| HardDriver |
 HardDriver Nova Slayer
| doggone |
 doggone World Chat Champion
| HardDriver |
 Posted: 21:11 - 28 Oct 2014 Post subject: |
| doggone wrote: | Should read the manual really, the exact procedure varies as some designs say run the bike for a minute then let oil settle before dipping. (some oil will be retained around the engine, pump and filters).
In practice doing it from cold on centre stand or held roughly level is probably OK and mainly you should to do it the same way each time so you can note any change.
You should pull it out and wipe it, then dip in all the way and straight out again to read the level.
The exact level is not that important but below minimum mark or above maximum are both potentially damaging.
If it's in the middle or towards the top level you are fine.
Checking it regularly you will should soon get a picture if it is tends to go down and need a small top up`after a few weeks.
Light oil use is not unusual or a sign anything is wrong, but a sudden change is more concerning. |
Thanks, really good answer!! It helped a lot, but about that measuring, to get more accuracy, need to dip in all the way, but some guys do without diping out, So its' kinda difficult, because without diping of I will get less oil. About oil you told really good things, that doesn't care is it middle, toper, just behind top or low levels.
THANKS A LOT. |
| prawny1 |
 prawny1 World Chat Champion
| HardDriver |
| c_dug |
 c_dug Super Spammer
| doggone |
| HardDriver |
| YBR Ric |
 YBR Ric Spanner Monkey
 Posted: 09:52 - 29 Oct 2014 Post subject: |
Knowing which bike you own might help us in providing the answer you seek  |
| c_dug |
 c_dug Super Spammer
| prawny1 |
| HardDriver |
| Rogerborg |
 Rogerborg nimbA
| HardDriver |
| Vincent |
 Vincent Banned
| _Iain_ |
 _Iain_ Banned
| HardDriver |
| Andy_Pagin |
 Andy_Pagin World Chat Champion
 Posted: 21:39 - 29 Oct 2014 Post subject: |
| HardDriver wrote: | Question, if oil was droop, because I leaked a bit and I put in from one bottle to another, is it bad to put again to engine? Because I read it about oil reacting with air, when you take of your oil seal, sun is too bad and so one, in bottle was water (I spill all) and in one bottle was old oil (cleaned with paper). So with that oil measurement and so one it really confussed me, but now do as you said guys. |
Never put used or dirty oil back in the engine. ____________________ They're coming to take me away, ho-ho, hee-hee, ha-haaa, hey-hey,
Yamaha Vity -> YBR125 -> FZS600 Fazer -> FZ1-S Fazer |
| Wonko The Sane |
 Wonko The Sane World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 00:12 - 30 Oct 2014 Post subject: |
I would aim to keep the oil level towards the top of the min / max range. Running low on oil is likely to kill the engine rapidly (yes there is an oil pressure light on most bikes, but with an engine using plain bearings and a high pressure oil supply that warning light is likely to just tell you the engine is now trashed). Running a bit high isn't great either, but likely you will need to be quite a bit too high to stand a good chance of damage.
Some bikes it was common to over fill the oil in certain circumstances. Some of the older 5 valve Yamahas in track / race use tended to need this to avoid problems.
With oil that has leaked out there is far too high a chance that it will have collected some grit on its way out.
| HardDriver |
| bikertomm |
 bikertomm World Chat Champion
| HardDriver |
| bikertomm |
| HardDriver |
The last post was made 11 years, 233 days ago. Instead of replying here, would creating a new thread be more useful? |
