Rebuilt R1 clutch slipping, doubled diaphragm now too heavy!
Nope.
PostPosted: 00:35 - 28 Dec 2014    Post subject: Rebuilt R1 clutch slipping, doubled diaphragm now too heavy! Reply with quote
Hi All,
I recently installed a new clutch kit in my 03 R1 (5PW). I fitted new friction plates, steel plates and diaphragm spring. The old clutch was slipping badly (if you accelerated from around 110 it would just hit the limiter for ages until it caught again and it wouldn't wheelie at all).
So after soaking the new plates in oil for around 12 hours and installing them along with the new steels and diaphragm spring I went out for a ride (on private land obviously). It will now wheelie but it still slips when accelerating from 110+. I've doubled up the diaphragm spring with the old one which seems to have stopped it slipping but now the clutch lever is very very heavy and hard to use for slow speed manoeuvring.
So, what could be causing it to slip? If I fit a barnett spring conversion will this solve my issues or will it be just as heavy? It was all adjusted correctly.
Any advice is appreciated!
Fizzer Thou
PostPosted: 10:40 - 28 Dec 2014    Post subject: Reply with quote
Did the clutch basket look like this?
https://i1073.photobucket.com/albums/w384/Rhencullen5/Picture065.jpg
If so,the fingers could be dressed down with a needle file.
What engine oil did you use to soak the new plates and what do you use in the engine?
How many miles has the bike done?
Always have a 'Plan B'
Copycat73
PostPosted: 10:57 - 28 Dec 2014    Post subject: Re: Rebuilt R1 clutch slipping, doubled diaphragm now too he Reply with quote
think this is what caused the problem and
take it you put new springs in aswell.
caveat emptor
Nope.
PostPosted: 16:34 - 28 Dec 2014    Post subject: Reply with quote
Hi,
This is the clutch basket:
https://www.bikechatforums.com/files/clutch3-1.jpg
I used my nail on the fingers and couldn't really feel any notches big enough to warrant filing it down.
I used new oil, Motul 5100 10W40 fully synth (https://www.ebay.co.uk/itm/361148792220).
It's done around 27k miles.
Thanks!
PostPosted: 21:51 - 28 Dec 2014    Post subject: Reply with quote
I'm a great fan of going back to standard when this sort of problem happens. Go back to the standard diaphragm spring and settings and test again.
If it still slips I would wager there is something wrong in that the full spring pressure is not coming on the plates, and needs to be addressed.
If Mr Yamaha thought it needed 'doubled up' diaphragm springs, do you think he would not have fitted them?
In my business (marine engineering) we have a saying, 'Fix it, don't mask it' because marine engineer are the biggest bodgers on the planet. (way better than Paddy Laughing )
The last post was made 11 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 46.35 Kb
