Help-Help-Help
Bob Pattinson
PostPosted: 16:33 - 23 Nov 2014    Post subject: Help-Help-Help Reply with quote
Problem;
Henson 110 Quad, New battery, New CDI, New plug, lead and coil - Still no spark. Engine turning no problem but not firing - Any suggestion?????
Bob Pattinson
Islander
PostPosted: 16:36 - 23 Nov 2014    Post subject: Reply with quote
Is there a kill switch? If so, is it on?
Bob Pattinson
PostPosted: 16:41 - 23 Nov 2014    Post subject: Reply with quote
Kill switch is off, engine will not turn over at all when kill switch is on, head done in
Bob Pattinson
robocog
PostPosted: 22:18 - 23 Nov 2014    Post subject: Reply with quote
Pickup coil that goes to the CDI packed up?
(or wiring unplugged)?
Regards
Rob
Needs a bigger garage...
Nemo
PostPosted: 22:22 - 23 Nov 2014    Post subject: Reply with quote
Change due to seeing your post (it came up tiny on my phone).
Best thing I can suggest is find a wiring diagram, isolate the part of the diagram you need, then work from that.
Have you changed the plug cap? Some have a resistor and stop spark when they go bad.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
PostPosted: 10:37 - 24 Nov 2014    Post subject: Reply with quote
Your CDI, does it have red/black, blue.black, black/white, green and yellow?
If so, green to earth, yellow to coil, blue and red to stator, white/black leave disconnected. Ground it to kill the spark.
Islander
PostPosted: 12:15 - 24 Nov 2014    Post subject: Reply with quote
This. Get a service manual with a decent wiring diagram and if you don't have one, buy a multimeter. Check all of the relevant connections including earths - the service manual will give you the resistances needed to check pickup coils and ignition coils. Use the multimeter to check continuity and voltages.
WD Forte
PostPosted: 15:40 - 24 Nov 2014    Post subject: Reply with quote
Never heard of a Henson so googled it
I did find a 'Hensim' 110cc ATV
this one?
https://www.extrememotorsales.com/Hensim_Utility_110cc_Kids_ATV.htm
Assuming the new stuff is AOK
I'd start by disconnecting the kill switch wire from the cdi and test the pulser coils
bikers smell of wee
WD Forte
PostPosted: 15:50 - 24 Nov 2014    Post subject: Reply with quote
Found this for a Hensim 150cc and assuming they don't vary much
in wiring
would disconnect the black/white in case the kill switch is shorting to ground
and then measure the resistance between both the
black/red then blue/white to ground.
I'll guess at circa 300 ohms? as its an AC CDI
If its say 2 ohms or Megaohms then it may be knackered
followed by an AC voltage check when the engine is being cranked
again guess at say 100VAC?
EDIT:
Just noticed the diagram, has test resistances and voltages
at the top so there ya go !
https://i397.photobucket.com/albums/pp60/LynnEdwards_photo/QuadSchematic1.jpg
bikers smell of wee
WD Forte
PostPosted: 15:56 - 24 Nov 2014    Post subject: Reply with quote
Iain
Agree, I once had to sort out a Honda quad the kids had got at
It looked like the wee feckers has been chewing the wires
and any bike in the toy/fun dept is often cruelly abused.
bikers smell of wee
The last post was made 11 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 69.24 Kb
