4 stroke oil change.
HardDriver
PostPosted: 18:48 - 28 Oct 2014    Post subject: 4 stroke oil change. Reply with quote
Hi. Need some information. In bike is a dipstick, so how much should it be? Between min or max, or 3/4? AND how to measure? Or I should just put the dipstick or screw him fully into engine? Also, should bike be on central stand or without stand at all? How more accuracy? Thanks.
doggone
PostPosted: 19:14 - 28 Oct 2014    Post subject: Reply with quote
Should read the manual really, the exact procedure varies as some designs say run the bike for a minute then let oil settle before dipping. (some oil will be retained around the engine, pump and filters).
In practice doing it from cold on centre stand or held roughly level is probably OK and mainly you should to do it the same way each time so you can note any change.
You should pull it out and wipe it, then dip in all the way and straight out again to read the level.
The exact level is not that important but below minimum mark or above maximum are both potentially damaging.
If it's in the middle or towards the top level you are fine.
Checking it regularly you will should soon get a picture if it is tends to go down and need a small top up`after a few weeks.
Light oil use is not unusual or a sign anything is wrong, but a sudden change is more concerning.
HardDriver
PostPosted: 21:11 - 28 Oct 2014    Post subject: Reply with quote
Thanks, really good answer!! It helped a lot, but about that measuring, to get more accuracy, need to dip in all the way, but some guys do without diping out, So its' kinda difficult, because without diping of I will get less oil. About oil you told really good things, that doesn't care is it middle, toper, just behind top or low levels.
THANKS A LOT.
prawny1
PostPosted: 21:15 - 28 Oct 2014    Post subject: Reply with quote
Some bikes will need the dipstick screwed back in some will need it just rested on the threads, the main dealer would know this info.
Ideally you would check the bike on it's wheels with the bike vertical and on a level horizontal plain.
hellkat wrote:
HardDriver
PostPosted: 09:07 - 29 Oct 2014    Post subject: Reply with quote
Oh, okey, thanks. One question, if doesn't care how much oil do you put (between low and top), when isn't better to be full (maybe better lubrication, protection, when oil just stay in between top and lower levels)? I'm just curiuos about that.
c_dug
PostPosted: 09:36 - 29 Oct 2014    Post subject: Reply with quote
It's better near the top purely because when it starts to use the oil you are less likely to run below the low level.
As long as the level is between the upper and lower levels it makes little difference to to the engine, they are deemed the safe levels by the manufacturer (and likely include a small margin of error too).
doggone
PostPosted: 09:51 - 29 Oct 2014    Post subject: Reply with quote
It would probably still be safe(ish) barely touching the dipstick unless you planned on a couple of TT laps.
The oil light will come on if it can't draw oil from the sump.
Overfilling is possibly a greater risk especially with very clean new oil which is hard to see on the dipstick.
Someone bought a bike from me and thought he would change the oil himself.
It had one of those sight glas windows but to be fair it was a bit opaque and his very pale oil was not obvious as it rose.
So he just kept adding more until it was level with the filler, and thought 'that'll do it' presumably.
Then when he tried to start it the engine could't be turned over.
Probably just as well, not sure what would have happened.
HardDriver
PostPosted: 09:52 - 29 Oct 2014    Post subject: Reply with quote
and likely include a small margin of error too). How to understand that? It means that is the bettest spot for everything or what? By the way, my bike doesn't eat oil, so I'm looking for the best (like between middle).
YBR Ric
Knowing which bike you own might help us in providing the answer you seek Wink
c_dug
PostPosted: 10:17 - 29 Oct 2014    Post subject: Reply with quote
What I mean is that there is likely to be a mm or so either side of the upper and lower mark before you get into the danger zone.
You're making too much of the oil level though, it makes little difference so long as it's between the lines, certainly not anything noticeable while riding.
prawny1
PostPosted: 10:18 - 29 Oct 2014    Post subject: Reply with quote
Anything above the minimum is adequate but maximum is best for oil life as it stays cooler and any particle build up is less concentrated.
A lot of bike engines rely on splash lubrication for the cylinders, some smaller bikes even rely on it for the main bearings (needle roller) so keeping the oil level at it's max give the most protection.
I have argued this with vw guys in the past, they had fitted a deep high capacity sump to a car (bolts below the standard sump with longer pick up pipe) but only filled the oil so it barely touched the end of the dipstick.
He claimed the purpose of the extended sump was to reduce drag by stopping the crank spinning in the pool of oil, My understanding was that it was to increase oil capacity so that the oil didn't take such a beating and stayed cooler (higher capacity is needed if you run an external oil cooler too).
