Fogging on top of pinlock
SteveSmith
PostPosted: 15:06 - 24 Nov 2014    Post subject: Fogging on top of pinlock Reply with quote
Hi, I've tried searching for this but can't find anything similar so sorry if this has been done before.
I have a Shoei GT-Air with a pinlock insert, bought new this September. In cold or wet weather it fogs up in a specific spot, at the bottom of the pinlock under my right eye, then spreads out from there.
I've had it before where they fog up between the pinlock and the visor, and solved that by tightening it up. This time though it's fogging on the surface of the pinlock itself - you can wipe it off with a finger.
Any ideas on how to stop it? Is there some sort of treatment or maintenance that I need to do on the pinlock?
Thanks,
Steve.
PostPosted: 15:49 - 24 Nov 2014    Post subject: Reply with quote
I too thought I had this problem. I tore off and threw my insert away while travelling along the A1 one winters night, (about 35 miles after having bought it fitted to a brand new visor) as it was making things worse to the point I couldn't see with oncoming traffic in the dark
Apparently I was imagining it because pinlock inserts are the best thing ever invented and work infallably all the time. I must have been breathing wrong or something.
Kierran
PostPosted: 15:53 - 24 Nov 2014    Post subject: Reply with quote
Mines does the same after 2 years of use. I just removed it wiped it down with a dry cloth, left it to dry out. I then gave the visor a good clean then put them back together and re tightened the two bolts. Not had a problem since
Im not driving too fast, Im flying too low!
Current Bike - GSXR 750 K5
Current Car - BMW 318i
Knacker
PostPosted: 16:44 - 24 Nov 2014    Post subject: Reply with quote
Not sure if it's just a Shoei thing but my Arai pinlock has been on for 5 years and never had an issue.
I'd imagine its just fitted incorrectly.
Previous: K1 GSXR 1000
PostPosted: 16:47 - 24 Nov 2014    Post subject: Reply with quote
Sold as not fogging up. Fogged up within 30 minutes of trying it. Can't see where the fuck I'm going at 100mph on a motorway. GTFO expensive bit of crappy plastic.
Motorcycle visors and all accessories to do with them must be the least fit for purpose products ever invented. They only work for the purposes of seeing out while not being battered in the face by objects/droplets/cold when none of those things are present.
I've spent more money that I'd care to think of on visors, inserts, gloops, potions and sprays that profess to stop fogging over the years. None perform any better than wiping spit on the inside, which is something that works only marginally better than nothing at all.
The only thing I've seen that works is an electrically heated snowmobile visor which is a) Not road legal and b) Not sold in the UK .
I just wear safety glasses and ride with the visor permanantly cracked open these days
esullivan
PostPosted: 16:52 - 24 Nov 2014    Post subject: Re: Fogging on top of pinlock Reply with quote
Thanks,
Steve.
I have the same lid and was having a similar problem (different spot fogging). The solution was to make sure that the pinlock doesn't have any gaps. It should be in contact with the visor all the way around, like double-glazing.
If there are any gaps, try carefully turning the pins on the sides using needle nose pliers. They are eccentrically shaped, so you only need to turn them a little bit to press the pinlock more securely against the visor. You will need to take the visor off to do this. Don't try to do with the visor still attached to the lid.
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
fatjames
PostPosted: 16:54 - 24 Nov 2014    Post subject: Reply with quote
I've only been riding a few years but have never had an issue with pinlock inserts. I heard a while ago that they do expire and need replacing, but none of mine have ever needed replacing due to wear.
Have a really good look at it and clean it. As said, let it dry properly. Is it scratched or anything like that?
Llama-Farmer
PostPosted: 18:09 - 24 Nov 2014    Post subject: Reply with quote
I have a similar problem on my pinlock and usually take it out, clean with visor cleaner and it is fine again for a few days use.
It really absolutely doesn't fit the visor properly though. It's an LS2 helmet. And no matter how the pins are adjusted, the pinlock will not make a complete seal around the visor, it seals up 90% of it but theres always a gap of about 1-2cm in the middle, either at the top or bottom.
I guess thats what happens with cheap helmets though, not ever had a problem with a Shoei, AGV or HJC.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
PostPosted: 18:16 - 24 Nov 2014    Post subject: Reply with quote
It's because it needs adjusting I'm with Iain on this. If it is adjusted correctly and sealed all the way round it will not do what you describe.
Stinkwheel, you could have fixed that issue in less than 5 minutes and with no tools. throwing it away is like scraping a bike because you have to adjust the chain. You just have to adjust the posts and make sure the seal is made all the way round. Every now and then I have to do it again but it is no bother. I've had many pinlocks on 3 different helmets, I think I have replaced 2 in about 7 years because they seemed to have worn out (seals gone).
PostPosted: 18:17 - 24 Nov 2014    Post subject: Reply with quote
Did you fit the pins yourself?
If not have you got the right pinlock insert?
loxilane
PostPosted: 18:21 - 24 Nov 2014    Post subject: Reply with quote
Maybe you just have a hot, sweaty face. Try sticking the pinlock over that rather than the visor Razz
iooi
PostPosted: 18:46 - 24 Nov 2014    Post subject: Reply with quote
Is a car windscreen any different ????
