ARSE
Skudd
PostPosted: 17:08 - 23 Nov 2014    Post subject: ARSE Reply with quote
Oh FFFFFFFFFFFFFFFFFFFFFFFFFUUUUUUUUUUUUCCCCCCCCKKKKKKKKKKKKK
How can a small job be such a arse ache.
Rear brake had seized slightly. No problem, just take it apart, give it a clean a bit of lube an put back together.
Only problem was it was a sliding pin that had seized, no problem really, just a bit of penetrating oil and a quick fiddle, it should all come apart.
NO Fuckety NO!!!!
Sliding bit snapped off inside the calliper holder.
No problem, small pilot hol down the middle, stud extractor gizmo and jobs a good one.
Hell fuck no!
Thing is welded in like a welded in thing to 1000th of an inch.
No problem, jus=tm make the hole bigger until the slider becomes loose or is no longer there.
Sound good, this I started to do. realise that the pilot hole wasn't as central as it could be so being careful do it bit by bit. But my box of drill bits are at the stables and I'm on nights so finish too early to go to the stables but need sleep before stables open.
So carry on with the few bits I have. Drilling tired is not the best way, but you do what you can.
Today was my day off, watched the F1 and then went to work on the bike.
Bloody drill bit snapped in the hole now.
Cant get the thing onto the work bench because I can't get the bloody ABS sensor off as that has welded itself inside it's mounting so everything has to be done on a cold floor attached to the bike under a carport with a gale blowing.
A 30 minute job now has taken a week and still no nearer finishing it.
Looks like a chewed up mangle bit of scrap at the moment.
PostPosted: 17:11 - 23 Nov 2014    Post subject: Reply with quote
Remove caliper, vice, slide pin punch and a hammer.
Skudd
PostPosted: 17:19 - 23 Nov 2014    Post subject: Reply with quote
Issue getting calliper off already done the punch and hammer thing to break the corrosion seal. Also it is encased so can't punch it from the other side, hence the drilling.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:34 - 23 Nov 2014    Post subject: Reply with quote
Ebay is your friend = buy another calliper...
Triumph Sprint ST 1050
Skudd
PostPosted: 17:43 - 23 Nov 2014    Post subject: Reply with quote
No it isn't as there aren't any on there.
PostPosted: 18:44 - 23 Nov 2014    Post subject: Reply with quote
Herp le derp mah shlurp?
https://www.ebay.co.uk/itm/HONDA-XL1000-V-XL-1000-V-VARADERO-REAR-CALIPER-ABS-YEAR-2007-/161178837991?pt=UK_Motorcycle_Parts_13&hash=item258701e3e7
https://www.ebay.co.uk/itm/Honda-Varadero-XL1000-year-2000-REAR-BRAKE-CALIPER-/271669284883?pt=UK_Motorcycle_Parts_13&hash=item3f40c05013
https://www.ebay.co.uk/itm/HONDA-VARADERO-1000-2003-REAR-CALIPER-BRACKET-/261555590481?pt=UK_Motorcycle_Parts_13&hash=item3ce5ed9551
Skudd
PostPosted: 21:59 - 23 Nov 2014    Post subject: Reply with quote
Paddy. wrote:
Well I never.................. been looking and missed this one, although I just need the bracket. Nice find. The other two aren't suitable.
I will try again tomorrow and then it is HAMMER time and then credit card time. Thumbs Up
Skudd
PostPosted: 01:51 - 27 Nov 2014    Post subject: Reply with quote
Well after a long search for just the bracket I have drawn a blank. Tried drilling out further but knackered the calliper so it is new calliper time. Apparently it is a known fault and that is why the brackets are so rare.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:38 - 27 Nov 2014    Post subject: Reply with quote
Commiserations, mate. It's always a complete cunt to ruin a perfectly servicable bit of kit due to a crap bolt.
PostPosted: 20:10 - 27 Nov 2014    Post subject: Reply with quote
Co-incidentally...
We can fake landing a man on the moon, so how chuffing hard can it be to design a sliding pin that actually slides? You could lick your dinner off my caliper, it's only seen a couple of wet days, and yet... seized solid. Mad
Skudd
PostPosted: 20:58 - 27 Nov 2014    Post subject: Reply with quote
Picking up the bracket tomorrow. Strange but a Honda dealer could do the part cheaper than all the so called cheap places.
SofaBear
PostPosted: 21:27 - 27 Nov 2014    Post subject: Reply with quote
I hate it when stuff like that happens.
Remember trying to drain the oil out of my old mondeo ST24. got underneath and in two seconds rounded the fucking bolt off. 30 minute job turned into 2 week job trying to find somewhere and the time to get the fecking thing off. angle grinder, 4 foot breaker bar and a broken sump later ...
Nobby the Bastard
Harley Gaydar
PostPosted: 21:32 - 27 Nov 2014    Post subject: Reply with quote
If it makes you feel any better, I know why the FZR was so cheap.
The starter sprag clutch is fucked. This wouldn't be so much of an issue but it's nestled in the middle of the gear box...
PostPosted: 21:38 - 27 Nov 2014    Post subject: Reply with quote
You can't start, we can't stop, let's call the whole thing off.
The last post was made 11 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 82.59 Kb
