| SteveSmith |
 SteveSmith Nitrous Nuisance
 Posted: 15:49 - 24 Nov 2014 Post subject: |
I too thought I had this problem. I tore off and threw my insert away while travelling along the A1 one winters night, (about 35 miles after having bought it fitted to a brand new visor) as it was making things worse to the point I couldn't see with oncoming traffic in the dark
Apparently I was imagining it because pinlock inserts are the best thing ever invented and work infallably all the time. I must have been breathing wrong or something. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kierran |
 Kierran Trackday Trickster
| _Iain_ |
 _Iain_ Banned
 Posted: 16:29 - 24 Nov 2014 Post subject: |
If it's externally fogging then I belive they're coated with the same sort of anti fog layer that you find on a normal visor. In which case, remove, warm water to clean it and it'll likely sort it. If it doesn't I'd consider replacement or application of a fog spray - Bob Heath stuff in pump form (not aerosol) is superb.
Internal fogging is due to seal leaking and usually fixed by adjustment & cleaning.
I do however think it's pretty foolish to have a temper tantrum and throw one away then have a rage on the internet because of such things. They are after all an item that'll cost as much as £40 so surely worth at least attempting a fix as they may have been wrongly installed by the seller, and manufacturing defects do happen with pretty much anything. ____________________ Please be aware that the above post may be full of complete nonsense.
| Knacker |
 Knacker World Chat Champion
 Posted: 16:47 - 24 Nov 2014 Post subject: |
Sold as not fogging up. Fogged up within 30 minutes of trying it. Can't see where the fuck I'm going at 100mph on a motorway. GTFO expensive bit of crappy plastic.
Motorcycle visors and all accessories to do with them must be the least fit for purpose products ever invented. They only work for the purposes of seeing out while not being battered in the face by objects/droplets/cold when none of those things are present.
I've spent more money that I'd care to think of on visors, inserts, gloops, potions and sprays that profess to stop fogging over the years. None perform any better than wiping spit on the inside, which is something that works only marginally better than nothing at all.
The only thing I've seen that works is an electrically heated snowmobile visor which is a) Not road legal and b) Not sold in the UK .
I just wear safety glasses and ride with the visor permanantly cracked open these days ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| esullivan |
 esullivan Could Be A Chat Bot
 Posted: 16:52 - 24 Nov 2014 Post subject: Re: Fogging on top of pinlock |
| SteveSmith wrote: | Hi, I've tried searching for this but can't find anything similar so sorry if this has been done before.
I have a Shoei GT-Air with a pinlock insert, bought new this September. In cold or wet weather it fogs up in a specific spot, at the bottom of the pinlock under my right eye, then spreads out from there.
I've had it before where they fog up between the pinlock and the visor, and solved that by tightening it up. This time though it's fogging on the surface of the pinlock itself - you can wipe it off with a finger.
Any ideas on how to stop it? Is there some sort of treatment or maintenance that I need to do on the pinlock?
Thanks,
Steve. |
I have the same lid and was having a similar problem (different spot fogging). The solution was to make sure that the pinlock doesn't have any gaps. It should be in contact with the visor all the way around, like double-glazing.
If there are any gaps, try carefully turning the pins on the sides using needle nose pliers. They are eccentrically shaped, so you only need to turn them a little bit to press the pinlock more securely against the visor. You will need to take the visor off to do this. Don't try to do with the visor still attached to the lid. ____________________ Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125. |
| fatjames |
 fatjames World Chat Champion
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| chris-red |
| chris-red |
| loxilane |
 loxilane L Plate Warrior
| iooi |
 iooi Super Spammer
| iooi |
 iooi Super Spammer
| esullivan |
| instigator |
 instigator Super Spammer
| Dave70 |
 Dave70 World Chat Champion
 Posted: 23:37 - 24 Nov 2014 Post subject: |
Personally, I wouldn't be without a pinlock at this time of year.
I've tried a few other "gadgets" from anti-fog sprays, washing up liquid and some other thing that sticks onto your visor, that I can't remember the name of right now. All had varying degrees of success but, none of them came close to being as good as the pinlock.
Sometimes, when it's particularly cold, I can experience a little bit of misting at the very bottom of the visor/pinlock but, nothing that impairs my vision, as it's below my line of sight. ____________________ There ain't no devil, there's just god when he's drunk.
2012: R125 killed by white van. 2016 R125 killed by 30,000 miles of redline. Current: 2016 Kawasaki ER6f. |
| Llama-Farmer |
| Nash GT |
 Nash GT World Chat Champion
| SteveSmith |
| RedPanda |
 RedPanda Could Be A Chat Bot
| iooi |
 iooi Super Spammer
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 12:39 - 25 Nov 2014 Post subject: |
Had pinlocks in three different helmets and ham fistedly fitted a fair few in my time. Never had an issues with them. They've worked amazingly well for me. Maybe I have the magic touch? ____________________ My Flickr |
The last post was made 11 years, 266 days ago. Instead of replying here, would creating a new thread be more useful? |
