Extractor fan help
WULFSTAN
PostPosted: 14:33 - 17 Dec 2014    Post subject: Extractor fan help Reply with quote
So am trying to wire this extractor fan up to a plug is was supplied with. i know where the blue and brown wires go. Now the problem is i don't know where the green wire goes am guessing its the earth. The extractor manual says it its double insuited does this mean i can just chop the green wire off an am good to go?
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
nowhere.elysium
The Pork Lord
PostPosted: 14:58 - 17 Dec 2014    Post subject: Reply with quote
Green and yellow wires are earth, yes. It's typically best to actually wire it to earth, as opposed to just cutting it off - double-insulation's nice and everything, but proper earthing is better.
Caveat - I am not a sparky, I just happen to have wired a few things up and not died yet.
robs321
Stick the earth in a spare bit of chock block or just put a bit of inspiration tape over the end Thumbs Up
WULFSTAN
PostPosted: 15:12 - 17 Dec 2014    Post subject: Reply with quote
Ive got no instillation tape would cello tape work?
nowhere.elysium
The Pork Lord
PostPosted: 16:04 - 17 Dec 2014    Post subject: Reply with quote
mpd72 wrote:
Can't you just screw the earth to the screw holding the chassis together?
Bit pointless, given that the screw doesn't go to earth, it just holds two bits of plastic together.
jeddy11
PostPosted: 16:10 - 17 Dec 2014    Post subject: Reply with quote
Just chop the earth off double insulated means no need to be earthed.
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
PostPosted: 16:25 - 17 Dec 2014    Post subject: Reply with quote
Chop chop!!
doggone
Fixing it inside even 'pointlessly' will look better and avoid the slight risk of cut off earth cable giving a shock if something else is wired wrong or goes faulty.
Islander
PostPosted: 16:40 - 17 Dec 2014    Post subject: Reply with quote
They provided an earth wire for a reason so use it. It'll take an extra 30 seconds or so to terminate it in the earth pin and as pointed out, it'll get it out of the way safely. Thumbs Up
ETA..
Gah, it wasn't clear from the OP that it was the fan and not the plug. That'll teach me to open the attachments. Laughing
There's nowhere to terminate it so cut it right back to the outer insulation and forget it.
drzsta
PostPosted: 17:03 - 17 Dec 2014    Post subject: Reply with quote
If you havnt got any connector blocks I would terminate it to the screw for the cable clamp like someone else mentioned. Just for future use.
Btw, inline fan on a plug top?
grr666
PostPosted: 21:04 - 17 Dec 2014    Post subject: Reply with quote
No earth needed. I'd usually use a bit of heat shrink to make the wire safe
from earthing issues elsewhere in the system.
Double square logo means double insulated
https://evantoh23.files.wordpress.com/2012/10/double_insulation_02-scaled1000.jpg
Commuter_Tim
PostPosted: 22:22 - 17 Dec 2014    Post subject: Reply with quote
This thread has been rather informative ...I now know of 2 new ways to pronounce "Insulation Tape" Wink
I ride a Bandit 600... badly.
ScaredyCat
PostPosted: 22:38 - 17 Dec 2014    Post subject: Reply with quote
I used to like tractors...
.. not any more...
... I'm an ex-tractor fan ....
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
grr666
PostPosted: 23:28 - 17 Dec 2014    Post subject: Reply with quote
.. not any more...
https://www.youtube.com/watch?v=8eXj97stbG8
robs321
PostPosted: 17:09 - 18 Dec 2014    Post subject: Reply with quote
Years ago I was working onsite and this Irish labourer cut his finger open. He had wrapped some blue roll round it and came and asked me if I had any of that inspiration tape to bind round it. Ive called it that ever since! Wink
robs321
PostPosted: 21:30 - 18 Dec 2014    Post subject: Reply with quote
Vincent wrote:
If you have it, google the manufacturer and model number...most guides are online somewhere.
Its double insulated, it doesn't need an earth, OP should just terminate the earth cable in a chock block or something so there is no bare end laying in there to cause a problem. This is done in case another incompetent comes along for a play!
The last post was made 11 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 110.74 Kb
