Just Failed MOD 1.
DRZ4Hunned
PostPosted: 15:55 - 16 Nov 2014    Post subject: Just Failed MOD 1. Reply with quote
All was going swimmingly on the MT03 until the emergency stop, on the 'practice' lap I was 1mph too slow, so I rolled the throttle on and went for the stop. To my annoyance I must've stamped on the rear brake causing me to lock up the rear for a good few meters, nearly had a foot down on the figure of eight too. Rolling Eyes
On the bright side I 'rode like a demon' on the way to the test centre, so that gives me some hope at least. Re-booked for the 7th now so hopefully it won't happen again. Off to go practice some emergency stops now Thumbs Up
Nash GT
PostPosted: 16:27 - 16 Nov 2014    Post subject: Reply with quote
Try to completely forget about the rear brake until you almost stopped, or just use it progressively.
Also don't fuck about with the gears just concentrate on breaking, stalling the bike is not a fail.
Suzuki GSF600N
Uncle fester
PostPosted: 19:55 - 16 Nov 2014    Post subject: Reply with quote
I failed on my mod 1 ,put my foot down on the bloody slalom, what really annoys me is that I've never put my foot down before. The examiner said it was a shame because I was spot on on everything else with no minors. Nerves I gues,onwards and upwards.
Tomorrows another day .just as we'll at my age
Commuter_Tim
PostPosted: 20:03 - 16 Nov 2014    Post subject: Reply with quote
Unlucky...Mod1 is a joke that should be treated as such anyway, it costs what, £15? just a practice run each time until you pass.
If you can afford to own a bike you can afford that a few times no problem. Thumbs Up
Sounds like you just had test nerves similar to me, except mine made me gun it a bit too much on the Swerve and E-brake, and he gave me a telling off afterwards. Shifty
I ride a Bandit 600... badly.
HughiusMaximu...
PostPosted: 20:21 - 16 Nov 2014    Post subject: Reply with quote
Unlucky.
As already said the front brake will do 95% of the stopping on the emergency stop.
You pretty much just token use the rear brake.
DRZ4Hunned
PostPosted: 20:39 - 16 Nov 2014    Post subject: Reply with quote
I'm treating it as a practice run so hopefully shouldn't be as nervous next time. I wish it was only £15 but I'm using the training school's bike so it works out at £90 including the test fee. Crying or Very sad
kerr
PostPosted: 20:52 - 16 Nov 2014    Post subject: Reply with quote
Just pretend to use the rear brake, don't think i used it at all on the e stop, remember you don't have to stop like your life depends on it, the examiner is just looking for the front forks to compress.
Think of it as a swift stop rahter than an "emergency" stop Thumbs Up
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
Az
PostPosted: 22:34 - 16 Nov 2014    Post subject: Reply with quote
I used an MT-03 for my tests and also failed my Mod 1 for locking up the rear. IIRC the MT had a brembo set up (good brakes) and it's a light bike. It doesn't take much to lock up the rear, especially on the MT-03.
As others have said, just don't use the rear brake at all. I didn't even have my foot on the pedal for my second attempt, so that it wasn't even a possibility for me to press the brake pedal.
Good luck next time Thumbs Up
Vracktal
PostPosted: 22:53 - 16 Nov 2014    Post subject: Reply with quote
I wonder, will the Mod2 still include an emergency stop bit in 2016 once mandatory ABS on motorbikes is in force? Thinking
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
Deathoctimus
PostPosted: 23:54 - 16 Nov 2014    Post subject: Reply with quote
Yean I watched a guy fail his doing the same thing few months ago. I was kind of cringing a bit was a wobbly stop.
slap it in second gear thats all you need for the hole test and like nashgt said stalling is not a problem, best tip I can stay is listen to what your engine sounds like at the correct speed then you can just focus on the stopping part.
Shaun
Current Rides Fireblade 900 RRN / DL1000 past: ZX9R B1 / GSX 600F K3 / YBR125
DRZ4Hunned
PostPosted: 00:28 - 17 Nov 2014    Post subject: Reply with quote
MC wrote:
Still have the estop on the car test even though ABS is fairly standard on most cars (although I know its not a mandatory exercise).
You need hardly any rear brake on the MT-03, the rear does like to lock, and anyway I thought it was standard practice on your mod 1 to only cover the rear brake Smile
What's the MT-03 like for the figure of 8 and u-turn? I would have thought it would be tricky not having much lock.
I was told to use a little back but mainly front but for some reason I did the complete opposite.
The figure of eight nearly threw me when i lost revs and I could feel the bike starting to lean and was about to require a foot down but I managed to get some more power on and lift it back up if that makes sense. U turn was fine. I'd imagine something like a cb500 would be better to learn on though.
