Hi from Ninjagirl and a quick question!
Ninjagirl
PostPosted: 20:10 - 28 Oct 2014    Post subject: Hi from Ninjagirl and a quick question! Reply with quote
First of all a quick hi to everyone on here!
I've recently purchased a Kawasaki 250R and I was wondering if anyone could tell me exactly where the battery is located. I'm hoping to put her on an Optimate but haven't got the permanent battery leads yet so will be attaching using crocodile clips for the time being.
Many thanks!
Ninjagirl
Albigularis
PostPosted: 20:15 - 28 Oct 2014    Post subject: Reply with quote
Under the seat, same for 99% of the bikes out there.
https://www.theyeagergroup.com/Ninjette%20II%20initial%20preperation/Electronics%20Installation%20on%20the%20Ninjette%20II/Accessory%20tabs%20mounted%20to%20Battery%20Posts.JPG
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
Snop Doog
PostPosted: 20:16 - 28 Oct 2014    Post subject: Re: Hi from Ninjagirl and a quick question! Reply with quote
Many thanks!
Ninjagirl
Hi! Welcome to the forum.
As for the bike, under the seat Thumbs Up
https://www.youtube.com/watch?v=jQXpAdsGDes
Edit: I was beaten to it! Smile
Ninjagirl
PostPosted: 20:23 - 28 Oct 2014    Post subject: Reply with quote
Thanks guys, I'd figured it was under the seat but was hoping it was accessible without having to take too much off!
waffles
PostPosted: 20:37 - 28 Oct 2014    Post subject: Reply with quote
If your Optimate came with two sets of cables then while you have the seat off and access to the battery fit the one that ends in the plug. Route the cable from that and cable tie in somewhere convenient but tucked away and pop your seat back on. If you don't have that cable you can buy them easily from places like ebay, Amazon and so on. Five minute job, tops!
Ninjagirl
PostPosted: 20:48 - 28 Oct 2014    Post subject: Reply with quote
Thanks Waffles! I'll have a look on ebay later!
stonesie
PostPosted: 21:04 - 28 Oct 2014    Post subject: Reply with quote
Just remember to disconnect the Negative (Black) first and re-connect it last.
The frame and all other metal parts of the bike are connected to the Negative on all modern bikes and cars so if your spanner touches the frame while you're working it's no bother. If you disconnect the Positive first and touch the frame with the spanner there will be sparks as it shorts out the battery. Other bad things may happen too so don't do that.
Ninjagirl
PostPosted: 21:11 - 28 Oct 2014    Post subject: Reply with quote
Thanks Stonesie,
I usually leave the spannering to 1198 but as he's away for a couple of weeks, I may have to do this myself!
I am what I am - do you know what you are??!
PostPosted: 09:45 - 29 Oct 2014    Post subject: Reply with quote
If you raise your seat in the air it makes for easier access, although you may find it's a bit of a tight squeeze in there. Don't forget to grease up well.
Matt B
PostPosted: 09:52 - 29 Oct 2014    Post subject: Reply with quote
Sweeping statement - I have 2 bikes where it's not under the seat. Lots of those 1% out there.
spriddler
PostPosted: 11:17 - 29 Oct 2014    Post subject: Reply with quote
You can keep your boots on! Wink
spriddler
PostPosted: 11:18 - 29 Oct 2014    Post subject: Reply with quote
Pardon?
Embarassed
Doovy
PostPosted: 11:24 - 29 Oct 2014    Post subject: Re: Hi from Ninjagirl and a quick question! Reply with quote
Ninjagirl wrote:
Ninjagirl
Pics?
angryjonny
PostPosted: 11:40 - 29 Oct 2014    Post subject: Reply with quote
86.4% Under the seat
8.8% Under the tank
3.1% Behind the headlight
1.2% Inside the rider's over-inflated ego
0.4% Built into the frame
0.1% In the spare wheel well
PostPosted: 11:44 - 29 Oct 2014    Post subject: Reply with quote
Of the 9 bikes that have passed through by household in the last 10 years all of them have battery under the seat. (although the RXS you removed it from the side)
PostPosted: 16:38 - 29 Oct 2014    Post subject: Reply with quote
_Iain_ wrote:
MC wrote:
Mines one of the 1% that has it under the tank Doh!
Had a genuine call from an RAC guy who couldn't find the battery on a ZZR1400 before - least you were able to find it without contacting a main dealer! Laughing
On the GS it's under the "tank", only that's not actually the tank, the tank is under the seat. But the battery isn't.
<Keanu-what-if.jpg>
c-m
PostPosted: 09:36 - 30 Oct 2014    Post subject: Reply with quote
Actually last bike had it under the side cover.
I realise none of this helps the OP...
My last two bikes are the same. The battery is under the right-hand side cover. The fuel tank is under seat which helps lower the cog(when full)
PostPosted: 10:53 - 30 Oct 2014    Post subject: Reply with quote
TL1000R is under one the front fairing at the side somewhere Laughing
Fizzer Thou
PostPosted: 11:37 - 30 Oct 2014    Post subject: Reply with quote
The same as on a Ducati 916/996/998 Wink
Always have a 'Plan B'
Mudshark
PostPosted: 12:39 - 30 Oct 2014    Post subject: Reply with quote
<Keanu-what-if.jpg>
GT tank under seat, battery under "tank" hmm. "battery cover"?
I've been in there to put put 5V usb connector for my tablet, god I'm turning into a right boring old cnut. Can't be all bad yesterday i managed to get a cyclist to shake his head slowly at me for filtering up the (broken white line) cycle lane. Hah I recognised him, he had no clue he knew me.
R1250RS
XT660X
panrider_uk
PostPosted: 13:43 - 30 Oct 2014    Post subject: Reply with quote
All of my bike have had the battery behind a side panel.
On the Pan i've got an accessory socket fitted - Optimate plugs into that.
map
Mr Calendar
PostPosted: 13:50 - 30 Oct 2014    Post subject: Reply with quote
panrider_uk wrote:
...On the Pan i've got an accessory socket fitted - Optimate plugs into that.
So that'd be an always live then, direct to battery.
I've always been reluctant to fit one of those, wary of shorts and/or any water ingress.
The last post was made 11 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.38 - MySQL Queries: 13 - Page Size: 129.37 Kb
