CarPlan Coolant
Jonathan A
PostPosted: 13:17 - 21 Dec 2014    Post subject: CarPlan Coolant Reply with quote
Im going to be giving my bike a service this week, and the coolant is due for a change…
Does anyone know if ethylene glycol coolant, like this:
https://www.wilko.com/invt/0296722
is ok for an aluminium engine? Confused
cheers Smile
Hyosung GT650R
Taught2BCauti...
PostPosted: 13:40 - 21 Dec 2014    Post subject: Reply with quote
Yes - I have been using that one for years, but the full-strength version, rather than ready-mixed - just because I'm too tight to pay that much for plain water!
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Jonathan A
PostPosted: 13:46 - 21 Dec 2014    Post subject: Reply with quote
Brilliant thanks! It beats the £12 I spent on coolant last time Embarassed
Hyosung GT650R
Fizzer Thou
PostPosted: 17:45 - 21 Dec 2014    Post subject: Reply with quote
If you can measure the ratio of 60% distilled water and 40% unmixed coolant,this will be better for your engine as anti-freeze is not very good at moving heat away from hot spots in the engine.
That and a 50/50 mix is good for countries that have a climate that might go down to -30c - which is not very likely in the UK Rolling Eyes
Always have a 'Plan B'
Nobby the Bastard
Harley Gaydar
PostPosted: 18:14 - 21 Dec 2014    Post subject: Reply with quote
The temperature may not get down to -30c, but windchill can easily get the rad temperature down near that before the thermostat opens and starts to fill it with warm/hot water.
Triumph Sprint ST 1050
Robby
Dirty Old Man
PostPosted: 18:18 - 21 Dec 2014    Post subject: Reply with quote
Get coolant the same colour as whatever is currently in there - it will be either blue, green or pink. 3 kinds of coolant, 3 colours. They don't all like to mix with each other.
As for discussions on ready mixed vs mixing your own - it doesn't make a difference. If you change the coolant on schedule, it will do the job of cooling the engine, not freezing, and preventing corrosion. There may be some minor differences in corrosion prevention, but they would take about 300 years to be apparent.
Fizzer Thou
PostPosted: 20:15 - 21 Dec 2014    Post subject: Reply with quote
https://www.challengers101.com/CoolantMix.html
I use a 70% distilled water,25% quality antifreeze and 5% Waterwetter in the KTM enduro and it works far better.
But on the Exup and R1 I use 65% distilled water,25% quality antifreeze and 10% Waterwetter
https://www.redlineoil.com/Products.aspx?pcid=10
But this is my preferance.
For lesser machinery a 50/50 mix will be fine Thumbs Up
A100man
PostPosted: 14:58 - 22 Dec 2014    Post subject: Reply with quote
Why would Tap water be no good ? I don't know BTW just curious..
iooi
PostPosted: 16:59 - 22 Dec 2014    Post subject: Reply with quote
Because tap water is fully of impurities....
Depending on where you live you can have soft or hard water... Hard water area's tend to leave lots of firing up on elements. Due to the high levels of minerals....
Last thing you need is your waterways getting all fured up Sick
You can make you own distilled water. But the cost is going to be a lot higher than buying a couple of bottles...
Fizzer Thou
PostPosted: 17:03 - 22 Dec 2014    Post subject: Reply with quote
A quick google search found this
'Although tremendous progress has been made in improving the performance of modern day antifreeze/coolants there is still one factor that can reduce their effectiveness – the quality of the water used for dilution! High levels of calcium and magnesium in tap water, that cause furring of kettle heater elements, can also lead to deposits and scale build up in the engine cooling system. If you are in a hard water area it is advisable to use distilled or deionised water in the cooling system rather than tap water.'
A100man
PostPosted: 22:49 - 22 Dec 2014    Post subject: Reply with quote
OK makes sense - calcium rather than chlorine is the problem element then..
Northern Monkey
PostPosted: 23:43 - 22 Dec 2014    Post subject: Reply with quote
Ethylene Glycol is has properties similar to alcohol. It's also known ethan-1-2-diol.
It has lower conductivity, and lower specific heat capacity than water, making it a less efficient coolant than water, however, it can be used over a greater temperature range than water.
UrbanRacer
PostPosted: 02:55 - 23 Dec 2014    Post subject: Reply with quote
If a thermometer reads 5c without windchill, it'll will still read 5c with windchill.
doggone
PostPosted: 10:00 - 23 Dec 2014    Post subject: Reply with quote
I can't see it actually causing problems because it's not like a kettle you keep refilling.
You only put in a few pints of water so you are only adding the one tiny amount of calcium.
If you don't have problems with local water doing that in kettles etc anyway, a complete non-issue.
Robby
Dirty Old Man
PostPosted: 13:08 - 23 Dec 2014    Post subject: Reply with quote
Even if you use hard water, the anti-corrosion elements of the coolant will cancel it out. It just won't last quite as long.
This is why I tend to buy pre-mixed coolant. It ends up costing me an extra £2/year.
weasley
PostPosted: 14:25 - 23 Dec 2014    Post subject: Reply with quote
Beat me to it. Windchill is a perceived temperature (due to heat transfer rates through the skin), not a real one. Bike's don't feel the cold.
The last post was made 11 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 91.04 Kb