I can't work out if I like MT03's or not, I doubt I'd buy one. I find the bike darts off when accelerating, probably user error though. And the vibrations are horrendous.
notbike
PostPosted: 00:35 - 17 Nov 2014    Post subject: Reply with quote
Good luck on your second attempt mate, I got it second time. First time was foot down on the fig of 8 which left me feeling pretty defeated but determined the next time round.
The trick to the E-stop is that you rest your foot on the rear brake without consciously applying any force, the force of braking hard on the front should automatically make your foot apply some pressure to the rear brake by throwing you a little forward in the saddle. At least that's what happened to me anyway.
Whenever I would use the rear consciously it would always lock up cause it's harder to focus on doing two things at once, so if you can avoid that then you're avoiding a potential fail fairly easily by forgetting the rear brake entirely.
deadwolf
PostPosted: 02:06 - 17 Nov 2014    Post subject: Reply with quote
MT-03, £90 test fee...and seeing your location is stated as York, you wouldn't happen to be with Ride 4 Life, out of Strensall? Laughing They're a good bunch, I did my training with them, passed both MODs on the first go, thank fuck for that.
I had a bit of rear-wheel locking during MOD1 practice, this was pointed out and from thenceforth I always made the conscious effort to favour the front brake a lot more during the emergency stop. Rear brake is risky because it's easy to lock up and also doesn't add much to your stopping power, which is a real lose-lose situation so just tap and hold it lightly while you progressively pull in the front brake.
Motorsapien Art
Llama-Farmer
PostPosted: 04:10 - 17 Nov 2014    Post subject: Reply with quote
Just because ABS will be mandatory on new bikes, doesn't mean that all bikes taking the test or being ridden on the roads will be.
ABS is a completely failsafe system. At least in respect to the braking system. By that I mean if it fails, the bike remains safe, you do not lose braking.
All it takes is for a dicky wheel speed sensor or a blown fuse and you've got no ABS, just regular brakes.
IMO it will always be prudent to practice emergency braking whether on the most technologically advanced ABS-equipped anti-dive traction and wheelie controlled bike or on a basic-as-you-like UJM.
ABS on a bike should not cut in on the road under normal (or reasonably expected) conditions. Including if a car infront suddenly brakes.
I've ridden 6 or 7 different bikes with ABS, braked very hard on all of them without having the ABS kick in, half the time in damp conditions as well.
I see it as a safety tool there to help you should you get things wrong, not as a tool to use regularly.
So yes I see it being on the test forever. I think it should be on all driving tests as well, (it might be now, but it wasn't back when I passed mine).
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
PostPosted: 09:53 - 17 Nov 2014    Post subject: Reply with quote
What's a shame is that they don't use their discretion like they do for just about every part of Mod 2.
Dropping the bike is a serious fault. Not dropping it...
dydey90
PostPosted: 10:20 - 17 Nov 2014    Post subject: Reply with quote
I did mine on a bike with ABS, it's just a fail if you trigger it rather than lock it up. They can still see it.
arry
PostPosted: 10:34 - 17 Nov 2014    Post subject: Reply with quote
Is that for real?
PostPosted: 11:51 - 17 Nov 2014    Post subject: Reply with quote
If there's an examiner or instructor out there who thinks that you shouldn't make use of the (soon to be mandatory) equipment fitted to the bike, they need a slap. Laughing
Indicators are too new fangled, make hand signals.
Dave70
PostPosted: 13:54 - 17 Nov 2014    Post subject: Reply with quote
[img]
It's like the old putting your foot down on the U turn. What difference does it make and why should it be a fail?
Stoopid rulez. Folded arms
arry
PostPosted: 14:01 - 17 Nov 2014    Post subject: Reply with quote
that one I mostly agree with. It's not the U Turn that's important per se, it's the control over the bike that is the test.
Llama-Farmer
PostPosted: 14:51 - 17 Nov 2014    Post subject: Reply with quote
But controlling a bike isn't usually that hard, if you're doing it properly.
When I was waiting for my Mod 1 and Mod 2s I was watching the others on the Mod 1 test, and maybe 1 in about 8 people were using their rear brake during slow handling.
It was drilled into me by my instructor to use it, and I found it makes it soooo much easier to control, as well as the fact it makes your turns much tighter. Why only one other person I saw used the back brake I don't know, but the rest of them were wobbling or making much wider turns but no telltale brake light on.
arry
PostPosted: 14:58 - 17 Nov 2014    Post subject: Reply with quote
Me too. And yes, certainly helps.
The last post was made 11 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 135.42 Kb
