Smallish van for bike
uk_ryan
PostPosted: 20:02 - 10 Oct 2014    Post subject: Smallish van for bike Reply with quote
Hi ,
I need a van for work but i want it too be able to fit a yam r6 in the back if needed but not too massive like a tranny with resonable mpg and not mega slow. I was thinking a vw caddy maxi, will it fit in? Any other suggestions?
PostPosted: 20:09 - 10 Oct 2014    Post subject: Reply with quote
Fairly tight fit.
Vitos are surprisingly nice and cheap to run... I can't say the Transit Connect I drove was any good at all on fuel, so adding a bike to it would be horrendous Thumbs Up
Mario_Kempes
PostPosted: 20:15 - 10 Oct 2014    Post subject: Reply with quote
small vans look a pain to load a bike into.
jjdugen
PostPosted: 20:28 - 10 Oct 2014    Post subject: Reply with quote
Peugeot Expert.
PostPosted: 20:42 - 10 Oct 2014    Post subject: Re: Smallish van for bike Reply with quote
A caddy maxi seems to be *just* ok; I've wondered about one in the past - maybe even a normal size one and take out the passenger seat for putting bikes in. However the Vito has a bit of extra height - dirt bikes are tight as it is in it. Fuel economy isn't bad on long runs, especially if driven carefully - not so great around town.
VW T4/T5 similar to vito - the later Vitos are RWD which gives a decent turning circle (while the T4 is pretty horrendous.)
Fladdem
PostPosted: 21:23 - 10 Oct 2014    Post subject: Reply with quote
A mate got his DT 125 in a 1998 Vauxhall Combo.
My boss uses a vito, we got two crossers in the back of his 109. The vito also carries his gixxer track toy around too. Vitos are meant to be pretty un-killable too. Thumbs Up
STONEY!
PostPosted: 21:35 - 10 Oct 2014    Post subject: Reply with quote
Peugeot Expert, Citreon Dispatch, Fiat Scudo all the same van 3 engine choices.
1.9 non turbo = very slow but cheap, reliable and 50mpg
1.9 turbo = reasonable performance, reliable and still 50mpg but not if driven fast
2.0 hdi = fastest and quietest but more to go wrong, 40-45mpg driven sensibly.
you can fit most bikes easily in the back, 2 enduro's 3 at a push. they dont really rust, cheap to buy, parts are cheap too. on the downside they are looked down on for being french and door locks are pretty crap so most have aftermarket locks fitted.
Al
PostPosted: 21:38 - 10 Oct 2014    Post subject: Reply with quote
I've got the newer shape combo with a bulkhead and my FZR would just fit in diagonally. The problem is you normally have to run a motorbike up the ramp into the back of a van and you can't really run into a combo.
Yamaha FZR400RR 3tj
My Instagram Thingy
Fladdem
PostPosted: 22:14 - 10 Oct 2014    Post subject: Reply with quote
Yeah no running into small vans, usually takes a couple of people to help push instead of using momentum.
Correct me if I'm wrong, but I believe I once saw a thread with a gixxer in a clio? I'd imagine with enough creativity you could squeeze most bikes into most vehicles. But one that fits easier is probably best.
Shaft
PostPosted: 22:15 - 10 Oct 2014    Post subject: Reply with quote
You can, but it feckin hurts if you get it wrong!
I'm in a similar position and will probably go down the Expert/Dispatch/Scudo route.
As said, relatively cheap to buy and run, with the added bonus that they are quite pleasant to drive.
Vito is a good choice if you need something bigger, but watch out for rust, noisy suspension and self destructing gear linkages; various parts of the linkage are available separately and some of it is adjustable, but if the cables need changing and you've never done one before, save yourself the aggro and pay somebody else to do it.
Val
PostPosted: 22:49 - 10 Oct 2014    Post subject: Reply with quote
I would not trust any french or italian machinery. You know why. They may be pleasent to drive only if they are moving. Not always.
Since BMW does not do vans you have 2 options: VW and Mercedes.
Funny enough Mercedes Vito which IMO is the best diesel van is cheaper then VW?!?
So for me there is one choice then: Mercedes Vito diesel, preferably not the smallest 1.6 engine something like 108/109 CDI is the best value for money. You can find rust, but you need to look for more then 10 years old van. I bought one for £1000 done 5000 miles in Europe and sold it two months later for the same price.
Dare you to do that same in 10 year old Citroen? Laughing Laughing Laughing
PostPosted: 22:59 - 10 Oct 2014    Post subject: Reply with quote
Good (or maybe not) to know - mine need doing Sad.
Also rust, lots of it.
Shaft
PostPosted: 23:26 - 10 Oct 2014    Post subject: Reply with quote
Yep, you know why?
Because I look after several fleets of vans and the Citroens are as good as most and better than many.
One of my customers currently runs about 150 Citroens and they have been amongst the most reliable vans he has ever bought; couple of gearbox issues on early Nemos, everything else is normal wear and tear (and they lead a very hard life) in fact he's got half a dozen 2007 Dispatches, all with well over 100K on the clock and we never see them.
