New battery but Bike still won't start
astroscope
PostPosted: 09:40 - 05 Nov 2014    Post subject: New battery but Bike still won't start Reply with quote
Good Morning All,
My bike stopped starting up. I've replaced the battery but as I push start, I hear some clicking sound to the rear right hand side.
The bike has an immobilizer. It's the Datatool Series 2. Not sure if that has anything to do with it.
Replaced one of the ignition fuse and still no good.
Any help desperately needed to get the bike home.
2010 Honda FES S Wing 125
PostPosted: 09:57 - 05 Nov 2014    Post subject: Reply with quote
InB4 "push it noob". Is scootay.
Not much to go on there. Kill switch if you have one, side stand cut-off switch, borked starter relay.
Is the new battery fully charged? I mean, do you know that it's fully charged and if so, how?
astroscope
PostPosted: 10:28 - 05 Nov 2014    Post subject: Reply with quote
hi,
yes new battery.
I have been advised to look at starter motor or solenoid. Please show me where this might be. I'll have to open the bike.
thanks
astro
el_oso
PostPosted: 10:36 - 05 Nov 2014    Post subject: Reply with quote
a picture
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 10:51 - 05 Nov 2014    Post subject: Reply with quote
Before you go ripping the tupperware off, how about ruling out the easy stuff first?
"New" does not mean "fully charged".
Did you charge it up before fitting it?
Did you check the voltage on it with a multimeter?
Are your electrics all working normally except for the starter?
astroscope
PostPosted: 11:26 - 05 Nov 2014    Post subject: Reply with quote
ok, will battery with a multimeter.
I did check the old one and the multimeter read 12.4 volt. When i crancked the engine, the volts dropped to 6.3volts.
So i ordered a new battery. I will test this and see what happens.
Monkeypony
PostPosted: 12:07 - 05 Nov 2014    Post subject: Reply with quote
You did remember to put the battery acid into the new battery right?
Not all bike batteries are the sealed variety, and it can be easy to miss the little plastic fluid pack in the packaging.
Current bike - 2018 H2-SX, 2004 SV1000s, 2016 Aprilia RSV4 RF, 2017 Sherco SERF 300, 2003 Suzuki DRZ400 (stolen - AY53 JUU)
astroscope
PostPosted: 12:25 - 05 Nov 2014    Post subject: Reply with quote
well this was the one i bought:
https://i1267.photobucket.com/albums/jj543/astroscope/264A086E-C81F-4DC3-84E6-E22E2E960BF5_zpssyah2zgl.png
spikenipple
PostPosted: 12:44 - 05 Nov 2014    Post subject: Reply with quote
Sounds like a faulty starter solenoid to me.
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
PostPosted: 12:49 - 05 Nov 2014    Post subject: Reply with quote
It does to me too, but fix that and it still won't start if the battery isn't charged.
Loui5D
PostPosted: 14:29 - 05 Nov 2014    Post subject: Reply with quote
Can you bump start it?
temeluchus
PostPosted: 14:44 - 05 Nov 2014    Post subject: Reply with quote
how does one bump start an automatic with a centrifugal clutch?
map
Mr Calendar
FYI as Mr Borg says, a Honda S Wing 125 is a scooter. You can't push start a scooter. Something about centrifugal clutch, no actual gears Rolling Eyes
Loui5D
PostPosted: 14:54 - 05 Nov 2014    Post subject: Reply with quote
oops, should have gone to spec savers.
monkeybiker
PostPosted: 18:18 - 05 Nov 2014    Post subject: Reply with quote
Look up a van and man service to get you home.
kwakkwak6
PostPosted: 13:52 - 06 Nov 2014    Post subject: Reply with quote
if its the starter solenoid. if you bridge out the two connections on the solenoid with a insulated screw driver . if the motor spins over then its the solenoid at fault . however most small bikes have a starter relay instead which you cant fault find unless you know your way around a multimeter.
astroscope
PostPosted: 21:19 - 16 Nov 2014    Post subject: Reply with quote
Thanks for the advice guys, I've managed to get the bike recovered home and have already started to open it. I'm looking at getting that starter motor out. The AA guy suggested getting that changed as all the symptoms seem to be pointing to that.
