IDE/ACHI mode choice on Fresh install
R1stu
Shrek!
PostPosted: 14:59 - 27 Nov 2014    Post subject: IDE/ACHI mode choice on Fresh install Reply with quote
Hey peeps.
I have just brought and installed a new 3TB HDD as low on space. Now I am thinking as its been about 3 or 4 months since last reinstall.
Now I have an SSD, and Use windows 7, I have also it currently set to ACHI mode.
HOWEVER.
I am unable to burn any cds. My internal drive keeps failing telling me I need to set the page mode to DAO to write, However everything is set correctly and working, and I even replaced my blue ray drive with a normal DVDRW drive.
After research It seems to be an issue with ISTOR Driver and ACHI Drivers and 64bit versions of windows 7. But non of the fixes seems to work.
My motherboard is an MSI P67A-GD65 B3, and it only allows me to set the mode for all of the sata channels not individually (Unlike my old Asus PQ65 mobo)
Now I no longer use a hot swap caddy in my machine, So I was wondering how much of a hit am I going to take performance wise, swapping to IDE mode on the SSD?
Stu
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
CaNsA
PostPosted: 15:22 - 27 Nov 2014    Post subject: Reply with quote
ACHI
Sorry, i should elaborate a bit more.
IDE is pants in comparison, so just dont use it.
What software are you using to burn?
What dvd drive are you using to burn?
PostPosted: 15:34 - 27 Nov 2014    Post subject: Reply with quote
Bless you.
R1stu
Shrek!
PostPosted: 20:39 - 27 Nov 2014    Post subject: Reply with quote
CaNsA wrote:
ACHI
three differnet optical drives via different manufactures. and any CD burning software at all, CDR find DVDR = coaster
CaNsA
PostPosted: 16:45 - 28 Nov 2014    Post subject: Reply with quote
Have you got the latest drivers for the chipset?
Latest BIOS ?
I see from elsewhere on the internet that you are planning a full re-install of windows.
Why is that?
prawny1
PostPosted: 17:07 - 28 Nov 2014    Post subject: Reply with quote
are you using compatible discs for your drive dvd+ vs dvd-
hellkat wrote:
R1stu
Shrek!
PostPosted: 19:57 - 01 Dec 2014    Post subject: Reply with quote
Done a full reinstall, nothing changed. installed a sata card but pc couldnt start it (Resource issue) and pc wouldnt boot half the time, going to stick an IDE drive in.
R1stu
Shrek!
PostPosted: 15:21 - 10 Dec 2014    Post subject: Reply with quote
Well, I have ordered a new Mobo now, as I tried to flash the bios to see if that helped, and the bios flash did not fully work.
MSI confirmed my Board is bricked, so ordered an ASUS P67 board as a stop gap until I can afford upgrade to 1150/i7
Least I should then be able to do a straight swap and not need to reinstall again.
The last post was made 11 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 58.61 Kb
