Mito 443
Bike Chat Forums Index -> Show & Tell Goto page 1, 2, 3, 4, 5, 6  Next
Yazza54
PostPosted: 19:48 - 22 Oct 2014    Post subject: Mito 443 Reply with quote
Incoming!
Building a bit of a special, so far it's a cagiva mito frame, RSV mille front end (resprung etc of course), RS250 rear wheel, Honda RS250 GP bike Wilbers shock. There are a few 350YPVS hybrids knocking about but I'm going a step further and stroking and big boring it, +7mm stroke and 68mm bore all developed in the states on banshee quads. This takes it to 443. I've not started the engine building yet but the bike is built as a roller, motor is the next job. I'm hoping for circa 95hp & 120kg. The mito frame is pretty good but the suspension was shit hence the re engineering on the front and rear ends etc.
Some pics I've taken so far, it has taken a lot of engineering to make the rear wheel fit the swinger and the front end fit, motor in etc. Just had the pipes made which is a big milestone.
This is where it's up to now...
If people are interested I'll keep it updated. Original thread is here.. You can see how it spiralled out of control a bit Wink
https://www.pistonheads.com/gassing/topic.asp?h=0&f=74&t=1342728&mid=158768&i=0&nmt=Mito+443+Project+&mid=158768
https://i133.photobucket.com/albums/q53/yazza54/F14F66E8-4B3E-499C-AA9A-36BAC177749A_zpszyvalo7s.jpg
https://i133.photobucket.com/albums/q53/yazza54/A5E85670-4117-405B-9368-27CE31AAE3E1_zpso50sgdqs.jpg
https://i133.photobucket.com/albums/q53/yazza54/ED832AC1-D346-4C94-A242-BE611B7055A1_zpslavrw74u.jpg
I'm unhappy cos I eat and I eat cos I'm unhappy
Aff
PostPosted: 19:50 - 22 Oct 2014    Post subject: Reply with quote
Looks awesome. Please keep updated. Thumbs Up
Electric Bike Project
stevo as b4
PostPosted: 20:03 - 22 Oct 2014    Post subject: Reply with quote
This +10! Thumbs Up
Should be something very special indeed, and I'm looking forward to hearing/seeing the big hybrid RD motor build too!
The pipe's are a work of art, and the diameter of the belly section says that the motor is going to be quite a few cc's!
I've always liked the looks of the Mito, and would one day like to find a tatty cheap one, to try fitting a GasGas TXT300 trials engine for something different too! Laughing
Yazza54
PostPosted: 20:15 - 22 Oct 2014    Post subject: Reply with quote
Cheers lads
https://i133.photobucket.com/albums/q53/yazza54/E5822DEF-8B30-4884-B8E4-0D4C85715EF7_zpsgnscbgph.jpg
Some engine bits Smile
The motor has the potential to make well over 110hp, but I'm not willing to trade off all the mid range and longevity that comes with that. I'll be brutal as it is!!
Tungtvann
PostPosted: 20:24 - 22 Oct 2014    Post subject: Reply with quote
Looks awesome, will look forward to seeing it develop. 95hp is not too shabby at all, that's about the same as my FZ6, but it's going to weigh less with you on it (unless fatty) than mine does alone!
Knacker
PostPosted: 20:31 - 22 Oct 2014    Post subject: Reply with quote
Holy Santa Claus shit!
Awsome looking build!
Previous: K1 GSXR 1000
pepperami
PostPosted: 20:46 - 22 Oct 2014    Post subject: Reply with quote
There only two things must do in your life at the moment.
Build moto-special and post on here Thumbs Up
DO IT NOW!
