Rusting frame, MOT
natefz6
PostPosted: 16:57 - 13 Oct 2014    Post subject: Rusting frame, MOT Reply with quote
Hi all,
My dependable Gs500 has developed what can be described as a hole in its frame Sad its located in the link between the two pieces of the right hand lower frame and the left hand main bit. Its on the rear side just above where the exhausts go in to the engine and is about 1-2cm big.
This bit, https://www.ebay.co.uk/itm/98-Suzuki-GS500-GS-500-LOWER-RIGHT-FRAME-RAIL-/191047015678?pt=Motorcycles_Parts_Accessories&hash=item2c7b4a1cfe
Now I am replacing this beast in the near future but unfortunately I use this work horse for the daily commute and its MOT is coming up in November. Is this something it will fail for? and am I putting my life in danger riding it? I have the money for a new bike but just need to find the time to go out and buy one! I don't really want to pour money in to this one needlessly
All of the examples of this part available on ebay seem to be from the US or as part of a whole frame. Has anyone replaced this part? I am guessing its an engine out thing?
Advice much appreciated.
"no I didn't steal it that's just the way I ride"
Itchy
PostPosted: 16:59 - 13 Oct 2014    Post subject: Reply with quote
Safe method, get a welder to weld a plate over it.
Old skool non safety nazi BCF method, wrap some tape around it and enjoy the bliss of ignorance.
RhynoCZ
PostPosted: 19:16 - 13 Oct 2014    Post subject: Reply with quote
Itchy wrote:
...wrap some tape around it and enjoy the bliss of ignorance...
...till the accident.
EDIT: Buy the whole frame, take parts you need, sell the rest. Thumbs Up
Itchy
PostPosted: 19:20 - 13 Oct 2014    Post subject: Reply with quote
RhynoCZ wrote:
...till a accident.
Pfft BCF is far too risk adverse, go drive a car if you don't want to take any risks.
wr6133
PostPosted: 19:26 - 13 Oct 2014    Post subject: Reply with quote
This, pretty sure the MOT tester can't look behind the tape either.
SQL
I was riding on a broken swingarm spindle for a few weeks
https://i0.kym-cdn.com/photos/images/original/000/151/628/kitty-says-fuck-the-police-4921.gif
PostPosted: 19:33 - 13 Oct 2014    Post subject: Reply with quote
Would cover for MOT.
Is it just the frame rail itself or actually part of the frame. A GS500 is likely to be sitting in a scrappy somewhere with the right parts Thumbs Up
RhynoCZ
PostPosted: 19:41 - 13 Oct 2014    Post subject: Reply with quote
https://www.ebay.de/itm/501-SUZUKI-GS-500-E-GM51B-Rahmen-Motorhalter-/231014313563?pt=DE_Motorradteile&hash=item35c986ae5b Thumbs Up
https://www.ebay.de/itm/Motorhalter-Rahmen-Unterzug-Suzuki-GS500E-GM51B-Bj-90-/251435427125?pt=LH_DefaultDomain_77&hash=item3a8ab82535 Thumbs Up
https://www.ebay.de/itm/Suzuki-GS-500-E-GM51B-Bj-93-Rahmen-Unterzug-/161224750527?pt=DE_Motorradteile&hash=item2589be75bf Thumbs Up
Und so fort...
natefz6
PostPosted: 20:38 - 13 Oct 2014    Post subject: Reply with quote
Danke schoen! I had not thought of looking closer to home, eBay only suggested US sellers.
So if I cover it I should be fine for the MOT?
In that case I will cover it and hammerite the shit out of it for now and order one from eBay.de to fit when it gets here.
Thanks again
PostPosted: 20:42 - 13 Oct 2014    Post subject: Reply with quote
They're not supposed to remove anything, so a bit of tape around it etc should be fine for the MOT.
I should have one for sale, but it's 250 miles away and not sure when I'll next be back there, so probably best to just order one from the above Smile.
natefz6
PostPosted: 20:43 - 13 Oct 2014    Post subject: Reply with quote
It's the bit that crosses between the two parts of the frame. So the back if the horizontal bit above the pipes at the front of the engine in this picture https://wiki.gstwins.com/uploads/Upgrades/sliders_naked.jpg
The engine is still bolted in so it's not like it's going to fall off, and I am not Evel Kenevel.
natefz6
PostPosted: 13:18 - 11 Nov 2014    Post subject: Reply with quote
I got around to replacing the offending part this weekend...
https://www.coolioso.org/junk/image2sm.jpg
oops a bit worse than I originally thought, ordered a new bit off fleebay and this is how it looks now.
https://www.coolioso.org/junk/image1sm.jpg
Just need to give it a clean and a new tyre and I should be good for the MOT as long as they don't notice the twisted sub frame and the slack chain Wink .
alt tab
PostPosted: 15:02 - 11 Nov 2014    Post subject: Reply with quote
That's pretty fucking rusted mate.
I take it that the majority of that wear comes from from where road grime flicks up from the front wheel?
How about wrapping your new shiny one so it lasts a bit longer, although it must have taken a fair few years to get that bad?
natefz6
PostPosted: 15:43 - 11 Nov 2014    Post subject: Reply with quote
Its a 11 year old bike and the only time its been inside is in the showroom, but yeah it was much worse than I thought it was. Once I took it off I poked at it and it crumbled...
There is lots of crap all over the front of the wheel and the exhaust bolts look more like rusty nails Sad .There are two drainage holes just where the rust started, I guess they fill with crud and keep the moisture in and it rots.
PostPosted: 16:18 - 11 Nov 2014    Post subject: Reply with quote
a few points:
Arrow Looks like a good job you replaced it.
Arrow You're lucky it's a bolt in-bolt-out rail and not part of the frame
Arrow That hole is so big your engine could have fallen out when riding! Shocked Smile
PostPosted: 17:00 - 11 Nov 2014    Post subject: Reply with quote
_Iain_ wrote:
Having changed an engine on a GS500 I conclude you are chatting shit. The bar that's rusted has nothing to do with suspending the engine.
https://i1148.photobucket.com/albums/o574/_Iain_/172CFDAE-A875-4771-A4DA-6CF5801B6BE4-1010-0000016964BCF078.jpg
Here's a GS500 standing perfectly happily with that bit of the frame removed entirely.
Note the engine remains in the frame as the rear mounting point is part of the main frame, and half of both the front mounts are welded to the main frame.
Iain,
There you go again with your annoying superior tone. I'm perfectly aware that there are other engine mounts other than the lower cradle. I've owned more than one bike with a removable bottom cradle, and have in fact changed engines in these bikes. I was not all together serious in saying that the engine could have fallen out, however it would most certainly have been an MOT failure, and could have resulted in the shifting of the engine in the remaining mounts bending or otherwise damaging them. That isn't going to be safe in anyones book. It wasn't safe to ride in my opinion.
natefz6
PostPosted: 17:44 - 11 Nov 2014    Post subject: Reply with quote
I ended up supporting the engine as I was not sure if the other bolts would support it on it's own so thought better safe than sorry. Looking at that picture I needn't have bothered!
I agree it was not safe to ride one minute it was a bit of bubbling paint then the next time I looked it had a hole. Before I took it off the hole was 1-2cm but it was eaten inside out so most of what you see in the picture when it was off was hidden by paint holding the crud together. Pretty worrying really I need to pay more attention to my bike Sad.
The last post was made 11 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.26 Sec - Server Load: 1.91 - MySQL Queries: 13 - Page Size: 124.39 Kb
