suzuki gp100 bogging
chrisjose1913
PostPosted: 00:12 - 07 Jan 2015    Post subject: suzuki gp100 bogging Reply with quote
Hello I have been trying to get my bike running
Anyway the Issue is related the the air flow
the bike only runs without the engine cover that goes over the carb.
anyway with a little research turn out some air vent pipe or something is not correctly fitted on my bike.
I have taken a picture from another bike and circled the pipe I am not sure about. I need to know where this pipe leads it has a metal bit on the other end of it.
1997 CB500
chrisjose1913
PostPosted: 11:13 - 07 Jan 2015    Post subject: Re: suzuki gp100 bogging Reply with quote
anyone ?
1997 CB500
PostPosted: 11:25 - 07 Jan 2015    Post subject: Reply with quote
The Orange Pipe on the Right looks like an overflow to me, it shouldn't be connected to anything.
Get a manual, Strip the carb completely clean it with carb cleaner making sure ALL the jets (Brass things with tiny holes) are Clear, Put it back together, WITH the air filter.
wodge
PostPosted: 11:27 - 07 Jan 2015    Post subject: Reply with quote
The brown pipe shown looks to be the float chamber vent pipe. Its job is to allow fuel to safely escape to a safe place if the bike is on its side. There might be a pipe missing for the float overflow on the bottom of the carb as well. These wont cause your problems unless they are blocked.
Have you tried stripping down and cleaning the carb without fiddling with the adjustments?
Its a 2T so look for air leaks from the crankcase/carb where air is not coming from the carb.
nolidge iz pouwur.
Yamaha RXS100 RS100
chrisjose1913
PostPosted: 12:31 - 07 Jan 2015    Post subject: Reply with quote
It's not an over flow pipe, From what i know it's a vacuum or some air vent, I have found a small hole that goes into the crank case exactly where the pipe ends up.
1997 CB500
wodge
PostPosted: 19:39 - 07 Jan 2015    Post subject: Reply with quote
2 stroke crankcases have to be airtight or the piston wont be able to suck in any air/fuel through the carb and I doubt its an autolube system. If it is the float chamber vent on the top of the carb and you connect it to the gearbox vent you could potentially be filling your gearbox with petrol.
I think an overflow pipe should also be connected to the nipple on the bottom of the carb next to the brass drain screw. If the float valve sticks or is not set correctly fuel will leak out of that bit.
These overflow or vent pipes don't usually go anywhere apart from down the side of the gearbox out of harms way.
Of course I might be completely wrong but try searching for an online copy of the Haynes or Suzuki service manual and find out. Smile
nolidge iz pouwur.
Yamaha RXS100 RS100
andyscooter
PostPosted: 21:23 - 07 Jan 2015    Post subject: Reply with quote
Will take pics of mine in morn and compere
andyscooter
PostPosted: 21:24 - 07 Jan 2015    Post subject: Reply with quote
cb1rocket
PostPosted: 22:46 - 07 Jan 2015    Post subject: Reply with quote
In reponse to one poster. It is an autolube system and the feed is directly behind the fuel inlet pipe on the left.
Strip carb, quite likely to be blocked esp the main jet
chrisjose1913
PostPosted: 00:53 - 08 Jan 2015    Post subject: Reply with quote
Thanks this will help loads Smile If you can also take a pic of were that line leads to that will help too Smile
1997 CB500
andyscooter
PostPosted: 16:33 - 08 Jan 2015    Post subject: Reply with quote
heres my carb on my gp
https://i206.photobucket.com/albums/bb129/andyscooters/bikechat2015045_zpsd72266b5.jpg
https://i206.photobucket.com/albums/bb129/andyscooters/bikechat2015046_zps78076b21.jpg
chrisjose1913
PostPosted: 19:28 - 08 Jan 2015    Post subject: Reply with quote
andyscooter wrote:
Do you have a photo showing where the pipe leads behind the carb ?
1997 CB500
cb1rocket
PostPosted: 21:12 - 08 Jan 2015    Post subject: Reply with quote
Andy are you running pre mix as your 2 stroke oil line isn't connected Shocked
Edit: Sorry looks like it is
The last post was made 11 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 80.33 Kb
