| Pete. |
 Pete. Super Spammer
 Posted: 01:39 - 20 Nov 2014 Post subject: Chinese digital clocks on my Bandit |
I bought these clocks and set about fitting them to my Mk2 Bandit 600. Since the bike already has an electronic sensor for the speed running off the front sprocket I thought I'd try to incorporate that with the clocks and avoid having an ugly sensor on the front forks.
Well, using this wiring diagram I did it. All you need to do is feed 12v into the speed sensor by linking it to the switched live in the clocks loom, then put a 100ohm resistor on the pink wire and connect that to the trigger wire for the new clocks and it will do the same job as the hall-effect sensor. I have set the pulse to 8 and the circumference to 1400 and it reads a little high but I'll calibrate that in using a GPS on the road. Even better yet the stock Mk2 clocks bracket is drillable to take the original grommets so the clocks can be rubber-mounted with ease.
Everything works, all the wally lights, rev counter, speedo, fuel gauge the whole lot. Here's the wiring diagram for a Mk2 bandit K4:
https://peterrimmer.myby.co.uk/images/mk2bandit_chinaclocks.jpg
Clocks fitted to bracket. I know the cutting is a bit rough but I got work in the morning so had a hurry on.
https://peterrimmer.myby.co.uk/images/clockinstall1.jpg
https://peterrimmer.myby.co.uk/images/clockinstall2.jpg
Lots of Suzukis use this same sensor for the speedo and this lets you use it to drive these clocks. Happily the fuel gauge resistance is a perfect match, so I guess that 10ohms full, 90 ohms empty must be a common value for the fuel gauge too. ____________________ a.k.a 'Geri'
132.9mph off and walked away. Gear is good, gear is good, gear is very very good
| cormac83 |
 cormac83 Nova Slayer
 Posted: 14:52 - 20 Nov 2014 Post subject: |
Nice, might have to give this a go myself. Generally electrics scare me so cheers for the diagram  ____________________ Suzuki GSX750 Inazuma |
| jjdugen |
 jjdugen World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 17:39 - 20 Nov 2014 Post subject: |
Mine also has the gear position wires but not used on the Bandit, nor the water temp light. I use the 'EFI' wire for oil light, it's just an engine fault symbol but it does the job.
One big benefit of doing this conversion on a Bandit is that the stock clocks if they are in good condition will sell for much more than you'll pay for the Chinese ones. ____________________ a.k.a 'Geri'
| BillyJ |
 BillyJ Nearly there...
| Pete. |
 Pete. Super Spammer
| BillyJ |
 Posted: 23:21 - 20 Nov 2014 Post subject: |
2002...
Thanks for the info anyway My tank is the only thing that could do with replacing so I will keep that in mind if it comes to it.
EDIT:
I just looked at how it displays fuel info... if I had a tank from a 2002+ bike, I'm guessing the fuel display wasn't in the firmware of the 2001 bikes and therefore it wouldn't be able to show anything?
I'm gonna do more guessing and assume there isn't even a place to plug the sensor lines into? ____________________ Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser" |
| Pete. |
 Pete. Super Spammer
 Posted: 23:29 - 20 Nov 2014 Post subject: |
Not on the original clocks no, but all you would do is run a wire to ground and a wire to the fuel gauge input on the chinky clocks and it will work. ____________________ a.k.a 'Geri'
| BillyJ |
| WD Forte |
 WD Forte World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 07:22 - 21 Nov 2014 Post subject: |
I don't think you'll find many digital tachos because the revs can rise so much faster than mph. You'll either get a blur of figures or big jumps in the numbers displayed. ____________________ a.k.a 'Geri'
| Polarbear |
 Polarbear Super Spammer
| WD Forte |
There is a gap of 4 years, 349 days between these two posts... |
| Painko |
 Painko L Plate Warrior
| Pete. |
 Pete. Super Spammer
 Posted: 00:49 - 05 Nov 2019 Post subject: |
I've attached the pics. Couldn't put them inline but you'll figure it out. ____________________ a.k.a 'Geri'
The last post was made 6 years, 236 days ago. Instead of replying here, would creating a new thread be more useful? |
