Installing Oxford heated grip on a Street Triple
stuey2407
PostPosted: 17:35 - 03 Jan 2015    Post subject: Installing Oxford heated grip on a Street Triple Reply with quote
I started to install some Oxford Heated grips on my Street Triple today. There was no problem removing the existing grips and although I removed all the ridges on the throttle tube the grip is still quite tight to get on.
I will probably try to get the grip on with an inch or so left and then apply the super glue to the exposed part of the throttle tube and inside the grip before twisting it fully home. Is there anythings I could use to help slide the grip on which won't interfere with the adhesion of the glue?
The other question I had was the routing of the wire. There isn't much room where existing wiring enters the frame so I am planning on routing it in under from the tank through the space at the front to one side of the bolts. Any thoughts?
b422063
PostPosted: 19:18 - 03 Jan 2015    Post subject: Reply with quote
If you need time before it setting (superglue gives you about a minute before curing) then try epoxy?
Alternatively, ensure the grips are on full before putting them on. You'll find they expand slightly and slide on easier.
stuey2407
PostPosted: 19:54 - 03 Jan 2015    Post subject: Reply with quote
I think I have some araldite somewhere. Would that be suitable?
raesewell
PostPosted: 21:11 - 03 Jan 2015    Post subject: Reply with quote
Hair spray is recommended by many people
Yamaha FJR 1300 Normanton West Yorkshire
stuey2407
PostPosted: 21:22 - 03 Jan 2015    Post subject: Reply with quote
I used hairspray on the original grips but read that it doesn't work well with heated grips.
I also have some very good glue I use for arrow fletchings called Saunders Arrow Mate which sticks very well, doesn't go off too quickly and is not brittle. However I am not sure was it is like with high temperatures though.
blackbosh
PostPosted: 23:31 - 03 Jan 2015    Post subject: Reply with quote
The oxford glue eventually gave on the left side on my triple, with regards to your throttle side i kept smoothing the ridges until it went on with the same amount of force as the left side. The wires will easily follow the stock cables through the frame as well making for a neat install
b422063
PostPosted: 05:34 - 04 Jan 2015    Post subject: Reply with quote
Probably would, although as it's a brand name, there are so many products it's hard to tell which you're referring to. Remember the worst that can happen is either the grips stick well and are hard to remove once they're on or they don't stick at all. If that's the case, use something to clean the sticking agent (I wipe off using brake cleaner) and then try something else! Smile
barrkel
PostPosted: 06:36 - 04 Jan 2015    Post subject: Reply with quote
Do not use epoxy unless you want a right PITA taking off the remains of your grips should, down the road, they stop working and you need to replace them.
Two of the three bikes I bought second hand with heated grips, the grips stopped working in less than a year.
c_dug
PostPosted: 08:53 - 04 Jan 2015    Post subject: Reply with quote
I've not managed to properly stick mine in place at all yet using superglue, they still slide a small amount on the twist grip if I whack the throttle open, and I used a really decent amount last time.
To be fair I'm happy enough with the small amount of movement in exchange for the ability to remove them if/when I want to.
Had mine for about 18 months now and still going strong with regular use.
el_oso
PostPosted: 11:46 - 04 Jan 2015    Post subject: Reply with quote
I never glued mine, don't even think I used hairspray. They were just a really snug fit. Get a slight bit of movement but I'm OK with that, I can at least get them off if I need to.
Duke 390
Car: Jeep Wrangler 4.0L
The last post was made 11 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 64.11 Kb
