| Indianapolis |
 Indianapolis L Plate Warrior
 Posted: 20:56 - 06 Jan 2015 Post subject: 1992 Bandit GSF 400 won't fire |
Hello folks!
I also posted this on the Bandit Alley discussion forum today, no you aren't seeing double
I'm new here, I've been reading lots of posts on the GSF400. Great info! I am by no stretch of the imagination a mechanic. I'm more suited with welding and fabrication.
I just purchased a 1992 Bandit 400. The bike has 6,200 miles on it and looks nearly new. VERY little wear. Bad news is that it won't run.
Here is the story from the second owner: Bike purchased from original owner with 4,000 miles in 2011. Ridden for 2,000 miles in summer of 2011 until on day while riding in a sudden rain the bike ran rough and stalled out. Carbs were gone through and cleaned at this point and bike still refused to run so it was put in the corner of a garage and left until now.
Fast forward 4 years...I come along and buy the bike for not much money. I have the bike at a mechanic shop that specializes in Suzuki and is really experienced with fuel system, carbs and such.
He put a new battery in, cleaned the carbs entirely (pointed out that they had been drilled, he said the screws were backed out quite a bit, four turns I think) new spark plugs. He has an IV bag hooked up with fuel and the engine cranks strong but won't fire. He will clean the tank when he gets the bike to run and will change oil and oil filter. With starting fluid (ether) still nothing. He says the plugs spark against the block but not as bright blue as he thinks they should. He is stumped and asked that I look up some info on the web.
Using the search function here I came across a few posts that make me think that it may be the CDI. I can get capacitors and have an IT guy at work that can easily swap them out, he is great with circuit boards and such . I'll wait to do this until I for sure know it is the problem.
I keep thinking back on what the guy said about it stalling out in the rain, anyways, can anyone help troubleshoot this?
Thanks in advance, I know a heck of a first post  |
| bradh511 |
 bradh511 Scooby Slapper
 Posted: 22:49 - 06 Jan 2015 Post subject: |
I would suspect rain got into somewhere and caused said problem.. has he tried new plugs tested the coils.. and test the pickups ( magneto ) then it most likely to be cdi check and the kill switch
Also has anyone done a compression check ?
Also are the plugs getting wet when being cranked ?
Brad ____________________ Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013  |
| doggone |
 doggone World Chat Champion
| bypass2 |
 bypass2 Spanner Monkey
| Fisty |
 Fisty Super Spammer
| Indianapolis |
| Indianapolis |
| Indianapolis |
| Indianapolis |
| Indianapolis |
| Indianapolis |
The last post was made 11 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
