Brake upgrade
stranger12
PostPosted: 22:59 - 09 Jan 2015    Post subject: Brake upgrade Reply with quote
Hi ,
From following which ones do you pick for brake performance ?
Braided lines
Brembo master cylinder
Discs
Looking around people say the beaided lines provide the most improvement followed bu brembo master cylinder.
Do you think it is worth it for road and occasional track riding ?
SV650 Red
R6 Red
Wull
PostPosted: 23:04 - 09 Jan 2015    Post subject: Reply with quote
As its not that expensive I've always found the brembo m/c and braided lines to be the best bang for buck with regards to improvement with braking.
On my R6 that I had a few years back I went the full hog and had pfm discs but I'd of been happy enough with just the m/c and lines as the improvement was good enough.
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
RhynoCZ
PostPosted: 23:06 - 09 Jan 2015    Post subject: Reply with quote
I heard, the blue spot brakes were the top notch. Thinking
Commuter_Tim
I hear that it is worth upgrading your brakes, if you want to stop that is.
Stopping is overrated, coming to a rapid stop on a motorbike can be dangerous. Folded arms
I ride a Bandit 600... badly.
lihp
PostPosted: 23:43 - 09 Jan 2015    Post subject: Reply with quote
Why do you want to upgrade the brakes?
Teflon-Mike
tl;dr
PostPosted: 02:18 - 10 Jan 2015    Post subject: Reply with quote
Couple of old addages for you;
KIS-KIS.... Keep it Simple - Keep it STANDARD
Before looking for MORE than 'Standard', make sure you have what you should AS standard.
To-Wit... start by stripping and cleaning and greasing what you got; dumping the old hydraulic oil and adding new, then bleed diligently...
NEXT? New pads.. you have some discretion over grade.
I wouldn't swap out OE discs unless they were past wear limit, damaged or warped; they are usually 'better' than after-market replacements.
Hoses? I like Aeroquip braided lines; but the 'improvement' they offer is much over-rated and exaggerated by usually replacing tired reinforced rubber, full of shitty milky fluid.
Master-Cylinder? On a road-bike? I wouldn't want the 'hassle' of insurance ramifications, either declaring it as a 'mod' to a safety critical system, or not declaring it... without the brain bending of doing the maths to work out the right cylinder sizing for the caliper(s), to be sure it would actually work and give some advantage..
mentalboy
PostPosted: 04:20 - 10 Jan 2015    Post subject: Reply with quote
For what? I think that every 'blue spot' caliper I've worked on has had rusty pistons and needed them replacing (or worse still the whole caliper). Maybe it's because people think they're so great that they neglect to service them until they are beyond recovery??
Edit: OP - braided lines will give your brakes a much more positive feel as they don't expand like rubber unbraided hoses. As for calipers and discs it does depend very much upon what you intend to do with the bike, what bike it is and what is currently fitted to it.
Make mine a Corona.
pdg
PostPosted: 04:56 - 10 Jan 2015    Post subject: Re: Brake upgrade Reply with quote
Braided lines
Discs
Even if you have all 3 of those things, your brakes will be absolutely crap.
You will also need caliper(s), pads and fluid.
Also, a means of attaching the whole shebang and something to attach them to that requires brakes.
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
talkToTheHat
PostPosted: 05:28 - 10 Jan 2015    Post subject: Reply with quote
Standard brakes on a sv650 are perfectly capable of breaking traction at the front or lifting the rear wheel.
Braided lines will give you a more direct and firmer feel than standard lines, and if your standard lines are worn out stretchy things then braking force transmitted may be significantly improved. As a side effect you will have fresh brake fluid. Flush your system evey 2 years or as recommended in your service manual.
A change of master cylinder will change what I am going to describe badly as the gear ratio of your brakes, a narrower diameter master will have more travel for a given movement of the caliper and force at the lever will be proportionally amplified. The inverse is also true. Beware of increasing lever travel to the point where you don't have enough room for fingers, or decreasing the ratio to the point where you cannot brake hard enough. Here be dragons. As mentioned previously, your insurers will hate this.
Pick road pads for feel, experiment with diferent brands and be aware of what happens in the wet. If for some reason you have organic pads in there, bin them. Consider using different pads for dry track days than you would on the road, as on the track break fade is an issue but you can use pads that don't work well without a little heat in them, whereas on the road instant cold performance is required and you are unlikely to be putting as much heat into the brakes by repeated hard braking.
Note that as well as the friction and temperature performance of a brake compound, the feel comes from the compressibility.
Cheapest mod is to keep your brakes bled, pistons clean and free-moving and your friction surfaces clean. Can be surprising, I finally got round to new brembo front pads in the Autumn and was most dissapointred as I was bedding them in only to spray a little cleaner on the front disk and then nearly headbutt the bars the next time I applied the brakes. I think this was about getting rid of material from the old ferodo organics that had transferred, as the brembos have been alright since.
Be careful not to wash silicone grease or copper grease from the calliper onto the friction surfaces when using brake cleaner.
