fork sound
Random13
PostPosted: 20:30 - 08 Jan 2015    Post subject: fork sound Reply with quote
Hi ,
I am starting to notice a click or rather sometime bang from my forks. it only happened since winter started , can it be due to oil that it has lost its qualities and during cold it gets stiff and plays up ?
thanks in advance
pdg
PostPosted: 21:04 - 08 Jan 2015    Post subject: Reply with quote
When does it specifically happen - when going over a bump or say when you brake?
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Random13
PostPosted: 13:47 - 09 Jan 2015    Post subject: Reply with quote
I can hear it when stand still and turning the steering side to side . This is not very often.
but the clicking in on braking I would say
CaNsA
PostPosted: 13:49 - 09 Jan 2015    Post subject: Reply with quote
Headstock bearings.
pdg
PostPosted: 13:58 - 09 Jan 2015    Post subject: Reply with quote
CaNsA wrote:
Headstock bearings.
This.
Sit on the bike, not running, pull the brake lever and rock the bike back and forward. You'll probably get 'clonkclonk'. If they are very gone or loose you might even see the top yoke moving relative to the frame...
whitedevil
PostPosted: 14:01 - 09 Jan 2015    Post subject: Reply with quote
You can also tip the bike towards you onto the side stand so the front wheel lifts off the ground, now turn the steering lock to lock slowly, you should feel any notchiness if present.
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
pdg
PostPosted: 14:05 - 09 Jan 2015    Post subject: Reply with quote
OP said a knock... Head bearings can be notchy as hell but not clonk, or clonky and perfectly smooth to turn because they are simply loose.
MarkJ
PostPosted: 14:10 - 09 Jan 2015    Post subject: Reply with quote
I once fitted some headstock bearings with rubbish seals, which let dirt get past the seals which would make the steering click as you turned it, so could be headstock bearings. Possibly could be fork bushes being worn. Unlikely to be wheel bearings but worth checking just to be sure.
pdg
PostPosted: 14:15 - 09 Jan 2015    Post subject: Reply with quote
There's also the possibility of loose pinch/spindle bolts, loose caliper, cracked frame............
MarkJ
PostPosted: 14:21 - 09 Jan 2015    Post subject: Reply with quote
Some bikes also have a bit of space inside the calipers so the pads can move a little, which can mean they click a little when being rocked back and forth as they move up and down in the caliper, the Honda Hornet does this. What bike is it?
mentalboy
PostPosted: 14:42 - 09 Jan 2015    Post subject: Reply with quote
Is it the same 'bang' as mentioned here?
It is easier to keep a thread going on the same topic, rather than starting a new one and needing to repeat all your details.
Make mine a Corona.
Random13
PostPosted: 07:34 - 13 Jan 2015    Post subject: Reply with quote
nope it is not the same bang .
it is a cbr 600 . i did lift the front and moved it side to side but still no sound or roughness.
short of ideas on what it can be
RhynoCZ
PostPosted: 07:48 - 13 Jan 2015    Post subject: Reply with quote
Are all the cables routed properly? Also check the front wheel bearings and tightness. Also the pads might be moving there, to check that, pull the brake lever so the pads are fixed (pushed onto the discs), then do the left right thing. My pads do it, they are nearly done though - Nissin 4 pot calipers from the late 80's. Thinking
Suntan Sid
PostPosted: 08:40 - 13 Jan 2015    Post subject: Reply with quote
Had the same on my CBR 600.
It would make a clunk when you first sat on the bike and also when you stopped, it was more noticable braking from low speed.
The head stock bearings were not seated correctly, the castlated lock ring had not been tightened correctly and the bearings had worked loose!
Random13
PostPosted: 19:54 - 13 Jan 2015    Post subject: Reply with quote
many thanks ,
@RhynoCZ, what do you mean by this ?
RhynoCZ
PostPosted: 20:20 - 13 Jan 2015    Post subject: Reply with quote
Me engrish no good here.
When you generate pressure by squeezing the brake lever, that pressure will push the pots out of the calipers. Those pots will push the pads onto the brake discs. This way the pads may not move freely, as they would when there is no pressure in the system and the pots are back in the calipers. More worn the pads are, more space to move they've got.
I experienced the same thing as you have. The motorcycle was standing still, I was checking whether the bars were locked (moved the bars left/right a bit) and I heard knocking. I found out there's freeplay in the pads, I could literary move them with my finger and reproduce the knocking sound.
Also, moving pads may result in the good old squeaking, when making full stop. Which mine do, a lot. Yes, I'm getting a fresh set of pads for the spring.
If that does not make any sense, then I am done here. Thumbs Up
Random13
PostPosted: 20:39 - 13 Jan 2015    Post subject: Reply with quote
makes perfect sense, thanks Very Happy
YBR Ric
PostPosted: 21:31 - 13 Jan 2015    Post subject: Reply with quote
Thumbs Up +1 for brake pads moving around in the calipers.
I adjusted my headstock bearings twice before realising this, but at least they ended up with better clearance than when it came off the assembly line Very Happy
RhynoCZ
PostPosted: 21:42 - 13 Jan 2015    Post subject: Reply with quote
Cool, let us know, what was it. Smile
Yes, I was nearly there too, I mean the bearings. Then, I accidentally squeezed the front brake and found out, the knocking stopped. Smile
The last post was made 11 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 99.89 Kb
