| kramdra |
 kramdra World Chat Champion
| UrbanRacer |
 UrbanRacer World Chat Champion
| ripzay |
 ripzay Nitrous Nuisance
| FriendlyEllis |
 FriendlyEllis Spanner Monkey
| anthony_r6 |
 anthony_r6 World Chat Champion
| Polarbear |
 Polarbear Super Spammer
| Minty |
 Minty World Chat Champion
| CaNsA |
 CaNsA Super Spammer
 Posted: 08:54 - 17 Nov 2014 Post subject: |
I bought a set of cheapo levers about 3yrs ago.
Zero kittens have died.
https://www.ebay.co.uk/itm/281031141771?clk_rvr_id=732305189019
The black has faded slightly, but it's not that noticeable.
inb4 "didnt someone buy some then crashed when the front wheel locked up"
Yes someone did, but they were the wrong levers, he knew they were the wrong levers but he fitted them anyway. |
| Matt B |
 Matt B World Chat Champion
| Ben90 |
 Ben90 Brolly Dolly
 Posted: 13:09 - 17 Nov 2014 Post subject: |
I bought the £30 ones for my fz6, good quality levers. Makes you wonder where the extra £100 goes when you buy branded ones
You can also choose the colour of the levers and the adjuster.  ____________________ Yamaha FZ6 S2 |
| stonesie |
 stonesie World Chat Champion
 Posted: 13:18 - 17 Nov 2014 Post subject: |
From what I have read over the years the cheap Chinese levers are okay on bikes with conventional master cylinders, it's on radial master cylinders that they can have problems with not having a deep enough recess for the pushrod and holding the brakes on a fraction. My STR has radial brakes so I ended up getting the Triumph levers.
As for fit and finish, I had some on the old SV and after 15K miles of use they still looked perfect, they were more expensive for Chinese levers and had ball bearings in the adjuster mechanism rather than the more basic sets.
https://www.ebay.co.uk/itm/Honda-CBR600-F2-F3-F4-F4i-CNC-00-01-98-99-Racing-Adjustable-Brake-Clutch-Levers-/290999210188?pt=UK_Motorcycle_Parts_13&hash=item43c0e790cc
I'm pretty sure it was this company, they're not as shiny and bright as most other levers. |
| kramdra |
 Posted: 14:02 - 17 Nov 2014 Post subject: |
Piston clearance should always be checked and adjusted with new levers I know of several reports with idiots crashing where they have not.
Interested to know if RR models are compatable with F4i? Tho I will be buying F4i ones. RR has a lot more choice for ebay tat.
Thanks for the links  |
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| Ol |
 Ol World Chat Champion
 Posted: 15:25 - 17 Nov 2014 Post subject: |
Had a set on my old SV and SRAD - worked fine, looked ok - cant complain.
Sent the SV down the road too with them on and they didn't break or anything  ____________________ Previous: Cub50, NRG50, TS50, YB100, CB125, NSR125, ZZR600, CBF1000, SV650s, ZX6R B1H, XT250, Mito Powered Crosser, WRF450, , FZ600, VN800, GSXR600 - Currently CB1000R |
| Ed Case |
 Ed Case World Chat Champion
| kramdra |
 Posted: 01:16 - 02 Dec 2014 Post subject: |
Update, for anyone interested. I decided on the cheapest, £14.50 ones from here https://www.ebay.co.uk/itm/301412270012
Arrived today and fitted just now, in the dark at 11pm they appear to be excellent, good finish well made CNC levers However I wanted short levers, these are very nearly the same length as OEM. I'd have liked the adjuster to stick out less and another inch off the total length.
Fitting - as expected there was zero.. perhaps even negative clearance on the master cylinder piston (and this was what I hoped, guessing they fit many bikes, material can be removed but not put back). OEM levers had about 0.3mm clearance and so I modified these to fit.
Not the best pic (greasy from test fitting) but it shows how much I removed, about ~1mm to get the required clearance:
https://i1133.photobucket.com/albums/m593/Kramdra/Cbr600/IMG_20141201_231955_zpsc515ede8.jpg
Recommend. If anyone knows of a shorter/more compact pair of levers I will put these on the other bike and get more. |
| Ed Case |
 Posted: 17:18 - 02 Dec 2014 Post subject: |
£14.50 ?, you skinflint, undercut me, wish I'd seen 'em, could've saved meself £1.50 !  |
| stonesie |
| RE8ELD0G |
 RE8ELD0G Renault 5 Driver
| Nash GT |
 Nash GT World Chat Champion
| Polarbear |
| kramdra |
| Cyclingbiker |
 Cyclingbiker Spanner Monkey
| mattyfattyboo... |
 mattyfattyboo... Scooby Slapper
The last post was made 11 years, 212 days ago. Instead of replying here, would creating a new thread be more useful? |