I couldn't see how doubling or even tripling the hp of an engine whilst at the same time reducing the oil level in the crankcase to what is way below the factory minimum was a good idea because like the bikes i mentioned the vw boxer engine relies on splash lubrication for it's cylinders.
HardDriver
PostPosted: 11:03 - 29 Oct 2014    Post subject: Reply with quote
I have an scooter, but for now, I think I will put more oil, because that think about splashing and so one, makes really good sense. I never thought about that. And that shows, that different is.
PostPosted: 11:15 - 29 Oct 2014    Post subject: Reply with quote
HardDriver wrote:
I have an scooter
Well, thanks for clearing that up.
The procedure is specific to your vehicle. Tell us what it is if you want useful help.
HardDriver
PostPosted: 11:23 - 29 Oct 2014    Post subject: Reply with quote
Rogerborg wrote:
HardDriver wrote:
I have an scooter
It just about about dipstick measurement. User before sad that fully is better, some guys sad that best is between, but I think fully is better, of that protection. Some said that 3/4 is better, so how many people so many comments Very Happy.
HardDriver
PostPosted: 19:16 - 29 Oct 2014    Post subject: Reply with quote
Question, if oil was droop, because I leaked a bit and I put in from one bottle to another, is it bad to put again to engine? Because I read it about oil reacting with air, when you take of your oil seal, sun is too bad and so one, in bottle was water (I spill all) and in one bottle was old oil (cleaned with paper). So with that oil measurement and so one it really confussed me, but now do as you said guys.
Andy_Pagin
PostPosted: 21:39 - 29 Oct 2014    Post subject: Reply with quote
Never put used or dirty oil back in the engine.
Wonko The Sane
PostPosted: 22:08 - 29 Oct 2014    Post subject: Reply with quote
especially if chance of water being added
moisture in the oil is always a bad thing, there are times it is part and parcel of changing the oil - for example if you've changed the oil and start the bike for a couple of mins to check no leaks you may find some condensation in the oil. This will burn off if you go for a ride for 20 mins
PostPosted: 00:12 - 30 Oct 2014    Post subject: Reply with quote
I would aim to keep the oil level towards the top of the min / max range. Running low on oil is likely to kill the engine rapidly (yes there is an oil pressure light on most bikes, but with an engine using plain bearings and a high pressure oil supply that warning light is likely to just tell you the engine is now trashed). Running a bit high isn't great either, but likely you will need to be quite a bit too high to stand a good chance of damage.
Some bikes it was common to over fill the oil in certain circumstances. Some of the older 5 valve Yamahas in track / race use tended to need this to avoid problems.
With oil that has leaked out there is far too high a chance that it will have collected some grit on its way out.
HardDriver
PostPosted: 17:19 - 03 Nov 2014    Post subject: Reply with quote
I just leaked some oil and now It's bad. That oil was just running in bike engine for 40 seconds, when I leaked in one bottle to another and that is bad? It was just new oil? Also fully synth castrol 10w40, so really good oil.
bikertomm
PostPosted: 17:48 - 03 Nov 2014    Post subject: Reply with quote
HardDriver wrote:
I just leaked some oil and now everything fucked up. Need to buy a new oil. Omg, I will be hobo fast Very Happy. It was just new oil, which for 40 s motor was running and I leaked because of too much Sad.
Sorry, what?
HardDriver
PostPosted: 17:54 - 03 Nov 2014    Post subject: Reply with quote
bikertomm wrote:
Sorry, what?
I just leaked some oil and now It's bad. That oil was just running in bike engine for 40 seconds, when I leaked in one bottle to another and that is bad? It was just new oil. Also it was fully synth castrol 10w40, so really good oil.
bikertomm
PostPosted: 18:22 - 03 Nov 2014    Post subject: Reply with quote
You leaked some oil? From where, how?
It leaked from a bottle to another bottle?
I'm going to take an almighty guess that you've somehow got the new engine oil leaking and caught it back in the oil container?
If that's the case I wouldn't worry to much. It's a scooter. So long as there was no metal pieces mixed with it Laughing
HardDriver
PostPosted: 18:31 - 03 Nov 2014    Post subject: Reply with quote
No, I put it too much oil into engine and when I leaked (manually), when I leaked, it was too much too. So I need to put back a bit oil into engine... But I must say, when I put too much oil I for 40s started engine and when leaked. First leaked to big bottle and into little water bottle (I think it was no watter Very Happy). That's all.
The last post was made 11 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 139.85 Kb
