Pearlescent paint ..
A100man
PostPosted: 21:18 - 07 Oct 2014    Post subject: Pearlescent paint .. Reply with quote
Hi all
I have an FZ750 which has what I would call pearlescent white paint on the tank and fairing. My usual paint guy said he can't make a touch up for the tank chips and gave me some flat off-white that I will likely use on the basis that it is probably better than leaving it out to the elements.
On the fairing tough I am looking to buy some new panels that will require paint from scratch and I'm wondering how I might get an approximate match - sounds like it might involve several stages which will be easy to mess up.
Any ideas out there ? Other than 'take it to dream machine'. the bike didn't cost much so I'm only tidying it up a bit really.
Cheers
bamt
PostPosted: 21:36 - 07 Oct 2014    Post subject: Reply with quote
If you aren't worried about it being original, then why not paint the tank and fairings with a simpler non-pearlescent paint? That way they'll match, probably cheaper doing both than getting fancy paint on the fairing and getting touch up paint will be easy.
lihp
PostPosted: 23:52 - 07 Oct 2014    Post subject: Reply with quote
Unless you are an exceptionally good painter, you probably won't get a match on that DIY.
Even for the pro's a match will be difficult as the effect is created not only in the paints used, but in the layering of them and conditions that they are done in.
A100man
PostPosted: 06:32 - 08 Oct 2014    Post subject: Reply with quote
Hmm, yes. I recall trying to repaint my purple fizz 30+ years ago and having similar issues. Trying to layer a clear purple over a metallic base coat. By the time you had depth of colour the metallic was obliterated. 'Might' be easier with white mind you..
Cheers
bladerunner
PostPosted: 01:39 - 09 Oct 2014    Post subject: Reply with quote
shockingly I've found halfrauds a good place for white pearl match on older yams and kwaks but you do need to either be doing a stone chip touch up or a full single part respray....you do need to buy at least 1/4 litre for the sub £30 mark tho they have the paint codes and the mix ratio pretty right to be fair.....as much as i hate to admit it, so long as the guy behind the counter knows what hes doing it works well!
A100man
PostPosted: 11:53 - 09 Oct 2014    Post subject: Reply with quote
Thanks for the reply - sub £30 mark ? Is that the minimum order something..
Cheers
The last post was made 11 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 47.85 Kb
