I'm struggling to keep it up.
Minty
PostPosted: 11:30 - 04 Dec 2014    Post subject: I'm struggling to keep it up. Reply with quote
Hey y'all.
Is there a simple fix that will make my choke stay in the 'on' position? I am finding it slides back down to off too soon on occasions (normally when I am rolling down my road to bump start it).
Fanx.
My fingers smell of your mum.
nowhere.elysium
The Pork Lord
PostPosted: 11:37 - 04 Dec 2014    Post subject: Reply with quote
A mate of mine keeps his keys on a lanyard, which he then loops through the bit between the choke lever and the rest of the switchgear - it provides enough resistance to keep the choke open as long as he needs it for.
bikenut
PostPosted: 11:50 - 04 Dec 2014    Post subject: Reply with quote
the choke cables usually have a twist and lock feature...........as it goes mine jammed solid last week but still got it to start....it now has a new cable ( oe cable has plastic body so its gunna break as soon as I look at it!! ) but the lads bike has had a clothes peg ( wood ) cabletied to the h/bar which he uses to "hold" the choke on whilst the eng warms up........his bike, his problem so his bill!! 8o)
little blue pills no good for this problem........ :D
nuts about bikes
PostPosted: 16:57 - 04 Dec 2014    Post subject: Reply with quote
Choke mechanism on one of my bikes isn't of the twist-lock variety. The housing for the plunger has a screw cap that when tightened adds friction to the plunger's shaft.
In short; Tried twisting yer cap?
If this post hasn't given you a semi, it's quite normal and I apologise.
cresad
PostPosted: 22:57 - 04 Dec 2014    Post subject: Reply with quote
A friend of mine keeps his open using a clothes peg Laughing
Adam
PostPosted: 23:27 - 04 Dec 2014    Post subject: Reply with quote
Pull it out and bend the stem. That'll stop it going back in Smile
Minty
PostPosted: 09:08 - 05 Dec 2014    Post subject: Reply with quote
I had a damn good yank of it this morning to make it as proud as I could, threw in a 'twist to the right' instead of the usual left, to maybe confuse it. Even had a look at what Pat said about the twisty cap thing - mine is tighter than a ducks arse.
Still slipped back in before I managed to bump start it 40m down the road. (I then pull over at the junction, keep it pulled with my left hand whilst I start it in the normal fashion)
bikenut
PostPosted: 11:34 - 05 Dec 2014    Post subject: choke Reply with quote
daft question but why are you bump starting it??
fix the starting problem and the choke mech
nuts about bikes
Minty
PostPosted: 11:43 - 05 Dec 2014    Post subject: Reply with quote
Oh. No starting problem, I just roll down the hill when I am on early starts so I wake other peoples neighbours and not mine. I bump just by the junction and I roar off into the distance.
And this thread was to try and fix the choke mech. Confused
Nobby the Bastard
Harley Gaydar
PostPosted: 18:29 - 05 Dec 2014    Post subject: Reply with quote
When I struggle to keep it up, I just get Mrs Nobby to fondle my bollocks. Works a fucking treat.
Triumph Sprint ST 1050
CaNsA
PostPosted: 18:35 - 05 Dec 2014    Post subject: Reply with quote
Elastic band looped on screen brace then hooked to choke slider.
A while nback i posted this on the zxr forum, it might apply to your check aswell.
Today, while i was cleaning the left switchgears because my indicators were being complete arseholes, I spotted a small bit of plastic inside the switchgear housing on the back half.
It is located next to the choke slider guide.
a small screw is holding a small metal plate on it.
Unscrew it, take out the small plastic bit and clean the spring, the plastic bit and the recess where it sits.
Put everything back together and check out how the choke lever will stay in place.
You're welcome.
Minty
PostPosted: 19:19 - 05 Dec 2014    Post subject: Reply with quote
She makes me hard too but with her party trick tongue thingy. Not relevant to my choke issue though. Sad
BikerMatt
PostPosted: 20:49 - 05 Dec 2014    Post subject: Reply with quote
On one of my old Honda's the choke had a plastic nut underneath, mine kept doing as you said but stopped when I tightened the nut
The last post was made 11 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 83.55 Kb
