2006 yamaha ybr 125 start problem
djmarcopolo
PostPosted: 19:41 - 03 Nov 2014    Post subject: 2006 yamaha ybr 125 start problem Reply with quote
hi, my ybr has been acting strange recently some days it wont start other days it will, last thing fitted was a new coil about 4 months ago
ive just cleaned the carbs out tonight as it wouldnt start all day put it back on and started first turn and ran perfect, adjust idle slightly to around 1500rpm and it was fine.
turned it off then retried and nothing dead wont kick or anything, just removed the plug and now no spark, tried an old plug and still no spark
with it being intermittent is it likely to be coil again or do i have to search the loom for something or could it be the cdi unit.
I have had a couple of issues with the ignition barrel recently but everything seems to light up as normal when turned on
thanks
keith
YBR Ric
PostPosted: 20:16 - 03 Nov 2014    Post subject: Reply with quote
Worn ignition barrel contacts have been known to cause this type of problem in the past.
The lighting contacts and ignition contacts inside the unit are separate, so it's possible to have a feed to the lights but not to the CDI.
Try turning the ignition on/off and also wiggling the key to move the barrel about and then check for a spark.
djmarcopolo
PostPosted: 21:21 - 03 Nov 2014    Post subject: Reply with quote
thanks for that i have ordered a replacement barrel as it has been intermittent in the past with just getting everything to come onbut hasnt happened for a while
The last post was made 11 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.33 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 34.97 Kb
