Interesting engine design
Bike Chat Forums Index -> Found on the 'Net Goto page 1, 2  Next
notbike
PostPosted: 10:00 - 18 Dec 2014    Post subject: Interesting engine design Reply with quote
Found it interesting
https://www.facebook.com/video.php?v=10154960288155112
RhynoCZ
PostPosted: 11:21 - 18 Dec 2014    Post subject: Reply with quote
It's way too complicated = expensive to produce and maintain. Thumbs Down
RTU engine - https://www.rtugroup.com/animation
Specs:
5-cylinder Turbo 2.5 liter
Power: 598kW (814 HP)
Torque: 1.000+ Nm (dyno limit)
Radiatorless Water System
Exhaust Gas Temp. 351°C
No catalityc converter needed
1.850 rpm - 115km/h - 5.3l/100km
Not sure if fictional or real, but there are videos from testing all over the news in Slovakia, so who knows? They even got money from the gov.
CieL
PostPosted: 15:35 - 18 Dec 2014    Post subject: Re: Interesting engine design Reply with quote
Meef wrote:
Thanks for sharing, that s**t was cool. Clapping
Semper Paratus
weasley
PostPosted: 16:42 - 18 Dec 2014    Post subject: Reply with quote
I like different ways of doing engine, and this is interesting. My first thought is about the constant radial thrust that each piston will exhibit on its cylinder, caused by the rotational motion of the 'block'. One must also wonder at the rotational inertia of the whole thing, and the resultant reactional torque. I also wonder how scalable it is? Can it lose pistons and still run? A recip engine can be any number of pistons.
hmmmnz
PostPosted: 19:38 - 18 Dec 2014    Post subject: Reply with quote
there are vids of it running on youtube as well,
https://www.youtube.com/watch?v=cTpPBiReaZk
its a cool motor, and has been pretty thoroughly tested,
it'll never be viable for a car, its more for trucks
the humans are dead
I kick arse for the lord
goto10
PostPosted: 17:31 - 19 Dec 2014    Post subject: Reply with quote
Anyone remember the ceramic engine design? I remember reading 10+ years ago that they'd revolutionise the way engines were made - nothing expands when it gets hot, so everything is made to extremely fine tolerances and it didn't need water cooling nor any oil to lubricate it. I'm guessing by their glaring absence that there were massive downsides (Cost/weight?)
PostPosted: 17:40 - 19 Dec 2014    Post subject: Reply with quote
It's funny, I was talking to a mate about that last week. I'm trying to remember where I first saw a mockup - might have been a motor show at the NEC. Going to have to commit Googlage now.
[edit] https://www.youtube.com/watch?v=gppJuPwmZJg
https://news.google.com/newspapers?nid=1368&dat=19851111&id=E3xIAAAAIBAJ&sjid=fxIEAAAAIBAJ&pg=5280,3438260
https://www.google.com/patents/US5063881
Triton Thrasher
PostPosted: 20:05 - 19 Dec 2014    Post subject: Reply with quote
Good for just pottering around.
Rrrrrrrrrrrrrrrrrr
PostPosted: 21:39 - 19 Dec 2014    Post subject: Reply with quote
It's unfamiliar. That doesn't make it over-complicated. You spotted the lack of valves and valvetrain, right?
Thing is, a Wankel is significantly simpler, smaller and lighter, and how many of them are in use in cars?
I think we just like our familiar complicated, shafty lumps, because we've got used to them.
goto10
PostPosted: 21:47 - 19 Dec 2014    Post subject: Reply with quote
Thing is, a Wankel is significantly simpler, smaller and lighter, and how many of them are in use? We like our familiar complicated, shafty lumps.
Doesn't the Wankel need its rotor tips replacing with disappointing regularity though? An engine that needs frequent rebuilds won't ever be particularly popular. ISTR that Mazda only developed the Wankel because of some tax advantage given to them by developing something different.
hmmmnz
PostPosted: 00:50 - 20 Dec 2014    Post subject: Reply with quote
yeah rotorys need the apex seals done pretty regulary,
but its an easy job, whats not easy is pulling off all the gubbins that are now attached to them,
back in the late 90s i had a rx3 bridgeport 13b, no turbo, no fancy electronics,
just a webber carb,
the engine could be pulled out stripped down seals done and back in in a couple of hours,
biggest problem with rotarys is the fuel efficiency, there is none Very Happy
the humans are dead
weasley
PostPosted: 08:45 - 20 Dec 2014    Post subject: Reply with quote
As suggested above, the love affair with recips means that they have attracted the lion's share of the development funding over the last 100 years. The Wankel has had a tiny fraction of that development, largely because it has been pushed by only one OEM, and in only one car at a time. If it had had the same development, maybe it would now be reliable and efficient.
