Perfect timing!
handbasket
PostPosted: 14:01 - 03 Dec 2014    Post subject: Perfect timing! Reply with quote
Had a 9am hospital appointment this morning, 8am I fire up the bike, the front light glows bright then dies.
Made me 20 minutes late by the time I’d found the right page in the manual (first failure in a year of riding), got the side panel off to access the back of the headlight unit, swapped the bulb, and put everything back together. At least I’m getting quicker at getting the panel off.
They were still able to see me at the hospital, and they decided they didn’t need to do anything.
goto10
PostPosted: 14:04 - 03 Dec 2014    Post subject: Re: Perfect timing! Reply with quote
10p says you need a new reg/rec too.
Snorty
PostPosted: 14:09 - 03 Dec 2014    Post subject: Re: Perfect timing! Reply with quote
+1, it's probably giving out too many volts.
handbasket
PostPosted: 15:48 - 03 Dec 2014    Post subject: Re: Perfect timing! Reply with quote
It’s a Honda. Did I mention that?
BenR
PostPosted: 16:09 - 03 Dec 2014    Post subject: Re: Perfect timing! Reply with quote
Definitely needs a new reg/rec then.
Itchy
PostPosted: 16:11 - 03 Dec 2014    Post subject: Re: Perfect timing! Reply with quote
Reg/recs are consumable items on Hondas Laughing
handbasket
PostPosted: 16:45 - 03 Dec 2014    Post subject: Re: Perfect timing! Reply with quote
Best get the voltmeter out (off to google to see what I need to test…)
monkeybiker
PostPosted: 17:02 - 03 Dec 2014    Post subject: Reply with quote
You check the voltage of the battery with the bike running. Rev the bike and the voltage should not go above 15 volts.
goto10
PostPosted: 18:33 - 03 Dec 2014    Post subject: Re: Perfect timing! Reply with quote
Sorry, I didn't realise - I'll change that to:
10p says you need a new reg/rec for your Honda.
Commuter_Tim
PostPosted: 22:06 - 03 Dec 2014    Post subject: Re: Perfect timing! Reply with quote
I won't believe you until I see the video proof.
...See you in 6 months? Whistle
I ride a Bandit 600... badly.
The last post was made 11 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 66.5 Kb
