Starting issues
lee8040
PostPosted: 17:28 - 09 Jan 2015    Post subject: Starting issues Reply with quote
My bike is not starting, when I press the ignition I just get a clicking noise. The battery failed due to the cold not holding charge so got another one. When I have the charger connected and the volts around 13v it just clicks and fails to turn over. What would this problem be?
Bikes a suzuki gs500 1993
RhynoCZ
PostPosted: 17:30 - 09 Jan 2015    Post subject: Reply with quote
Bad ground somewhere.
lee8040
PostPosted: 17:39 - 09 Jan 2015    Post subject: Reply with quote
Should point out the 2nd batt doesn't appear to be holding a charge well so going tore place it but shouldn't a charger connected to the batt putting 13v through start the bike?
PostPosted: 17:41 - 09 Jan 2015    Post subject: Reply with quote
Check regulator and the main fuse on the starter solenoid.
lee8040
PostPosted: 18:01 - 09 Jan 2015    Post subject: Reply with quote
How do you check the regulator? If the fuse had gone woulditbe still click?
RhynoCZ
PostPosted: 18:07 - 09 Jan 2015    Post subject: Reply with quote
It's not the regulator, locate the starter solenoid, take it off, and clean the contacts of it. If that won't help, then the starter might be sticking, or the grounding of the starter is corrupted.
EDIT: Or the solenoid is done, of course. Thumbs Up
lee8040
PostPosted: 20:54 - 09 Jan 2015    Post subject: Reply with quote
The old battery won't hold the charge it slowly drops but when connected to the bike it will light the ignition lights etc but won't turn over just clicks. The new battery is faulty the volts drop from 13 on charge to 1 in seconds so this is going back. On the bike it shows no lights and no clicking
pdg
PostPosted: 23:51 - 09 Jan 2015    Post subject: Reply with quote
A charger connected would start the bike - if said charger was capable of delivering over 100 amps...........
If you have a 'normal' charger capable of putting out like 6 amps (at a push) then the relay would click. If you have something like an optimate it might not even do that.
Voltage without current means nothing.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
lee8040
PostPosted: 06:54 - 10 Jan 2015    Post subject: Reply with quote
I have a halfords 2-4 amp charger for bikes. That would def not turn the bike over would it?
Taught2BCauti...
PostPosted: 14:18 - 10 Jan 2015    Post subject: Reply with quote
It might be just enough to test the solenoid off the bike - I have a bench power supply that I use for testing stuff like that, and that is set at 13.8v and 2.4A max.
It's plenty for the solenoid, but wouldn't be anywhere near enough to spin the starter motor.
I always think that when you have electrical problems, you need to start by making sure the battery is good, and all earthing points between battery, frame and engine are solid.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
lee8040
PostPosted: 14:20 - 10 Jan 2015    Post subject: Reply with quote
Bought a new battery today just on charge so will test in a few hours
cb1rocket
PostPosted: 15:57 - 10 Jan 2015    Post subject: Reply with quote
Bridge the contacts of the solenoid with a screwdriver and see if it cranks
lee8040
PostPosted: 16:00 - 10 Jan 2015    Post subject: Reply with quote
New battery on fires up straight away. Other new one was faulty and not holding a charge.
Thanks for your help guys
Iain.
PostPosted: 17:03 - 10 Jan 2015    Post subject: Reply with quote
So, if a regulator fails and it stops charging the battery alltogether that couldn't possibly cause the previously good battery to become flat?
inb4 "It's happened again" and turns out that the GS has decided to convert itself to total loss electrics. Laughing
The last post was made 11 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 80.26 Kb
