| nleitao |
 nleitao Two Stroke Sniffer
 Posted: 12:32 - 26 Oct 2014 Post subject: Hard starting CBR |
Hey Guys, pretty nice community here
Well i'm facing some starting issues with my Cbr125R from 2005
I bought it last week and i'm using it for commuting.
It has an Malossi cilinder, increasing his size to 166c, and also an aftermarket exhaust. Can't really identify it.
The main issue is a hard start.
All the week in the morning, i had almost a minute of continuous start button, every day, for it to go; that's terrible for the starter and for the battery. At 16:30h it starts almost well. She sleeps in a underground garage during the night and during the day is also in a closed garage at the work.
Yesterday i changed the spark plug for a new one although the old one sparks really nice; picture below of the old one. It has a standard gap of 0.7, and Malossi recommends 0.8 to 0.9. The measuring tool is already ordered to fine tune it.
Since when i choke it a tiny bit it's really worse i imagine the mixture is to rich, so i thought i would look for the air filter box to see how the air filter is; No air filter inside! Also already ordered.
In conversation with the guy from the spark plug shop, he suggested one of those start sprays. Bought one and i really notice a difference. it starts almost instantly compared with before.
I guess i have to open the Carb tomorrow and give him a cleanup, no air filter might put dirt inside, i'll change also the fuel filter, you never know and its really cheap.
Any other thoughts?
Picture and Youtube video below
https://lh6.googleusercontent.com/-Yj5TUIREVrk/VExH9_capUI/AAAAAAAATlQ/t2IwDjgl3AM/w596-h805-no/IMG_20141025_092912.jpg
https://www.youtube.com/watch?v=JSLawPk1jCs&list=PLRd9q9Uf0C6LnPZ1AHvIfVnWsZllx-64w |
| monkeybiker |
 monkeybiker World Chat Champion
 Posted: 13:30 - 26 Oct 2014 Post subject: |
If you take out the spark plug and look at it then look for picture of spark plugs online. The condition of the plug will give you an idea if it is rich or lean.
With it having no air filter I would have thought it would be running lean. Or it's running very rich and the last owner took out the air filter to lean it out.
How to fix it? I have no idea  |
| nleitao |
| Clutchy |
 Clutchy World Chat Champion
 Posted: 14:50 - 26 Oct 2014 Post subject: |
I'm fairly sure poorly checked valve clearances could also cause this issue, how many miles has it done?
But yeah, clean carbs, replace filter and see where you are after that. ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
| nleitao |
| prawny1 |
 prawny1 World Chat Champion
| nleitao |
| prawny1 |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 01:25 - 27 Oct 2014 Post subject: |
It's probably jetted wrong. You've increased the capacity by 30%, so probably need both mains and pilots to compensate. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| nleitao |
 Posted: 13:29 - 27 Oct 2014 Post subject: |
| prawny1 wrote: | heating needle = temperature gauge? |
Yes, sorry wasn't remembering the english word
Just had a quick look on it and what i found strange is the fact of the radiator is dry, i open the top and is dry, i take out the sensor, also dry... shouldn't i had refrigeration liquid there? the compensation deposit is slightly above the maximum and i can ear liquid moving in it with the engine running.
| prawny1 wrote: | with a carb you will want to check your pilot mixture settings (may well be electronically controlled on a newish bike) and check for air leaks around the manifold or disconnected pipework. |
Pipework is ok, just checked it now
| prawny1 wrote: | Does the bike have a manual choke for cold starting? perhaps the cable is broken or slack. |
It does have and its ok, but i can't touch it, if i do, it will stop the engine if its running or not turn when in off state...
| mattsprattuk wrote: | It's probably jetted wrong. You've increased the capacity by 30%, so probably need both mains and pilots to compensate. |
I just came from opening the carburetor, it was the cleanest i ever seen! ( maybe a only had seen one other a few years ago, but the main idea is that it was really clean.) Also is a diaphragm type.
When i arrive from a ride the RPM settles steady on 3000 i reduced it now to around 2000 on the carburetor knob that stretches the gas cable.
The jets have been messed, you can clearly see someone used a wrong size screwdriver to adjust them, but i don't know the correct setting for them, also can't really find a workshop manual and a Haynes manual links for this specific model...
I'm almost sure the problem is in the mixture, just can't sort it out how to tune it...
The fact of choke it a tiny bit would suggest me that the mixture is too rich. the spark is slightly dark, also suggests the same, the previous owner took out the air filter, probably to increase the air flow, suggesting its too rich also...