Oh that would be a NO as you need wipers & a heater to make sure that you can see through it.... Laughing
iooi
PostPosted: 18:53 - 24 Nov 2014    Post subject: Re: Fogging on top of pinlock Reply with quote
esullivan wrote:
The solution was to make sure that the pinlock doesn't have any gaps. It should be in contact with the visor all the way around, like double-glazing. .
Double glazing works by the fact that there is a void (airless) between the 2 panes of glass. which allows the cold hitting the outside and the warm of the inside not cause condensation on the surface.
Put 2 panes of glass next to each other and you will have a steamed up surface....
esullivan
PostPosted: 19:31 - 24 Nov 2014    Post subject: Re: Fogging on top of pinlock Reply with quote
iooi wrote:
Double glazing works by the fact that there is a void (airless) between the 2 panes of glass....
Yes, I know. I meant no gaps around the edges, but worded that incorrectly.
That said, pinlock isn't magic. On exceptionally cold and wet days (a handful of times a year), mine has fogged up a bit. Nothing like as foggy as the part of the visor not covered by the insert, but still misty. .
PostPosted: 21:00 - 24 Nov 2014    Post subject: Reply with quote
So you're saying that having a seal all round the insert prevents fog forming on the inside surface of the insert. For clarity, that being the surface closest to my face?
instigator
PostPosted: 23:22 - 24 Nov 2014    Post subject: Reply with quote
Do you think perhaps you were just unlucky? I have my first lid in 12 years now that takes pinlock and it works amazingly well. I always rode with my visor cracked open and it's no longer necessary. You also curse scottoilers as well (iirc) yet my current one is absolutely magic. Infact, all of my scottoilers have been! And I'm sure you're not just a more demanding person.
Dave70
PostPosted: 23:37 - 24 Nov 2014    Post subject: Reply with quote
Personally, I wouldn't be without a pinlock at this time of year.
I've tried a few other "gadgets" from anti-fog sprays, washing up liquid and some other thing that sticks onto your visor, that I can't remember the name of right now. All had varying degrees of success but, none of them came close to being as good as the pinlock.
Sometimes, when it's particularly cold, I can experience a little bit of misting at the very bottom of the visor/pinlock but, nothing that impairs my vision, as it's below my line of sight.
Llama-Farmer
PostPosted: 02:08 - 25 Nov 2014    Post subject: Reply with quote
Whether the fit is perfect or not is irrelevant if it is fogging up on the pinlock surface that is not sealed to the visor but on the other side, i.e. closest to your face. A perfect seal would not prevent that and an imperfect seal would not cause it.
Not initially no, the shop did. And it was definitely the correct pinlock.
But it misted up and got water down between the visor and pinlock. After taking it out to clean and refit I snapped one of the pins so had to replace it and refit myself, and still haven't managed to get a perfect seal. Nor has the shop when I took it back to get them to try.
I just came to the conclusion that the correct insert just doesn't fit properly.
It's already like looking through a letterbox... can just about see the pins in my peripheral vision, but can clearly see the top and bottom of the pinlock with very noticeable lines right in the line of sight.
My Shoei on the other hand you cannot see at all any of the edge of the pinlock, its like its not even there.
Nash GT
PostPosted: 04:28 - 25 Nov 2014    Post subject: Reply with quote
I've had a similar problem with my scorpion helmet, 1months old shop fitted the pin lock for me, if fogs up in the wet an cold.
Suzuki GSF600N
PostPosted: 10:43 - 25 Nov 2014    Post subject: Reply with quote
Nope. I'm fine with scotoilers. They don't work well on my bike though because of the way the sprocket attaches (studs are within a few mm of the edge of the sprocket and tend to rip the delivery spout out). I'm not so keen on their prices.
SteveSmith
PostPosted: 10:57 - 25 Nov 2014    Post subject: Reply with quote
Thanks. I knew that was the case if it was fogging between the pinlock and the visor, but in this case the fogging is on the "outside" surface of the pinlock, i.e. the inside of the helmet, nearest to my face.
As far as I can tell visually the seal looks good, and it isn't fogging up on the inside, just the outer surface.
Steve.
RedPanda
PostPosted: 11:21 - 25 Nov 2014    Post subject: Reply with quote
Until this thread I didn’t even know what a pinlock visor was, turns out my AGV came with one. My ride into work was a lot easier today so thanks for that.
CBF125 (2013) -> CBR600F (2001) -> 'Ninja' 300 (2014)
iooi
PostPosted: 12:36 - 25 Nov 2014    Post subject: Reply with quote
Steve.
While pinlocks are good, they will not stop all misting up. there bonus is it clears a lot quicker than a visor without one.
Do you have a buff or such over your nose?
Strange but true fact that keeping nose clear helps to reduce misting.
PostPosted: 12:39 - 25 Nov 2014    Post subject: Reply with quote
Had pinlocks in three different helmets and ham fistedly fitted a fair few in my time. Never had an issues with them. They've worked amazingly well for me. Maybe I have the magic touch?
The last post was made 11 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 139.16 Kb
