Linux, this one's for you Teme...
RhynoCZ
PostPosted: 13:53 - 11 Dec 2014    Post subject: Linux, this one's for you Teme... Reply with quote
Today, I tried to boot up the Debian and all I got was that: the ''BootMGR'' was missing and all I could do was restart the PC with alt+ctrl+del.
Is there a way how to get this sorted out? I'm burning Debian image onto a CD as we speak. Rolling Eyes
b422063
PostPosted: 14:00 - 11 Dec 2014    Post subject: Reply with quote
According to Google, that's a Windows error... Is it a dual boot system? Are you using GRUB, LILO or some other boot manager?
RhynoCZ
PostPosted: 14:09 - 11 Dec 2014    Post subject: Reply with quote
I do have Windows and Debian in one PC, but each system have its own hard drive. Thinking
b422063
PostPosted: 14:12 - 11 Dec 2014    Post subject: Reply with quote
BIOS will be telling your computer to boot from either one or the other hard drive which has the MBR on?
Do you go into BIOS to change the booting operating system?
RhynoCZ
PostPosted: 14:16 - 11 Dec 2014    Post subject: Reply with quote
Nope, I just press F8 key at the start up screen and that gives me the option to choose which drive to boot up. Worked for ages, now this.
b422063
PostPosted: 14:20 - 11 Dec 2014    Post subject: Reply with quote
You are telling BIOS which drive to boot by doing that. My first troubleshooting test would be to shutdown -> unplug Windows hard drive completely -> try boot from Debian.
If it fails to boot I'd suggest reinstalling GRUB/LILO or what other boot manager you have installed.
Afraid I only have one laptop with Windows on which dual boots and it's a very old laptop running Windows 7 so I can't help with the Windows element of the situation.
RhynoCZ
PostPosted: 14:27 - 11 Dec 2014    Post subject: Reply with quote
I did as you said, and it works. I'm still not sure why it wouldn't let me boot the linux up using the F8 key as always.
Anyway, thank you, Sir. Smile
RhynoCZ
PostPosted: 14:42 - 11 Dec 2014    Post subject: Reply with quote
Well, I tried to update the OS, and got this:
E: Error https://security.debian.org/ wheezy/updates/main libapt-pkg4.12 amd64 0.9.7.9+deb7u5
404 Not Found [IP: 212.211.132.250 80]
I think I let Teme down and ruined the OS again. Laughing
CaNsA
PostPosted: 14:48 - 11 Dec 2014    Post subject: Reply with quote
Do you have any internet access on that machine?
RhynoCZ
PostPosted: 14:59 - 11 Dec 2014    Post subject: Reply with quote
Yes, I do. I'm in the Debian right now. Thumbs Up
temeluchus
PostPosted: 15:51 - 11 Dec 2014    Post subject: Reply with quote
So your windows install shit itself and this is therefore a linux problem?
temeluchus
PostPosted: 15:53 - 11 Dec 2014    Post subject: Reply with quote
What did you fuck with Rhyno?
If you say *i did nothing* you are an utter total bald faced liar and I will no longer talk to you.
If you have windows vista, 7 or 8 some of the updates delete GRUB and fuck up the bootloaders by trying to go back to bootmgr. Windows will try and install the bootloader on a random drive and as far as i know there is no easy way to stop it.
TL:DR uninstall windows if you want a multiboot system that is reliable.
b422063
PostPosted: 15:56 - 11 Dec 2014    Post subject: Reply with quote
What's the contents of your /etc/apt/sources.list?
Also: https://serverfault.com/questions/636343/apt-fails-to-get-sources-due-compression
RhynoCZ
PostPosted: 19:19 - 11 Dec 2014    Post subject: Reply with quote
Well Teme, all I did, was that I tried to boot it up after 3 months or so. Confused
temeluchus
PostPosted: 19:34 - 11 Dec 2014    Post subject: Reply with quote
So you had not turned the machine on in three months?
RhynoCZ
PostPosted: 19:38 - 11 Dec 2014    Post subject: Reply with quote
I used the PC for Windows, I had to get some work done. You know far too well how fragile a linux based system can be when I, specifically, need it to do stuff. Smile
temeluchus
PostPosted: 20:00 - 11 Dec 2014    Post subject: Reply with quote
The windows update was backported from 7 and 8 applied to vista and has ruined the bootloader. Good luck.
Like WD says you need to sort out GRUB.
Going
PostPosted: 22:36 - 11 Dec 2014    Post subject: Reply with quote
Or get rid of Grub and use Gummiboot if you're using a different hard drive for each OS.
Also Debian, fragile Razz Surprised Very Happy
Stowelly
PostPosted: 15:32 - 12 Dec 2014    Post subject: Reply with quote
boot the live disk and run boot-repair (should be in apt)
nowhere.elysium
The Pork Lord
PostPosted: 17:21 - 12 Dec 2014    Post subject: Reply with quote
RhynoCZ wrote:
...how fragile a linux based system can be...
You really do talk some shit, you know that?
b422063
PostPosted: 19:22 - 12 Dec 2014    Post subject: Reply with quote
Maybe he's logged in as the root user all the time? Laughing
sickpup
Old Timer
PostPosted: 19:25 - 12 Dec 2014    Post subject: Reply with quote
A question.
Is there a point to dual booting now its so easy to run Virtual Machines?
CaNsA
PostPosted: 19:29 - 12 Dec 2014    Post subject: Reply with quote
Depends on the hardware running the VM.
It takes less resources to run a single operating system then it does to run an O/S, then the VM client, then another O/S within it.
b422063
PostPosted: 20:04 - 12 Dec 2014    Post subject: Reply with quote
Really depends what you want from the Virtual Machine. Gaming takes so much resources you'd struggle to run them in a VM reasonably.
Going
PostPosted: 01:12 - 13 Dec 2014    Post subject: Reply with quote
Gaming for me, otherwise I'd be happy to bin Windows.
Currently as both by admin and user profiles have been corrupted for some reason and none of the windows recovery options want to work including reading a DVD or USB for repair, binning it may happen sooner rather than later Neutral
The last post was made 11 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 129.53 Kb