Time to dive on youtube to see if i find a cbr125 carburetor tune... |
| wr6133 |
 wr6133 World Chat Champion
| prawny1 |
| chris-red |
 Posted: 14:58 - 27 Oct 2014 Post subject: |
A few points,
Don't hold the starter you shouldn't use it for more than a few seconds at a time.
Does it start ok with the spray?
By the sounds of it the carb isn't set right.
First off once it is warmed up and running take it out for a blast and see how it feels open the throttle fully and gradually reduce how it is opened. If it feels like it gets faster when you come off the throttle, you probably need a bigger main jet.
There is no point trying to set the rest of the carb untill you have the main jet sorted.
I've recently set up a carb for an old triumph using this.
https://www.hitchcocksmotorcycles.com/monobloc-how-to-tune-up
It is written for than specific carb, but applies to all cabrs. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| nleitao |
 Posted: 15:48 - 27 Oct 2014 Post subject: |
You guys are great, I really appreciate the help. When I arrive home I'll digest this new info.
Thanks again
Nuno |
| nleitao |
 Posted: 22:17 - 27 Oct 2014 Post subject: |
| prawny1 wrote: | your cooling system should be full too, lack of coolant suggests a leak, a faulty water pump or head gasket issue.
the expansion bottle is only an overflow /reserve tank for the main system.
When the coolant gets hot it expands and the radiator cap allows the excess pressure to escape preventing blown pipework and splits in the radiator, when the bike cools down again the coolant creates a negative pressure drawing the fluid back from the expansion tank. |
Really clear explanation. Well i didn't had cooling liquid at hand so i grabbed distilled water. it's better than be dried and saturday i'll dry all the system and put new liquid. I had just opened the radiator lid on the top and filled in with the distilled water. Let's see if i find water on the floor tomorrow morning. Faulty water pump doesn't seem to be the problem, since i gave start button for a second with the lid open and it spitted a nice gulf of water out.
| prawny1 wrote: | The jetting can only be altered by physically replacing the jets or enlarging the hole in the centre with micro drill bits (only good if you are running lean as you can't make the hole smaller this way), the numbers on the jets tell you the flow rate, higher number = higher flow.
Different jet makers use different sizing schemes so the numbers may not match between brands. |
physically replace the jets seems the way to go... Do you guys have a brand suggestion, or is there some kind of kit with different sizes to tune it up?
| prawny1 wrote: | To adjust the idle mixture you will have a small screw with a tapered end and a spring with a small washer and o ring beneath it for sealing.
Usually somewhere towards the front of the carb by the inlet manifold, screwing this in will weaken/lean the mixture screwing it out will richen it up,
but like I said some bikes have an electronically controlled idle mixture that will be controlled by the engine temperature circuit (cold = richer warm = leaner).
Your plug being black suggests rich running but the fact you need easy start spray suggests you are lean.
Perhaps you are lean low rpm but rich high rpm,
try turning the idle mixture screw all the way in then back out 2.5 turns and drop the diaphragm needle down by raising the little clip one slot at a time and see what your plug colour does. |
https://screencast.com/t/RpvqD7ZEaSn
I would guess this is the screw that makes the mixtures richer / leaner?
Well, this is important, but not the most important for the moment. In this moment the bike is not starting due to a short circuit somewhere in the start circuit.
https://www.youtube.com/watch?v=XducdmEM0LI&feature=em-upload_owner
I turn the key on, everything good. in the moment i press the start button i ear the start relay on/off/on/off real quick and loud. the start engine don't run. this happened after i gave a quick start with the radiator open to check it out if the water pump was running. Apparently some water jumped to somewhere it shouldn't.
i'm really becoming discouraged, when i sort out something, other something shows up... and i did bought the motorcycle with less than 5000 kms on the clock trying to avoid this... ahhh life sucks, but i have to sort out all now; tomorrow is other day.
The bike started with bump start but i let it go down, never started again on the next 3 tries to pull it down to the building garage.
Also this afternoon, noticed that after the carburetor assembly, and in desaceleration, it was making very small afterburners in the exaust.
TODO list by priority order
- Sort out the short circuit in the start circuit Maybe the start engine is gone? it had a tough time before i got the start spray. after i had it never had more than 5 seconds pressed down.
- Sort out why the radiator was dry / temperature gauge not working
- Put the air filter in the box, adjust if possible the mixture
- Sort out the Jetters |
| chris-red |
| nleitao |
| iooi |
 iooi Super Spammer
| chris-red |
| nleitao |
| prawny1 |
| nleitao |
| nleitao |
| prawny1 |
| nleitao |
The last post was made 11 years, 249 days ago. Instead of replying here, would creating a new thread be more useful? |
