| uk_ryan |
 uk_ryan Two Stroke Sniffer
| P.addy |
 P.addy Red Rocket
 Posted: 20:09 - 10 Oct 2014 Post subject: |
Fairly tight fit.
Vitos are surprisingly nice and cheap to run... I can't say the Transit Connect I drove was any good at all on fuel, so adding a bike to it would be horrendous  |
| Mario_Kempes |
 Mario_Kempes Trackday Trickster
| jjdugen |
 jjdugen World Chat Champion
| G |
 G The Voice of Reason
| Fladdem |
 Fladdem World Chat Champion
 Posted: 21:23 - 10 Oct 2014 Post subject: |
A mate got his DT 125 in a 1998 Vauxhall Combo.
My boss uses a vito, we got two crossers in the back of his 109. The vito also carries his gixxer track toy around too. Vitos are meant to be pretty un-killable too.  ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
| STONEY! |
 STONEY! Brolly Dolly
| Al |
 Al World Chat Champion
| Fladdem |
 Posted: 22:14 - 10 Oct 2014 Post subject: |
| Al wrote: | | Fladdem wrote: | A mate got his DT 125 in a 1998 Vauxhall Combo.
I've got the newer shape combo with a bulkhead and my FZR would just fit in diagonally. The problem is you normally have to run a motorbike up the ramp into the back of a van and you can't really run into a combo. |
Yeah no running into small vans, usually takes a couple of people to help push instead of using momentum.
Correct me if I'm wrong, but I believe I once saw a thread with a gixxer in a clio? I'd imagine with enough creativity you could squeeze most bikes into most vehicles. But one that fits easier is probably best. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
| Shaft |
 Shaft World Chat Champion
 Posted: 22:15 - 10 Oct 2014 Post subject: |
You can, but it feckin hurts if you get it wrong!
I'm in a similar position and will probably go down the Expert/Dispatch/Scudo route.
As said, relatively cheap to buy and run, with the added bonus that they are quite pleasant to drive.
Vito is a good choice if you need something bigger, but watch out for rust, noisy suspension and self destructing gear linkages; various parts of the linkage are available separately and some of it is adjustable, but if the cables need changing and you've never done one before, save yourself the aggro and pay somebody else to do it. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| Val |
 Val World Chat Champion
 Posted: 22:49 - 10 Oct 2014 Post subject: |
| G |
| Shaft |
 Posted: 23:26 - 10 Oct 2014 Post subject: |
Yep, you know why?
Because I look after several fleets of vans and the Citroens are as good as most and better than many.
One of my customers currently runs about 150 Citroens and they have been amongst the most reliable vans he has ever bought; couple of gearbox issues on early Nemos, everything else is normal wear and tear (and they lead a very hard life) in fact he's got half a dozen 2007 Dispatches, all with well over 100K on the clock and we never see them.
By contrast, I always seem to have a Merc or two in my place, usually with something expensive wrong with them (one poor guy has spent nearly £8K on his Vito this year). ____________________ Things get better with age; I'm close to being magnificent........
| Shaft |
 Posted: 23:31 - 10 Oct 2014 Post subject: |
| G wrote: | | Shaft wrote: | but if the cables need changing and you've never done one before, save yourself the aggro and pay somebody else to do it. |
Good (or maybe not) to know - mine need doing .
Also rust, lots of it. |
Are you sure it's the cables?
There's some adjustment at the lever end, there's also a bush that goes there, which is simple and cheap to fix.
At the gearbox, there's a linkage arm with another bush that fails, only available as part of the arm, but I think it's only about 30 quid and is another easy fix.
Don't rush into cables until you're absolutely certain that's the problem. ____________________ Things get better with age; I'm close to being magnificent........
| G |
| Shaft |
 Posted: 00:03 - 11 Oct 2014 Post subject: |
Generally (but not always) when the bushes go you lose one or other plane of movement, if it's the cables, they start to become very difficult to select gears, usually starting with the extremities (fifth and reverse) but second can be a bugger as well.
The lever gets really stiff as you move across the gate and/or going into gear; in extremis, either you won't get into gear at all, or it will jump out, unless you hold the lever. ____________________ Things get better with age; I'm close to being magnificent........
| G |
| jjdugen |
| STONEY! |
| Dischord |
 Dischord World Chat Champion
 Posted: 20:20 - 11 Oct 2014 Post subject: |
I'm not sure some of you guys realise just how much a Mercedes Vito rusts? and it's not even the new ones they all suffer from really bad rust just do a google search!
If this was me I'd be buying a Peugeot Expert or LDV Cub / Nissan Vannette I've driven plenty of French vehicles with work and they take a thrashing, my dad did 8 years and about 60k in a Peugeot Partner without touching a thing, not even servicing it - it's still going strong now!
I think deep down everyone would like a T5 but for me the cost is just too much! ____________________ 2012 KTM EXC 250
Check out my vids - https://www.youtube.com/user/KTMSparky/videos |
| G |
| Jonathan A |
 Jonathan A Crazy Courier
| STONEY! |
| STONEY! |
| Rogerborg |
 Rogerborg nimbA
The last post was made 12 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