So far this is the condition of the starter motor.
https://i1267.photobucket.com/albums/jj543/astroscope/7b9cd2d962b616cf9f5d55924bf203c8_zps97dcb9bd.jpg
https://i1267.photobucket.com/albums/jj543/astroscope/a3d1ca3fa7b4096aaa6d10784501f6e3_zpsc39bbb37.jpg
https://i1267.photobucket.com/albums/jj543/astroscope/36dd646e6287411cb3c1284488315e5d_zpsfc87f5f2.jpg
I have taken the starter motor to two mechanics who have attempted to crank it using a 12Volt battery. It sparks but does not turn. They have suggested getting a replacement.
https://i1267.photobucket.com/albums/jj543/astroscope/943a45db7d69ebc684a04a8f7cd35a95_zps8be40b1e.jpg
Gonna be opening this baby up....
talkToTheHat
PostPosted: 06:50 - 17 Nov 2014    Post subject: Reply with quote
open it up, check it out could just be suck or worn out brush. Plenty of brushes and starter motor rebuild kits on ebay. Worse is shorted or open windings, check each coil has the same dc resistance, it should be a low, like a couple of ohms but not quite zero.
Bandit. does. everything.
astroscope
PostPosted: 09:45 - 17 Nov 2014    Post subject: Unveiling!!! Reply with quote
Well it's opened up...
https://i1267.photobucket.com/albums/jj543/astroscope/c4138737619e7fc36b68eb615d9ba067_zps813a0d30.jpg
https://i1267.photobucket.com/albums/jj543/astroscope/508e53e6dfb9624e3ce5ab4079a8fed7_zps2b3df837.jpg
https://i1267.photobucket.com/albums/jj543/astroscope/26fb4a0148ea4c77bacfcd4c883726c9_zps20578481.jpg
One magnet has sheared off!!!
https://i1267.photobucket.com/albums/jj543/astroscope/dc93c1c609977e1e349be7899bdfdd1c_zps2fb12de4.jpg
A crack!
https://i1267.photobucket.com/albums/jj543/astroscope/dd85473348c0cbc0d76eea6c9bd7ae9b_zpsdd71a85f.jpg
astroscope
PostPosted: 09:47 - 17 Nov 2014    Post subject: Recommended length for the brushes Reply with quote
According to Haynes, they recommend the length to be between 10mm-10.5mm for the brushes.
https://i1267.photobucket.com/albums/jj543/astroscope/43dd56150c2ce1da66ff709117445c0b_zps273f380e.jpg
Both brushes are almost 10mm!
Compare that with the new ones I bought from Honda!!!
https://i1267.photobucket.com/albums/jj543/astroscope/6f4d144058fb1a6c37e29797d0985f7e_zps22122a1c.jpg
astroscope
PostPosted: 14:58 - 17 Nov 2014    Post subject: Reply with quote
So guys,
is it worth repairing this starter motor, or do I invest in a whole new starter motor?
These motors are £121 from Honda.
Astro Thumbs Up
map
Mr Calendar
PostPosted: 15:05 - 17 Nov 2014    Post subject: Reply with quote
astroscope wrote:
...is it worth repairing this starter motor...
Can you get all the bits to repair? That magnet bit looks like a non-replaceable item.
astroscope wrote:
These motors are £121 from Honda...
That's quite cheap for a starter motor. Guess depends on the bike.
Have you tried any local (or even national) bike breakers? Would be my first try. At least then use for your new bushes.
astroscope
PostPosted: 15:07 - 17 Nov 2014    Post subject: Reply with quote
Been on the phone to Honda and they have asked me to bring it in to have a look.
astroscope
PostPosted: 15:21 - 17 Nov 2014    Post subject: Reply with quote
Crying or Very sad Crying or Very sad Expensive
WD Forte
PostPosted: 20:07 - 17 Nov 2014    Post subject: Reply with quote
Wouldn't be surpised if that motor is common to quite few other bikes
so a breakers would be my first stop and as said,
you get to use the new brushes too
bikers smell of wee
The last post was made 11 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 130.85 Kb
