Impact driver for carb screws - Overkill?
FlightRisk
PostPosted: 22:01 - 24 Nov 2014    Post subject: Impact driver for carb screws - Overkill? Reply with quote
I hate little hex socket head bolts. (The ones you need an allen key for.)
One is stuck solid and has started rounding off and now I'm wondering if an impact driver is what I need for this sort of thing.
No job too small that it doesn't require a new tool purchase. Thumbs Up
Oiled it and left it overnight but no joy and now allen keys (small 2.5mm) won't get a firm grip on it.
Hitting small carb bits with a hammer hitting type tool seems a bit drastic but then I'd really quite like to hit it with a hammer right now. Lump hammer or sledge ideally... Evil or Very Mad
Honda CB500S
PostPosted: 22:06 - 24 Nov 2014    Post subject: Re: Impact driver for carb screws - Overkill? Reply with quote
I'd go for a mole grip on the outside of the screw if you can.
Oh and absolutely most definitely do not put it back in! Smile
FlightRisk
PostPosted: 22:12 - 24 Nov 2014    Post subject: Reply with quote
There's nothing to grip unfortunately, it's a rounded head one and it's in an awkward spot so no chance of filing a slot in it.
Honda CB500S
PostPosted: 22:17 - 24 Nov 2014    Post subject: Reply with quote
Got a picture?
I'd be trying getting an appropriate sized trx head wedged in there (light tapping with a hammer).
I'd consider some heat on the outside of the carb (being VERY aware of what a carb typically contains - use extreme caution!)
Fizzer Thou
PostPosted: 23:06 - 24 Nov 2014    Post subject: Reply with quote
Drill off the socket head and remove the carb part.Then use molegrips on the bit of the screw that is now exposed if it does not come out using just a pair of pliers Thumbs Up
Always have a 'Plan B'
Bezzer
PostPosted: 23:22 - 24 Nov 2014    Post subject: Reply with quote
Try using a centre punch lightly tapping it around the hex hole to tighten it up first, if you end up properly rounding it off then go for drilling but with left hand bits, the hex head ensures you are in the centre and the left hand drill often just unwinds it straight out. You can get a set of 10 for a fiver plus the postage from Tracy tools, they're imperial sizes but that doesn't matter.
https://www.tracytools.com/10-left-hand-drills-hs-various-sizes-from-1-16-tlo-3-8
Raffles
PostPosted: 23:45 - 24 Nov 2014    Post subject: Reply with quote
It sounds as though you're dealing with a 4mm screw.
Before drilling the head off the screw, you should send a 3mm drill straight down the middle of the fastening to a depth that is just below the underside of the screw head. If, after removing the screw head, you are unable to grip the remaining threaded section of the fastening then you will have a pilot hole available to drill out the remnants.
WD Forte
PostPosted: 00:00 - 25 Nov 2014    Post subject: Reply with quote
Some folk have used coarse grinding paste in the holes
of philips and hex heads to remove worn screws
Might work, might not
Ditto JBkwik
Also, a suitably selected torx bit may get enough of a grip to remove it.
bikers smell of wee
c_dug
PostPosted: 07:08 - 25 Nov 2014    Post subject: Reply with quote
I wouldn't want to go hitting a carb too hard, too much risk of breaking it.
I'd go with G's suggestion of the torx key first, if you have one. If not I'd skip straight to fizzer thou's suggestion of drilling the head straight off. Personally I wouldn't faff around with left handed drill bits, nor holes down the middle. Once the pressure is off the bolt the remaining threaded part should unscrew easily, I doubt it will be corroded in or anything.
PostPosted: 09:39 - 25 Nov 2014    Post subject: Reply with quote
I've drilled the head off carb screws many times and the stub has always come out with a pair of pliers.
I wouldn't be hammering anything around the flange of a carb, they are very easily broken.
STONEY!
PostPosted: 09:48 - 25 Nov 2014    Post subject: Reply with quote
Meh, I strip and rebuild carbs on a daily basis and 7/10 times I use an impact driver to undo the screws. I used to use grips and still sometimes do but I have found the impact driver to be the best option most times.
Tap the bit into the screw first, then give the driver a few light hits and jobs a good un. Obviously the emphasis is on light hots if you go at it with a sledge hammer then yes you will probably break something.
Islander
PostPosted: 13:08 - 25 Nov 2014    Post subject: Reply with quote
I've used a small, sharp cold chisel to tap the head round on stuck screws with a good degree of success. Carb bodies aren't made of glass and as long as you take reasonable care you should be ok.
jjdugen
PostPosted: 19:11 - 25 Nov 2014    Post subject: Reply with quote
If its the last one, just tap the float bowl backwards and forwards, this usually loosens its grip enough to get it out with grips.
FlightRisk
PostPosted: 21:25 - 26 Nov 2014    Post subject: Reply with quote
It defeated the Torx method, I realised there was actually just enough space to cut a slot in it with a piece of hacksaw blade. Didn't work either.
Don't have any chisels or punches but I tried tapping it around using an old screwdriver as a punch. Didn't work.
It's not even the float bowl, it's a little M4 bolt holding a pipe right in the way of the last float bowl screw.
As was pointed out to me above it did occur to me yesterday that maybe bashing cast aluminium parts with a big hitting stick was not the way of happiness.
Thanks for the tips. I'll just do what Fizzer Thou said and drill the head off - should actually leave a decent amount exposed to get a grip on, which I didn't realise at first. Found replacement bolts on Wemoto.
Honda CB500S
FlightRisk
PostPosted: 21:32 - 26 Nov 2014    Post subject: Reply with quote
Oh but I came across this little impact driver, not sure if this would be any good for this kind of lighter stuff in future?
Of course I didn't see any impact hex bits that small, I presume normal ones would just sheer off. Are impact drivers even any good for hex?
https://www.machinemart.co.uk/shop/product/details/laser-7535-38-drive-micro-impact-driver-set
Honda CB500S
lihp
PostPosted: 21:50 - 26 Nov 2014    Post subject: Reply with quote
I'm guessing somebody put stainless steel socket heads into an aluminium carb?
bassmastergen...
PostPosted: 21:51 - 26 Nov 2014    Post subject: Reply with quote
This. Step away from the impact driver!
As opposed to the superb quality, monkey-metal JIS dome-heads they come fitted with as standard.
lihp
PostPosted: 21:57 - 26 Nov 2014    Post subject: Reply with quote
Unsure if sarcastic or serious? Thinking
Aluminium or mild steel fixings could be used instead, less likely for a reaction too
FlightRisk
PostPosted: 23:34 - 26 Nov 2014    Post subject: Reply with quote
I'm a little fuzzy on my bolt terminology but it's this sort of thing:
https://images.wemoto.com/full/BOLTS_SCREWS_ALLEN_METRIC/10042950.jpg
Honda CB500S
Fizzer Thou
PostPosted: 23:42 - 26 Nov 2014    Post subject: Reply with quote
I fitted s/s Allen bolts to the float bowls and diaphragm caps of my FZR1000R years ago and never had any problems.They are far easier to use than the original screws and make working on the carbs when in situ much easier.
If anything,when rebuilding the carb with new screws,add a dab of copaslip or moly grease to the threads.Just do not do them up too tight Wink Thumbs Up
The last post was made 11 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 110.13 Kb