By contrast, I always seem to have a Merc or two in my place, usually with something expensive wrong with them (one poor guy has spent nearly £8K on his Vito this year).
Shaft
PostPosted: 23:31 - 10 Oct 2014    Post subject: Reply with quote
Are you sure it's the cables?
There's some adjustment at the lever end, there's also a bush that goes there, which is simple and cheap to fix.
At the gearbox, there's a linkage arm with another bush that fails, only available as part of the arm, but I think it's only about 30 quid and is another easy fix.
Don't rush into cables until you're absolutely certain that's the problem.
PostPosted: 23:36 - 10 Oct 2014    Post subject: Reply with quote
The bush at the lever end definitely has 'issues' - as I found when the vertical actuation stopped working leaving it stuck in neutral just as it started to rain REALLY hard in the start of rush hour traffic on the way to it's MOT - luckily was ahead of time for once, so managed to drive it to the MOT in third once I'd worked out it was a problem there not under the van and get it working again in the car park.
Shaft
PostPosted: 00:03 - 11 Oct 2014    Post subject: Reply with quote
Generally (but not always) when the bushes go you lose one or other plane of movement, if it's the cables, they start to become very difficult to select gears, usually starting with the extremities (fifth and reverse) but second can be a bugger as well.
The lever gets really stiff as you move across the gate and/or going into gear; in extremis, either you won't get into gear at all, or it will jump out, unless you hold the lever.
PostPosted: 00:07 - 11 Oct 2014    Post subject: Reply with quote
It jumps out of first unless the lever is held in - typically you feel a kind of 'double click' to get it into first on most cars/light vans, but it doesn't seem to go that far - as it isn't able to lock in properly.
It's stiff to get into second.
Both seemed they could be consistent with there being a bit of slop in the vertical play - or so I decided once it had popped out completely.
Rest of the gears are pretty much ok, bar being slightly stiff maybe.
jjdugen
PostPosted: 00:41 - 11 Oct 2014    Post subject: Reply with quote
Mines a '98 Expert 1.9 TDI. Been the most reliable of any vehicle I've owned. Holds everything up to a Harley but does need the bike loading at an angle so is best with two hands loading and a longish ramp.
Radiator went about five years ago, its had an engine mount and a new silencer system and some tyres. Still hums along like a good 'un. 145000 miles up, can't speak highly enough of them.
One downside is that you can't go into the inner London area due to emissions restrictions, but I would never go there anyway.
STONEY!
PostPosted: 01:14 - 11 Oct 2014    Post subject: Reply with quote
Later expert/scudo/dispatches can go into london fine.
Only those who dont know any better dismiss the french vans with the exception of the renaults that do seem to live up to the poor reputation. In reality I firmly believe they are the best option overall. Look at the competition:
Merc sprinter, like a car to drive but rust like hell, go wrong a lot and expensive to fix.
Nissan vanette, slow uneconomical rust bucket but reliable and will pull a house down
Toyota hiace, good but poor mpg and quite small inside
Ford transit cheap but unreliable poor mpg bit bigger rust bucket.
Vw transporter, these are very good but sadly poor on fuel, if you get 30mpg your doing well. If it weren't for this I would have one but when you consider doing 20,000 a year its going to cost £1500 or so more in fuel than the any of the french vans.
Dischord
PostPosted: 20:20 - 11 Oct 2014    Post subject: Reply with quote
I'm not sure some of you guys realise just how much a Mercedes Vito rusts? and it's not even the new ones they all suffer from really bad rust just do a google search!
If this was me I'd be buying a Peugeot Expert or LDV Cub / Nissan Vannette Thumbs Up I've driven plenty of French vehicles with work and they take a thrashing, my dad did 8 years and about 60k in a Peugeot Partner without touching a thing, not even servicing it - it's still going strong now!
I think deep down everyone would like a T5 but for me the cost is just too much!
2012 KTM EXC 250
PostPosted: 20:25 - 11 Oct 2014    Post subject: Reply with quote
Especially the W639 white ones. To be fair, sorting out the rust has been 'on the list' for far too long and wouldn't have got this bad if I'd got around to sorting it out sooner.
Prefer a Vito over a T5, not just for not paying 'weedub' tax, but RWD. If the T5 was really low in the back, I'd be happy with that making up for the limited steering lock, but it only manges a little more load height on the Vito.
Jonathan A
PostPosted: 20:30 - 11 Oct 2014    Post subject: Reply with quote
LDV Pilot?
Hyosung GT650R
STONEY!
PostPosted: 20:48 - 11 Oct 2014    Post subject: Reply with quote
Ldv cub ans vanette are slow rot boxes!
Ldv pilot is also a slow rot box and being rwd a bit high to get bikes in and isnt that big inside
STONEY!
PostPosted: 20:50 - 11 Oct 2014    Post subject: Reply with quote
Transporter t5 is a bit of a let down to be honest most seem to have lots of problems. The t4 however is a quality machine.
PostPosted: 21:36 - 11 Oct 2014    Post subject: Reply with quote
https://i59.tinypic.com/1zvcys8.gif
The last post was made 12 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 135.5 Kb
