Setting up mixtures
mudcow007
PostPosted: 13:00 - 01 Dec 2014    Post subject: Setting up mixtures Reply with quote
how do you know when the mixture is setup correct?
is it a case of adjusting an just checking the plugs?
or is there a more scientific method....
gracias
A100man
PostPosted: 13:11 - 01 Dec 2014    Post subject: Reply with quote
Plug colour is a decent starting point I think. Some folk also use ColourTune (google is your friend).. if you're rich (I mean wealthy - not too much fuel) a rolling road session.
lihp
PostPosted: 13:19 - 01 Dec 2014    Post subject: Re: Setting up mixtures Reply with quote
gracias
Is there any reason why the book settings won't be correct for your engine?
mudcow007
PostPosted: 13:29 - 01 Dec 2014    Post subject: Reply with quote
yep tried book settings an it runs like a bag of spanners, richer makes it run better but i have a feeling its too rich now (sooty plugs)
i have read that people "dial in" mixtures etc...i just wondered how they determine what it needs to go too
stirlinggaz
PostPosted: 13:37 - 01 Dec 2014    Post subject: Reply with quote
hi,
give us a clue then?
what bike? what exhaust? original airbox or open air filter? any other mods?
all those have to be taken into consideration when setting up carb'd bikes (as well as carb settings)
cheers,
GAZ
lihp
PostPosted: 14:19 - 01 Dec 2014    Post subject: Reply with quote
Quickest and cheapest way is to get a garage to do it on a Dyno, otherwise you are constantly buying jets, making needle shims, riding, stripping, riding, stripping.
It's something that is honestly, quicker and better done on a dyno
PostPosted: 14:55 - 01 Dec 2014    Post subject: Reply with quote
Dynos are typically run at wide open throttle, right? Thinking
lihp
PostPosted: 15:17 - 01 Dec 2014    Post subject: Reply with quote
I won't pretend to know how (good) dyno techs work their magic with them, however, I do know that it's a lot less hassle, and quicker to let them set it up with one.
mudcow007
PostPosted: 16:15 - 01 Dec 2014    Post subject: Reply with quote
the bike is a 600 blandit (40k mileage)
original zort
original (genuine) air box/ filter
it just runs crap, on choke it will drop a cylinder, less choke, missing cylinder comes back - im putting this down to being too rich (plus the plugs are as black as a witches hat)
the bike is all tucked up for the winter now, so i wont fiddle with it until it gets warmer...
just thinking out loud really, i do like the look of them colour tune things though Thumbs Up
lihp
PostPosted: 17:35 - 01 Dec 2014    Post subject: Reply with quote
original zort
if the bike is stock, then it should run fine on the standard settings, I'd be looking elsewhere for issues.
PostPosted: 17:41 - 01 Dec 2014    Post subject: Reply with quote
Mixture only controls the AFR at low throttle openings.
Where in the revs/throttle position does it run poor?
If it is missing and running crap with black plugs I reckon you need to look the electrical side of things, Plugs/coils/leads/caps etc.
Old Git Racing
PostPosted: 17:53 - 01 Dec 2014    Post subject: Reply with quote
If its laid up for the winter whip the carbs off and clean them, jets out, pilot jets, emulsion tubes etc or get them cleaned. Check all the plug leads are good with good connections at each end, replace if in doubt same goes for plug caps. Fit new plugs of the correct grade. Clean or replace the air filter, check rubbers joining it to carbs. Fill with spanky new fuel and I bet it will run on standard settings.
OGR
Fizzer Thou
PostPosted: 23:18 - 01 Dec 2014    Post subject: Reply with quote
I recollect a post a while ago where someone with a Bandit 600 had a similar problem and it ended up being the inlet manifold seals between the cylinder head and the manifolds.If they leak,which would explain your symptoms,then the bike would run lean.If the choke was then run on half setting,then this would compensate part way.
Easiest and quickest way to determine inlet leaks is to run the engine and then squirt some Dampstart or WD40 around the manifolds.If the engine revs change slightly,then the inlet vacuum is drawing in the accelerant and enrichening that cylinder.
If you are going to have the carbs off anyway,take a look at the seals Wink
https://www.cmsnl.com/suzuki-gsf600-1996-sut_model13530/partslist/FIG2.html#results
Part #22
Always have a 'Plan B'
mudcow007
PostPosted: 23:49 - 01 Dec 2014    Post subject: Reply with quote
cheers all
fizzer, i think that was me earlier in the summer, so its already had the o-rings....
i will have another go at the weekend i reckon. no doubt i will get it running sweet but wont be able to ride it (no tax) Laughing
ta
The last post was made 11 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 88.2 Kb
