Coffee drinkers....
Bike Chat Forums Index -> Dear Auntie BCF... Goto page 1, 2, 3, 4, 5  Next
mudcow007
PostPosted: 15:24 - 17 Dec 2014    Post subject: Coffee drinkers.... Reply with quote
So what do you all use to brew?
im looking at buying an aeropress as im getting fed up of using my stovetop, they look pretty funky an fast
Current favourite coffee is El Savador bourbon from Hasbean.co.uk
nom nom nom....
TheArchitect
PostPosted: 15:45 - 17 Dec 2014    Post subject: Reply with quote
I just use the Nespresso M130. Their Livanto is scrumptious!
GSXR 600 K6 - Stolen
MT09 - Almost stolen
PostPosted: 15:48 - 17 Dec 2014    Post subject: Reply with quote
Druggies!!! Rolling Eyes
arry
PostPosted: 17:14 - 17 Dec 2014    Post subject: Reply with quote
I just use a grinder and french press.
Also use hasbean - they're very good
PostPosted: 17:17 - 17 Dec 2014    Post subject: Reply with quote
Aeropress with a Pact subscription. Thumbs Up
CaNsA
PostPosted: 17:18 - 17 Dec 2014    Post subject: Reply with quote
This is supposed to be shit hot, I want one.
https://www.amazon.co.uk/Andrew-James-Programmable-Integrated-Reuseable/dp/B00JRA1G84/
mudcow007
PostPosted: 17:19 - 17 Dec 2014    Post subject: Reply with quote
chris how you getting on with the press?
for £20 it seems a bargain....
PostPosted: 17:27 - 17 Dec 2014    Post subject: Reply with quote
Great, does exactly what it says on the tin Thumbs Up
My advice with them follow the instructions 1 scoop then fill to the 1 line, or 2 scoops and fill to the 2 etc. Putting more water through the grounds adds bitterness, top it up with hot water if you are having a cup. Also take your time brewing it. Thumbs Up
barrkel
PostPosted: 17:51 - 17 Dec 2014    Post subject: Reply with quote
Aeropress with Hario Mini Mill hand grinder and Pact subscription here. Two coffees a day, 10-13g of beans per cup, so I get about 10 cups from a 250g bag of whole beans.
Use an automatic burr grinder at home, only one coffee on Saturday and Sunday.
I use a fine steel mesh filter (S Filter) with the Aeropress at work, removes the need to keep filters safe from the cleaners, other fluids, etc. I use a combo of steel mesh and paper filter at home. The paper filter doesn't catch much, the steel blocks almost everything.
Different beans benefit from different grind size and steeping time. Some coffees, I'll brew in the Aeropress upside down, as otherwise the water filters through a bit too quickly (the steel mesh is more porous than the paper filters to begin with). The grinders, both manual and automatic, make it easy to adjust. Overextracted coffee is bitter, underextracted is sour. Finer grinds and longer steeping increases extraction. But my taste also varies, depending on how tired I am.
weasley
PostPosted: 17:53 - 17 Dec 2014    Post subject: Reply with quote
I bought a DeLonghi EC152 around a year ago and have used it daily since then. It's a simple one, but turns out decent enough coffee. I have generally bought from supermarkets, stuff like Taylors and Illy, but recently found a relatively local online supplier that I think I might give another go.
What I like about a pumped machine vs a pod-based system is that you, as the 'barista', have an influence over how it turns out. How much coffee you use, how hard you tamp it, how long you pump for, the grind size etc. There's a skill to it, which appeals to me (at the risk of getting some cups that aren't so great).
PostPosted: 18:34 - 17 Dec 2014    Post subject: Reply with quote
Whatever wholebean instant is on sale at the time. And a kettle.
barrkel
PostPosted: 18:50 - 17 Dec 2014    Post subject: Reply with quote
Let me tell you about my 25 year balsamic... Smile
PostPosted: 19:20 - 17 Dec 2014    Post subject: Reply with quote
Whilst I think the "Use by" dates are a con, that's pushing it a bit.
notbike
PostPosted: 19:24 - 17 Dec 2014    Post subject: Reply with quote
I drink tea does this count
can i join in
pls respond.
sensi5446
PostPosted: 19:34 - 17 Dec 2014    Post subject: Reply with quote
I use a nespresso, perfect coffee every time and their decaf range is delish Smile
Nash GT
PostPosted: 19:50 - 17 Dec 2014    Post subject: Reply with quote
We use a Nespresso Essenza or a Greca coffee maker with freshly ground beans when we fancy a change
Suzuki GSF600N
Nash GT
PostPosted: 19:51 - 17 Dec 2014    Post subject: Reply with quote
can i join in
pls respond.
https://i0.kym-cdn.com/entries/icons/original/000/007/423/untitle.JPG
Suzuki GSF600N
Nash GT
PostPosted: 19:53 - 17 Dec 2014    Post subject: Reply with quote
CaNsA wrote:
OH has been banging on about one of this for a while now, might give it a try
Suzuki GSF600N
duhawkz
PostPosted: 20:36 - 17 Dec 2014    Post subject: Reply with quote
BodyGuard wrote:
Coffee makes your breath smell of shit I get my caffeine fix in other ways.
No I'm sure that's just all the bullshit you spout
Nash GT
PostPosted: 20:39 - 17 Dec 2014    Post subject: Reply with quote
Doesn't for me, then again I brush my teeth after the morning coffee and chew mints like they are going out of fashion the rest of the day
Suzuki GSF600N
PostPosted: 20:43 - 17 Dec 2014    Post subject: Reply with quote
https://dissociatedpress.com/wp-content/uploads/2013/02/starbutts-enema-450.png
bamt
PostPosted: 20:46 - 17 Dec 2014    Post subject: Reply with quote
Nowadays we go for convenience in making coffee.
We have a Nespresso machine as Mrs bamt likes it. It gives reasonable drinks and is consistent, but a little expensive to run at about 30p a cup and the machines aren't particularly long lived before they start to leak. We are on our third; and one of those I got another couple of years life out of by replacing a leaking valve before the heater failed. I'd probably not replace the machine for my own use.
We also have a Cuisinart bean to cup coffee robot a bit like that Andrew James one. Bung beans and water into it, set the timer, wake up to freshly ground and brewed coffee. Perfect. It's also been useful the odd time when I've forgotten to set my alarm clock; the grinder (which normally fires up when I'm using the bathroom) wakes me up.
duhawkz
PostPosted: 20:48 - 17 Dec 2014    Post subject: Reply with quote
at work I drink Tesco French ground from a cafetiere or taylors if its on offer cause I drink too much of it to buy the dear stuff.
I bought a grinder and have been using Tesco's Java Sumatra Beans, which are rather nice, and I bought some Panama Dark and some Gautemala beans from fresco gaurmet coffee - https://www.frescogourmetcoffee.co.uk/ again in a cafetiere.
I have also got a nespresso machine.
duhawkz
PostPosted: 20:54 - 17 Dec 2014    Post subject: Reply with quote
I'm not really a big fan of percolated coffee, it never seem hot enough.
Does anybody know where you can buy decent beans by the kilo fairly cheaply.
The last post was made 11 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.65 - MySQL Queries: 13 - Page Size: 127.85 Kb
