cornering in rain
stranger12
PostPosted: 21:27 - 08 Jan 2015    Post subject: cornering in rain Reply with quote
ever since I dropped my bike because of rain and mainly mud on the round about , half of me doesn't allow me to lean as much in rain and ride around like someone whom started to ride yesterday .
considering I am no pro but used to almost get my knee down in dry and in wet , I was a bit crazy by almost trying to much my lean angle as dry , I am now very dis appointed .
It is not that I am afraid , hell no but rather that moment when it slipped from under me and it was all happening in split of seconds and I couldn't control it stops me from leaning .
it is more been wise than scared.
what would you do ?
like today someone chasing me and got me really annoyed , I still couldn't push the bike round corners.
what do you consider a safe lean angle in rain ?
the faster you go, do you have more grip ? is there a chance of bike sliding under you on high speed corner or anything above 40-50mph?
I think when I dropped mine , it was mainly due to mud which even if you walked on it you would have slipped and secondly due to the fact I did not carry any speed (around 20-25mph ).
so I am thinking the faster you go the more grip you have and the more lean angle you can have
also I should say , I am very considerate of the icy conditions of the road due to the cold weather so it is not only the rain
SV650 Red
R6 Red
arry
PostPosted: 21:33 - 08 Jan 2015    Post subject: Re: cornering in rain Reply with quote
stranger12 wrote:
I am no pro
what would you do ?
Pretty much all of your post, but definitely the bits above, give the impression you're riding outside of your ability and understanding.
MUCH better to be wise and alive.
Nobody can give you an accurate figure of what lean angle to aim for. It's dependent on too many factors; tyres, tyre pressures, temperature, suspension geometry, weight, surface type, body position - the list goes on.
Just slow down, ride safe and build on your abilities progressively.
stranger12
PostPosted: 21:42 - 08 Jan 2015    Post subject: Reply with quote
Don't agree re riding outside my ability. How i phrase it is , i push myself to become better and never feel over confident.
In rain part of me says f**k it and nail it and the other part says be wise. I will lean as much as i feel comfortable but at the moment i am not even doing that and do a very basic ride after the stupid crash
SV650 Red
R6 Red
PostPosted: 22:01 - 08 Jan 2015    Post subject: Reply with quote
[edit] What arry said Thumbs Up
1st off don't get chased. You're making hard work for yourself if you're feeling vulnerable after a spill.
Grip is like the wind. It's rarely constant and like the wind it can seem to be worse in some areas.
Yes, going faster will increase available grip in certain situations.
Yes, going faster will decrease grip in certain situations.
Same goes for lean angle as most tyre profiles offer a bigger contact patch as the angle increases, but as you increase lean angle you reduce the effectiveness of your suspension, thus the tyre won't follow the imperfections in the road surface as well.
Tell you what to do.
Ride to the conditions i.e It's winter so generally ride a bit slower and always position yourself in the safest place with the best view. Corners, junctions..Move your head to help you steer correctly. Keep smooth on the controls. Greasy roundabouts and the like, that's where I'll keep the bike more upright by shifting my bum an inch or so (towards the inside of the corner) before I get to the skidpan.
bikertomm
PostPosted: 22:07 - 08 Jan 2015    Post subject: Re: cornering in rain Reply with quote
stranger12 wrote:
what would you do ?
Slow down.
Trackday.
One that doesn't cause you to chin the tarmac.
Seriously? Do you drive a formula 1 car on your wet commute to work?
Yes.
HTH Thumbs Up
Albigularis
PostPosted: 22:14 - 08 Jan 2015    Post subject: Reply with quote
I'd like to know what to do in wet corners in terms of keeping in the safe zone, as I've tried both of these methods and haven't had any slides related to cornering speed yet, so haven't had a chance to means test them.
Corner whilst leaning upper body as normal or more to stop the bike having to lean as far, thus being less likely to slide?
Or
Corner whilst counter leaning to keep the bike stable in the event that it does slide, even though this will incur a higher lean angle and (theoretically) have the bike more likely to slip?
