| FlightRisk |
 FlightRisk Spanner Monkey
 Posted: 23:01 - 24 Nov 2014 Post subject: Impact driver for carb screws - Overkill? |
I hate little hex socket head bolts. (The ones you need an allen key for.)
One is stuck solid and has started rounding off and now I'm wondering if an impact driver is what I need for this sort of thing.
No job too small that it doesn't require a new tool purchase.
Oiled it and left it overnight but no joy and now allen keys (small 2.5mm) won't get a firm grip on it.
Hitting small carb bits with a hammer hitting type tool seems a bit drastic but then I'd really quite like to hit it with a hammer right now. Lump hammer or sledge ideally...  ____________________ Honda CB500S |
| G |
 G The Voice of Reason
 Posted: 23:06 - 24 Nov 2014 Post subject: Re: Impact driver for carb screws - Overkill? |
I'd go for a mole grip on the outside of the screw if you can.
Oh and absolutely most definitely do not put it back in!  |
| FlightRisk |
| G |
| Fizzer Thou |
 Posted: 00:06 - 25 Nov 2014 Post subject: |
Drill off the socket head and remove the carb part.Then use molegrips on the bit of the screw that is now exposed if it does not come out using just a pair of pliers  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| Bezzer |
 Bezzer World Chat Champion
 Posted: 00:22 - 25 Nov 2014 Post subject: |
Try using a centre punch lightly tapping it around the hex hole to tighten it up first, if you end up properly rounding it off then go for drilling but with left hand bits, the hex head ensures you are in the centre and the left hand drill often just unwinds it straight out. You can get a set of 10 for a fiver plus the postage from Tracy tools, they're imperial sizes but that doesn't matter.
https://www.tracytools.com/10-left-hand-drills-hs-various-sizes-from-1-16-tlo-3-8 ____________________ I used to be indecisive but now I'm not quite so sure. |
| Raffles |
 Raffles World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
| c_dug |
 c_dug Super Spammer
| stinkwheel |
 Posted: 10:39 - 25 Nov 2014 Post subject: |
I've drilled the head off carb screws many times and the stub has always come out with a pair of pliers.
I wouldn't be hammering anything around the flange of a carb, they are very easily broken. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| STONEY! |
 STONEY! Brolly Dolly
| Islander |
 Islander World Chat Champion
| jjdugen |
 jjdugen World Chat Champion
| FlightRisk |
| FlightRisk |
| lihp |
 lihp World Chat Champion
| bassmastergen... |
 bassmastergen... Nitrous Nuisance
| stinkwheel |
| lihp |
| FlightRisk |
| Fizzer Thou |
The last post was made 11 years, 298 days ago. Instead of replying here, would creating a new thread be more useful? |