You are only allowed to go to work to get funds for the bike Wink
chickenstrip
PostPosted: 20:50 - 22 Oct 2014    Post subject: Reply with quote
Incredible build mate! I never even knew you could get all that engine stuff done - interchangeable domes for the heads ffs! Shocked
A man of many talents (and contacts Laughing ) you obviously are. Thanks for sharing this here, including the original build thread; a great read so far. Looking forward to reading more, and especially the finished project Thumbs Up
Just_James
PostPosted: 22:54 - 22 Oct 2014    Post subject: Reply with quote
Shocked
Stunningly beautifully amazing... and stuff Shocked
sidewinder
PostPosted: 23:50 - 22 Oct 2014    Post subject: Reply with quote
Sweet needing more now Very Happy
bikertomm
PostPosted: 12:59 - 24 Oct 2014    Post subject: Reply with quote
Holy jizz bucket that's cool. Following Thumbs Up
Matt B
PostPosted: 13:24 - 24 Oct 2014    Post subject: Reply with quote
https://memeorama.com/wp-content/uploads/2012/01/MOAR.jpg
Yazza54
PostPosted: 19:51 - 24 Oct 2014    Post subject: Reply with quote
Mono block 68mm barrels, billet inlet manifold and 38mm mikunis
The barrels have been cast to match the long stroke, no power valves, totally different porting to a YPVS.
https://i133.photobucket.com/albums/q53/yazza54/FAAD56BF-F36D-48FD-9EBF-F9B8ACBC00BB_zps2abaqgvq.jpg
https://i133.photobucket.com/albums/q53/yazza54/3A4E8A31-FFC7-49AC-95CB-7CB624ADE9F5_zpsqrvaaqyk.jpg
Crank cases trenched to clear the rod due to longer stroke
https://i133.photobucket.com/albums/q53/yazza54/Mobile%20Uploads/2014-06/0F7D68E7-438E-4DE4-91F8-495B258751E3_zpsiuvccape.jpg
https://i133.photobucket.com/albums/q53/yazza54/Mobile%20Uploads/2014-06/CFDBB0B5-A0CC-4034-9351-401414F28EC6_zpsgfhyji9h.jpg
Upgraded oil pump to feed extra capacity..
https://i133.photobucket.com/albums/q53/yazza54/F65C30EF-D8D7-4CA6-9E25-0F95EE18FD4E_zpsrf1tnpmt.jpg
Lightened flywheel
https://i133.photobucket.com/albums/q53/yazza54/7B763E9F-2581-4CE7-ABAD-FD231F6BFF98_zpsiy4h1jqv.jpg
Modified sprocket carrier and custom sprocket, 530 blank milled back to inset it nearer the wheel then milled back to 520 on the outer side. Meant I could align the chain without taking lots of material off the carrier. Countersunk with ti bolts for additional clearance
https://i133.photobucket.com/albums/q53/yazza54/A4D29843-2908-488C-9BD0-2EF17CD4FCCE_zpsulwsy12a.jpg
Pingel dual high flow tap on a plastic rs125 tank which suits the fairings better (tz250 fairings), also lighter than mito tank
https://i133.photobucket.com/albums/q53/yazza54/B1BD7FC3-404C-487E-994D-3A253B2D8707_zpsey7s76si.jpg
Tz250 tail
https://i133.photobucket.com/albums/q53/yazza54/EE60BF57-1319-4D5B-9CAF-1B898BA80C6A_zpsijvqnjis.jpg
Billet head and domes
https://i133.photobucket.com/albums/q53/yazza54/4DD9DA1A-0323-4E02-8D3B-0F1FDCB75587_zps9fuqdsxc.jpg
https://i133.photobucket.com/albums/q53/yazza54/560DCC58-AEAF-4677-AAE4-3F7524774A87_zps3rkt7ove.jpg
https://i133.photobucket.com/albums/q53/yazza54/43B57AA5-6191-4EE4-972E-68572D483B14_zps92gsmihp.jpg
Brand new 7mm stroker crank with TZ 16 pin big ends and heavy duty 11 ball mains
https://i133.photobucket.com/albums/q53/yazza54/FA225148-5A80-4B3A-8241-A3C0BAD453C4_zpsyvjrr1o5.jpg
More randoms
https://i133.photobucket.com/albums/q53/yazza54/8F504A43-9565-449D-8C53-272F1ABC4427_zpsvr7igbfj.jpg
https://i133.photobucket.com/albums/q53/yazza54/2F2EB40D-34F8-44B1-A026-DDB756A3EDED_zps3wam8muy.jpg
Scores highly on my jizz dyno
FLV
PostPosted: 22:18 - 24 Oct 2014    Post subject: Reply with quote
Pure sex...!
parp...brap....parp
RhynoCZ
PostPosted: 22:21 - 24 Oct 2014    Post subject: Reply with quote
https://thechive.files.wordpress.com/2014/09/darkhair.gif?w=250&h=235
daverwheeler
PostPosted: 00:04 - 25 Oct 2014    Post subject: Reply with quote
lovely, following!