Biking history so far-
Aprilia RS125 - Kawasaki ZXR400 - Triumph Street Triple R - Suzuki GSXR1000 L3 - BMW R1200GS - Kawasaki Z1000 - Kawasaki ZX10R C1H - Ducati Multistrada 1200 S Touring - Suzuki Hayabusa
Doovy
PostPosted: 22:17 - 08 Jan 2015    Post subject: Re: cornering in rain Reply with quote
Yes you are, pussy.
Just ride within your limits for the conditions, obviously.
PostPosted: 22:38 - 08 Jan 2015    Post subject: Re: cornering in rain Reply with quote
stranger12 wrote:
what would you do ?
Slow down so that I don't have to lean as much.
Shift my weight so that I can keep the bike more upright.
Not knee-down, just put weight on the inner peg and shift my arse slightly off the seat. I stress partially, a bit, in moderation.
You know this sort of drama doesn't regularly happen to everyone else, right?
pdg
PostPosted: 22:50 - 08 Jan 2015    Post subject: Re: cornering in rain Reply with quote
Of course it does, I get chased almost 3 times a day.
Oh.
Wait....................
No I don't.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
robertw95
PostPosted: 22:58 - 08 Jan 2015    Post subject: Reply with quote
Winter times not the time to try and get knee down like you can in summer, when was the last time you checked tyre pressures? Probably a mental thing after your off happens to us all but i'd give the pressures a check for piece of mind
07 Dt125r, sv650s k8, zx6rr 04
Wull
PostPosted: 23:18 - 08 Jan 2015    Post subject: Reply with quote
Its not all about lean angle,what you want to do is reduce the centre of gravity by shifting your body weight to the inside of the corner,this method works perfect in the wet conditions as it allows you to corner at the same speed but with less lean angle,keeping the bike on the fatter part of the tyre reducing the chances of wiping out.
One of the best racers to watch utilising this method is pedrosa,as he powers out of the corner he stands the bike up whilst still hanging off.
I love wet weather riding as its all it ever does up this way,and I like to push hard and this works wonders.
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
barrkel
PostPosted: 23:23 - 08 Jan 2015    Post subject: Reply with quote
Someone chasing you probably just wants to go faster than you; or they think you're racing them. But more likely the former.
I now lean a lot less in the wet than the dry. I've had a number of wheel slips in the wet, and most of my non-collision accidents have been in the wet. There's more variance in wet grip and for any given route, the minimum grip on a wet road will be lower than dry. Pushing it on roads with uncertain amounts of oil, diesel, mud etc. isn't worth it.
Keeping the bike upright in the wet, for me, has been more about giving the bike more space to regain grip before hard parts lever the tyres off the ground. Makes it a bit more likely to highside though.
On a wet road, I try to take more pleasure in making good progress smoothly and with less risk, whereas dry will bring out more of my flicking tendencies. But the wet skills are actually good in the dry too, not quite as much fun, but they are the skills needed when riding faster.
andi
PostPosted: 23:45 - 08 Jan 2015    Post subject: Reply with quote
Positive countersteer! You may be avoiding countersteering without realising it.
Before: Suzuki GT 185. Honda Superdream 250. Yamaha RD350LC. Suziki RG250. Yamaha FZS600. Honda CBR600F3
Now: Honda Fireblade 929
stranger12
PostPosted: 23:53 - 08 Jan 2015    Post subject: Re: cornering in rain Reply with quote
DoovyRR wrote:
Yes you are, pussy.
We are the same then !
Good tips and views from last few posts .
When i say someone chasing me , i un necessarily get into race when tempted and most of the time leave them behind fair bit but then i want to avoid and control the temptation:D as silly as it may sound
SV650 Red
R6 Red
Dave70
PostPosted: 00:24 - 09 Jan 2015    Post subject: Reply with quote
Take note of the advice already given above, as it's pretty much spot on. Thumbs Up This is not the time of year to be trying to push you or your bikes limits, especially around corners.
