| stevenc370 |
 stevenc370 Two Stroke Sniffer
 Posted: 20:15 - 20 Nov 2014 Post subject: Won't start after cutting out |
hi can anyone help I have a suzuki gp100 that I'm trying to get back on the road but its not playing nice.
Right so when I got it all the wiring was knackered but it ran great, well it ran so I start to sort out the wiring put an ignition in still ran the same. Then got onto the headlight plugged it in started it all the same turn the headlamp on and it dies slowly and won't start again.
I have removed the plug which was wet so cleaned that up and left overnight with plug out then it starts but still same problem when I turn the light on.
Next day ripped apart the carb cleaned everything checked float heights etc etc plumbed it back together started first time left idling got it up to temp set the idle slightly high turn the light same thing won't start again.
I can't thinkeep why Ithe won't start I get that the light van draw to much power but why not start when the light is turned off |
| CG Sam |
 CG Sam Crazy Courier
| stevenc370 |
| UncleFester |
 UncleFester World Chat Champion
| stevenc370 |
| CG Sam |
| stevenc370 |
| CG Sam |
| bypass2 |
 bypass2 Spanner Monkey
The last post was made 11 years, 63 days ago. Instead of replying here, would creating a new thread be more useful? |
