TRIDENT CARB TUNE /set up
TRIDENT WIGAN
PostPosted: 14:58 - 23 Nov 2014    Post subject: TRIDENT CARB TUNE /set up Reply with quote
HELLO EVERONE !!!
I have a trident it's only been riden short journeys and has had a new set or carbs on it
The plugs are realy black ,running rich ,there's no air box just bell mouths. My question is does any one know a good bloke or dealer that would fettle this issue for me ?? Jetting and tuning ?? I'm in wigan northwest eng
ANY INFO WOULD BE FAB
Bezzer
PostPosted: 15:50 - 23 Nov 2014    Post subject: Reply with quote
What Triden it is would help, T150, T160 or a Hinckley one? The older ones are better off with someone who knows them as they can be awkward.
TRIDENT WIGAN
PostPosted: 17:14 - 23 Nov 2014    Post subject: Reply with quote
Hi it's a t150 1972 !! I've just had a tinker with it checked the mixture screws and they were only about a turn out from seated ! I turned em back in and then 2 .5 turns out as recommended then cleaned the plugs and it's made a lot of difference ! I'll ride it a bit then check colour of the plugs again.
When I get it right I'll put new plugs in ! Would like an experienced bloke set it up REALY to get the best out off it !!!
Can't believe how nice it is to ride!!! Thanks for your reply
Triton Thrasher
PostPosted: 17:16 - 23 Nov 2014    Post subject: Reply with quote
Get thee to www.triplesonline.com
They can tell you what's what.
Rrrrrrrrrrrrrrrrrr
jjdugen
PostPosted: 19:11 - 23 Nov 2014    Post subject: Reply with quote
Amal concentrics are notorious for wearing, even at low mileage. You might need to replace with modern manufactured devices.
Triton Thrasher
PostPosted: 19:54 - 23 Nov 2014    Post subject: Reply with quote
That really is for experts. People spend literally years adjusting Mikunis on old Triumphs.
Rrrrrrrrrrrrrrrrrr
Triton Thrasher
PostPosted: 19:55 - 23 Nov 2014    Post subject: Reply with quote
The idle mixture screws should be set for best mixture, rather to a pre-decided number of turns.
Rrrrrrrrrrrrrrrrrr
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
TRIDENT WIGAN
PostPosted: 11:35 - 24 Nov 2014    Post subject: Ok then what carbs are recommended ?? N a rough cost Reply with quote
TRIDENT WIGAN
PostPosted: 11:36 - 24 Nov 2014    Post subject: Reply with quote
OK FOLKS WHICH CARBS WOULD BE A GOOD REPLACEMENT
PostPosted: 13:48 - 24 Nov 2014    Post subject: Reply with quote
Can't speak for the T150, but the T120 I recently worked it was recommended to use an Amal Monobloc. A bit different mind as mine only had 1 carb to your 3!
Triton Thrasher
PostPosted: 14:03 - 24 Nov 2014    Post subject: Reply with quote
There can't be room for three normal Monoblocs.
Rrrrrrrrrrrrrrrrrr
TRIDENT WIGAN
PostPosted: 08:59 - 25 Nov 2014    Post subject: Reply with quote
I shall sort it myself ,then I've only me to blame
Would have been nice if I'd had a starting point though ,ie someone who dad a similar set up
TRIDENT WIGAN
PostPosted: 19:44 - 01 Dec 2014    Post subject: Reply with quote
Sorted thanks folk I did it myself on inspection the carb on the righ ,nearest kick start was stuck halfway open ,a result of old petrol me thinks
The last post was made 11 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 79.04 Kb