Wait until the summer arrives, when the roads are a lot more dry and sticky, then lean your bike as much as you dare. You'll soon find the limit. Wink
stranger12
PostPosted: 00:36 - 09 Jan 2015    Post subject: Reply with quote
agree and thanks for great info
I have just been a kid and a bit silly
SV650 Red
R6 Red
XBIKER
PostPosted: 03:07 - 09 Jan 2015    Post subject: Re: cornering in rain Reply with quote
So what happens when the chaser has better / newer wet weather tyres / technique and flies past you, do you chase him/her only to discover yours aren't as good? OR that he/she knows the road better than you
In the past I have had to ride quickly in the rain/downpours etc but the main thought in my head was to reach the destination safely.
Riding in wet conditions is something you will get used to if you have to do it for long enough and increased speed comes with experience and confidence.
There are a whole host of different road scenarios from just wet, rain , wind swept rain, winter with leaves on the road, branches on the road, potholes, mud slippery roundabout markings, drain covers etc and you will probably fall off on most of the above before becoming a more experienced rider.
The only nice thing about rain is you slide better when you fall off. Laughing
Don't ride too fast in the wet unless you really have to or you are being paid to do it. Shocked
Keep it between the hedges.
DrDonnyBrago
PostPosted: 08:55 - 09 Jan 2015    Post subject: Reply with quote
BCF should have a retard amnesty.
andyscooter
PostPosted: 09:11 - 09 Jan 2015    Post subject: Reply with quote
was on a ride course two days ago
was told over 60% of bike crashes only involved one vehicle
with people like this about i can now sort of see their point
its raining you have a 50p size patch of tyre in contact with the road
slow down
dont try and lean as much Shocked
who cares if someone else is faster are you riding for them or you
LustyLew
PostPosted: 11:21 - 09 Jan 2015    Post subject: Re: cornering in rain Reply with quote
Why do I read this as "someone passes me, so I crank the throttle wide open to prove I'm faster, but then fuck up the corners..."
90% of my riding is commuting to work. When it's wet and miserable I tend to suck at cornering. There's paint, man hole covers and shitty road surfaces to think about. Not to mention, cars following close, the compulsory 50cc ped in your blind spot, cyclists and pedestrians.
Wet weather means we have to think about what we're doing a lot more. I do find relaxing and trying not to analyze toe road too much helps.
I have a had habit of 'covering' my brakes when leaning into a corner, I know braking in a corner is bad, even more so in the wet. So I try and force myself to not touch them. I ride well within my BIKES limits, I need to trust it more than me.
Snowdonia Rider
PostPosted: 11:39 - 09 Jan 2015    Post subject: Reply with quote
Don't get egged on by other people, ride for the enjoyment of riding bikes and not to be king of the road.
kramdra
PostPosted: 17:27 - 10 Jan 2015    Post subject: Re: cornering in rain Reply with quote
My commute has some scary sections with lose dirt and mud all over the road. The road is narrow with mud banks which cars like to hit, dragging it into the centre. On Thursday, 3 blind bends were fully flooded (oncoming cars are fun), and at <20mph riding on the dirt river both wheels were sliding Shocked
So its the dirt and gravel Im worried about, rather than rain.
Id like to see you getting knee down there. (Ashurst to Steyning). Its quite nice in the summer though.
Dual carriageway can be ridden similarly to dry weather, just being far more cautious of car drivers.
Iain.
PostPosted: 18:26 - 10 Jan 2015    Post subject: Re: cornering in rain Reply with quote
Have you spoken to Bodyguard lately?
Slacker24seve...
PostPosted: 19:04 - 10 Jan 2015    Post subject: Reply with quote
This thread reaffirms my belief that stranger12 is full retard.
Banger rallies are ace
BMWilliams
PostPosted: 14:11 - 11 Jan 2015    Post subject: Reply with quote
In the words of RJ only ride to 70% of your ability leaving the other 30% to get out of danger
https://youtu.be/iSgIB4ZkeCk
A good long ride can clear your mind, restore your faith, and use up a lot of fuel.
Never ride faster than your guardian angel can fly.
Ride, eat, sleep...repeat.
The last post was made 11 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.51 - MySQL Queries: 13 - Page Size: 137.3 Kb
