| ColdKill |
 ColdKill Derestricted Danger
| iooi |
 iooi Super Spammer
 Posted: 10:35 - 24 Nov 2014 Post subject: |
White smoke is just condensation turned into steam (its got warm).... Not a problem at all.
Just look at cars stood at traffic lights and see exactly the same effect.
What you might have done is flooded it a bit leaving the choke on.
DO NOT WORRY
South west cold and frosty?????? They keep telling us it's just wet and warm....
Still not had any frosty temps up in the north yet.... Guess it must be you soft southern fairies and anything below 10C  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| ColdKill |
 Posted: 11:08 - 24 Nov 2014 Post subject: |
| iooi wrote: | White smoke is just condensation turned into steam (its got warm).... Not a problem at all.
DO NOT WORRY
Still not had any frosty temps up in the north yet.... Guess it must be you soft southern fairies and anything below 10C  |
Thanks mate you put my mind at rest. I thought I had done something major since its only a 1 year old bike and never failed to start. Had to walk to work thinking I damaged the bike. Just need my new cover to come asap.
But Yeh haha. Woke up this morning to everything frosted over and the bike covered in it. First winter in the south for me, I'm from Glasgow originally (not a southerner haha) and there I was thinking it was nothing but sunshine this far south haha. Even the ignition button got stuck the first time I pressed it. |
| AndyNUFC |
 AndyNUFC Borekit Bruiser
| ColdKill |
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:01 - 24 Nov 2014 Post subject: |
Air cooled engine, right? White smoke can only be from condensation in the exhaust.
Full choke from cold is fine, that's exactly what it's there for. ____________________ Biking is 1/20th as dangerous as horse riding.
| AndyNUFC |
 Posted: 12:09 - 24 Nov 2014 Post subject: |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:01 - 24 Nov 2014 Post subject: |
I'm not suggesting leaving it on for any length of time, just for the initial push (or kick) on a cold day. If it doesn't start immediately on full, try a different setting, but why would it be there if not to be used? ____________________ Biking is 1/20th as dangerous as horse riding.
| andym |
 andym World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 16:25 - 24 Nov 2014 Post subject: |
| ColdKill |
| iooi |
 iooi Super Spammer
 Posted: 19:02 - 24 Nov 2014 Post subject: |
Take plug out and dry it.
Or
Try bump starting it.
If you keep cranking it over it should fire up, but you may flatten the battery 1st...
Do you have a charger? ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:35 - 24 Nov 2014 Post subject: |
If it's flooded then I'd normally go with choke fully off, open the throttle fully, hold it open, and kick or crank a few times. Don't blip the throttle, just hold it open.
Plug out and dry it off is a good plan, it'll also give any fuel in the cylinder a chance to evaporate. Although really I'd have expected it to have done so anyway.
When you say "the same bike as a Pulse Adrenaline", it definitely has an air cooled engine, right? ____________________ Biking is 1/20th as dangerous as horse riding.
| ColdKill |
| AndyNUFC |
| ColdKill |
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:27 - 24 Nov 2014 Post subject: |
You'll want to get that battery on charge ASAP, especially in the cold. On that matter, if it's a wet cell, when was the last time that you checked the electrolyte levels?
125s are pretty easy to bump start. 2nd or even 3rd gear, clutch in, push-push, jump on, clutch out until it spins, clutch in. You need very little speed.
That's assuming that it's going to start up. Don't change your normal start routine from whatever worked this morning until you've definitely determined that it won't fire up like that with a fully charged battery or a man sized bump. ____________________ Biking is 1/20th as dangerous as horse riding.
| ColdKill |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 22:00 - 24 Nov 2014 Post subject: |
Not surprised it won't start if you're just pressing the starter like that. Hold it until it fires. You can hold them one for usually a max of 5-10 seconds with no issues.
Still sounds like it's cranking ok to be honest. Seems to have enough power to push it past the compression stroke, just that you're not holding the starter on long enough. ____________________ My Flickr
| ColdKill |
| Wafer_Thin_Ham |
| ColdKill |
| Wafer_Thin_Ham |
| Major Doss |
 Major Doss Traffic Copper
| talkToTheHat |
 talkToTheHat World Chat Champion
The last post was made 11 years, 298 days ago. Instead of replying here, would creating a new thread be more useful? |