Yazza54
PostPosted: 08:03 - 25 Oct 2014    Post subject: Reply with quote
Cheers lads, picking it up today the pics of the pipes came from kenny @ TSA exhausts
Hopefully later on I'll be able to bang a photo up with the seat unit sat back on and pipes on
Yazza54
PostPosted: 18:23 - 25 Oct 2014    Post subject: Reply with quote
Back home
https://i133.photobucket.com/albums/q53/yazza54/8D4F8C99-CF32-4366-80C0-B6C1FE5FBD4B_zpsnlfnz1kz.jpg
https://i133.photobucket.com/albums/q53/yazza54/C4C958B4-3F38-4FEF-A085-07C6CEB73799_zpslpvfj6wr.jpg
pepperami
PostPosted: 16:38 - 26 Oct 2014    Post subject: Reply with quote
Thumbs Up You sir are a damm fine poster of a damm fine project!
Clutchy
PostPosted: 17:24 - 26 Oct 2014    Post subject: Reply with quote
Doooooooooooooooooooooo wants Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Fladdem
PostPosted: 21:45 - 27 Oct 2014    Post subject: Reply with quote
It's so good it feels disgusting to look at. Thumbs Up
Yazza54
PostPosted: 08:54 - 04 Nov 2014    Post subject: Reply with quote
Did some messing last night, figured out the plumbing. Not much room at all but managed to get an inline rad cap in and keep it all relatively simple. Then just used a HRC catch tank, not a fan of loads of cable ties but seemed the obvious way to fix it.. Need to get a round rad cap, as you can see it's a bit tight
Also threw the heel guards on and HRC brake hose reservoir thingy as I don't really have anywhere to mount a normal reservoir. Always thought these were a bit tacky on normal road bikes but it's ideal for this.
Another thing I bought the other week is a genuine ally TZ250 subframe which fits my seat perfect... Doesn't fit the bike mind you - so that's next on the list. It's so light I thought the box was empty when it came!! The ballache of this next step is I really need to be there when it's modified as the positioning of the seat in relation to the pipes in particular will make or break the look of the bike.
Once that's done the cases and cylinder is going to mick abbey for some port work.
https://i133.photobucket.com/albums/q53/yazza54/33D177CA-56B7-4CD0-B40B-83F66C1D5106_zpsqd83m1sy.jpg
https://i133.photobucket.com/albums/q53/yazza54/F4CE7C7E-419B-420C-9A66-0C64A8D6D367_zpsn99uximp.jpg
https://i133.photobucket.com/albums/q53/yazza54/DE69D33C-86B2-4F38-B9F6-ADFE9D042745_zpse2wwgblk.jpg
https://i133.photobucket.com/albums/q53/yazza54/2505F084-2356-47E5-B551-9D797413BADF_zpstvpp8wyo.jpg
Yazza54
PostPosted: 19:27 - 04 Jan 2015    Post subject: Reply with quote
Been busy with new house etc but decided to get my shit together and crack on.
Productive day, tz250 subframe is almost fitted. Took some measurements and drawings to get stuff done over the week to finish it off. Then I can FINALLY pull the motor out for porting and build the fucker!!
https://i133.photobucket.com/albums/q53/yazza54/3823E22C-F218-45D2-A8F8-0BDC5BAAF4F2_zpsrgslmj5p.jpg
https://i133.photobucket.com/albums/q53/yazza54/4F814678-D5E7-452A-AB0F-0B7AFE47E081_zpsftnopeer.jpg
https://i133.photobucket.com/albums/q53/yazza54/661E853F-86BF-40F9-95B6-9267C398EC4D_zpswzovcjx4.jpg
Slacker24seve...
PostPosted: 22:13 - 04 Jan 2015    Post subject: Reply with quote
This makes me moist.
Banger rallies are ace
Eddie Hitler
PostPosted: 22:29 - 04 Jan 2015    Post subject: Reply with quote
https://i.imgur.com/lUoOxnc.gif
The last post was made 11 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 6
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 135.45 Kb
