Reply with quote
Primary side.. Clutch has 4 solid steel plates, and 4 containing 44 7/16" dia cork inserts each
Davetom500
PostPosted: 21:47 - 07 Oct 2014    Post subject: Reply with quote
Clutch plates.. Had them recorked for a tenner a plate by some retired old guy in the Sunbeam club..bargain!
Davetom500
PostPosted: 21:51 - 07 Oct 2014    Post subject: Reply with quote
Last pic.. This is on the entrance drive to Umberslade Hall in Warwickshire, known as Slumberglade Hall when Bsa and Triumph used it as their Research and ( lack of ) Development, from about 67-71
PostPosted: 23:18 - 07 Oct 2014    Post subject: Reply with quote
That is some novelty shit right there, not my type at all but that is superb Shocked
Davetom500
PostPosted: 23:20 - 07 Oct 2014    Post subject: Reply with quote
I'm a bit out of touch, is ' Novelty shit' a complement ?😊
BravoCharlie
PostPosted: 10:16 - 08 Oct 2014    Post subject: Reply with quote
i believe it is, but that is a lovely, lovely bike. not something I'd ride but something I can definitely admire. thanks for sharing!
Current: Kawasaki ZL600 Eliminator
Past: Suzuki GZ125, Kawasaki GT550, Kawasaki GPX600R, Honda vrx400,Kawasaki Zephyr 750, Suzuki SV650 K5
Dream as if you'll live forever, live as if you'll die today.
RhynoCZ
PostPosted: 11:31 - 08 Oct 2014    Post subject: Reply with quote
This thread should be 18+. So much bike porn here. Smile
Minty
PostPosted: 11:34 - 08 Oct 2014    Post subject: Reply with quote
Don't use it, it aint safe. Wink
My fingers smell of your mum.
The last post was made 12 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 123.26 Kb