We've gone too far down the recip road to embrace any other kind of ICE until the EV (or whatever) comes along.
Triton Thrasher
PostPosted: 10:06 - 20 Dec 2014    Post subject: Reply with quote
The revolving "magazine" with the pistons has to seal against the end plate that carries the plugs and ports.
Failing to prevent wear and failures there is going to use up most of their money. The rest can go on motor show extravaganzas with model girls. Then they'll give up.
Rrrrrrrrrrrrrrrrrr
RhynoCZ
PostPosted: 10:53 - 20 Dec 2014    Post subject: Reply with quote
Interesting point, but still, the way the ''crank'' moves in that New Zealander's engine and the rods pushing it just feels very, very odd.
Also, there was an four stroke engine head with not conventional valves (there are seals under the rotors with possibly very poor durability):
Coates engine
https://www.thetruthaboutcars.com/wp-content/uploads/2007/12/pic06.jpg
PostPosted: 15:12 - 20 Dec 2014    Post subject: Reply with quote
Mmm, I expect the next tranche of development will be camless with solenoid valves, if only because it'll help with scamming emissions.
spikenipple
PostPosted: 16:59 - 20 Dec 2014    Post subject: Reply with quote
Christian von Koenigsegg has developed a very interesting looking pneumatic valve system which him and the dev team at Koenigsegg have had fitted to a Volvo. If I recall correctly there is a Youtube video of him saying that the car has covered over 200,000 miles without a fault. The valve timing can be set precisely how they like at any given parameter range (throttle opening/RPM/load etc).
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
Grizly
PostPosted: 17:08 - 20 Dec 2014    Post subject: Rotary engine Reply with quote
Yes, seen this before as a hydraulic pump and also (a long time ago) as an engine in a torpedo - can't remember the fuel but it must have been a monofuel with it's own O2.
Only needed to work once but went like stink.
Wohoo!
Triton Thrasher
PostPosted: 17:59 - 20 Dec 2014    Post subject: Re: Rotary engine Reply with quote
Swash plate mechanism. Used as hydraulic pump or motor.
I think torpedos may be driven by compressed air, or some gas compressed, without any combustion going on.
Rrrrrrrrrrrrrrrrrr
PostPosted: 21:18 - 20 Dec 2014    Post subject: Reply with quote
Solenoid, hydraulic, yes. Cams have had their chips, although Honda will doubtless push their VVVVVVTEC as far as it shall go.
goto10
PostPosted: 13:35 - 21 Dec 2014    Post subject: Reply with quote
https://www.youtube.com/watch?v=f4p-55a3WV8
RhynoCZ
PostPosted: 13:59 - 21 Dec 2014    Post subject: Reply with quote
I know this might sounds stupid, but are two strokes dead? I mean, there were no moving parts in the head, extremely light yet powerful units and so on. Thinking
PostPosted: 15:26 - 21 Dec 2014    Post subject: Reply with quote
Emissions, sadly.
The anti-bike brigade keeps trotting out some rather bizarre claims that mopeds have worse emissions than buses. If they're based on anything other than mentalism, it'll be 2 strokes they're on about.
PostPosted: 21:57 - 21 Dec 2014    Post subject: Reply with quote
This is what we need.
https://www.lotuscars.com/gb/omnivore-interactive-animation
PostPosted: 00:16 - 22 Dec 2014    Post subject: Re: Rotary engine Reply with quote
Very early torpedoes were flywheel-driven. They spun the wheel up to some stupid RPM and let it go. Didn't have much range but not much to go wrong wither.
EDIT: just found the link I recall. One was discovered by dolphins trained by the navy to look for mines and such:
https://articles.latimes.com/2013/may/17/local/la-me-torpedo-dolphins-20130518
Just_James
PostPosted: 00:18 - 22 Dec 2014    Post subject: Reply with quote
2 stroke should be the standard for all engines Thumbs Up
Yeah we'd all be breathing in a lot of barely singed hydrocarbons.... but what better smell is there? Very Happy
The last post was made 11 years, 328 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Found on the 'Net All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 133.46 Kb