Bandit. does. everything.
stranger12
PostPosted: 06:48 - 10 Jan 2015    Post subject: Reply with quote
sorry for the confusion , this is for the r6 . As I said, I am happy with the brakes but came to mind, If I can improve them then it is a worth while investment.
So far,
I have cleaned the caliper and changed all seals just few month ago
EBC sintered pad in front
changed the brake fluid
based on some advice and my research ,
braided lines provide the most performance gain so I will be looking at getting a set . what brand do you recommend ? How do I know my rubber lines are expanding , by checking them as I am squeezing the brakes?
now re master cylinder, some peopleswear by them saying how much improvement it provided. Are we saying it doesn't and it changed the firmness of the brake by using longer or shorter stroke pistons ?
Would you invest in brembo mc ?
re discs, I thought the wavy ones were the latest but then people say they are not great as you don't have that much surface as the normal disc. So I then thought, I can upgrade mine from 300mm to 320 which will provide an improvement , will it not ?
assuming mine is 300 mm?
re calipers, I think they will not make any difference unless I get something with bigger pistons or more pistons
SV650 Red
R6 Red
stranger12
PostPosted: 07:03 - 10 Jan 2015    Post subject: Reply with quote
on a separate note, do you wipe the brake cleaner from disc after it is applied ?
SV650 Red
R6 Red
temeluchus
PostPosted: 07:43 - 10 Jan 2015    Post subject: Reply with quote
The whole point of aerosol brake cleaner is that the spray is the very last thing to go near the brakes. Use the pressure of the spray to blast any left over muck off. Do not touch the brakes with anything after you've blasted them thoroughly.
All iterations of the R6 have good brakes from the factory. If they are working, leave them.
stranger12
PostPosted: 07:54 - 10 Jan 2015    Post subject: Reply with quote
bought a set of race hel braided lines from helmobile for £69 which is usually £90. I used the code "forum" Very Happy
that is for anyone wanting to buy braided lines and save
re spray , so it is ok to spray and start riding ?
how often would you do it ?
I know the brakes are great but just want to improve them if I can
SV650 Red
R6 Red
Fisty
PostPosted: 08:54 - 10 Jan 2015    Post subject: Reply with quote
So Mike, all your bikes have OEM tyres, bulbs, filters etc? How about you bearings do you get all those from Honda? If not the are counted as a modification as they are not standard fit.
I have a new addage to stick to MFOUS:- Mike's Full Of useless Shit.
Some people (myself included) enjoy modifying bikes, to make them better than standard and have a bit of fun experimenting in the process. Most bikes are built to a budget (christ you should know with your insistance on whoring ancient poverty spec 125's) and can be improved upon with readily available upgrades which are proven to work.
Back on topic, after experimenting with MANY set ups on the TL, I found that a Brembo 19x20 radial master cylinder, Braided hoses, and Brembo sintered pads gave far better braking than a well maintained standard set up.
The above feels much more progressive and allowed me to brake a fair bit later. The Brembo pads also had next to no fade even after a good session at Donnington, compared to the SBS pads I used to use.
Fatter and faster than Fret
stranger12
PostPosted: 09:46 - 10 Jan 2015    Post subject: Reply with quote
I will try brembo next as mine is currently ebc sintered
Re master cylinder, what is 19x20 or 18x..?
SV650 Red
R6 Red
Taught2BCauti...
PostPosted: 10:59 - 10 Jan 2015    Post subject: Reply with quote
I would always fit stainless braided brake hoses if nothing else. Keep the rest of the components in good order and you will be fine.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
mentalboy
PostPosted: 15:12 - 10 Jan 2015    Post subject: Reply with quote
That is what 'talktothehat' posted about altering your 'gear ratios'.
Regarding your earlier query about how do you know your rubber lines are stretching/giving when braking. Easy... they are rubber!!! Braided lines basically mean your rubber lines are wearing a strait jacket which helps prevent line distortion when braking - thus hydraulic pressure is transferred more efficiently to your calipers rather than losing energy as it tries to escape through the side wall
Make mine a Corona.
PostPosted: 20:44 - 10 Jan 2015    Post subject: Re: Brake upgrade Reply with quote
stranger12 wrote:
Hi ,
Braided lines
Discs
Depends on the bike and the actual problem you are trying to fix
Lines covered in braided steel are claimed to expand less. In practice it depends on the condition of the standard lines. Main advantage is that it forces you to bleed the brakes properly
Master cylinder wise, depends how well matched things are. Most bikes are pretty decent on this (an exception was my Bimota - standard m/c was badly mismatched with the Brembo calipers, and the brakes had a very dead feel). In simple terms a larger bore master cylinder gives less lever travel but less feel. Smaller master cylinder bore gives more feel but lever travel might be excessive.
Disks, not that much to be gained and will also likely only improve things if the replacement disks match the pads you use with them.
There are 2 ratios with master cylinders, relating to the master cylinder bore and the position of the master cylinder bore relative to the pivot point of the lever.
talkToTheHat
PostPosted: 15:04 - 11 Jan 2015    Post subject: Reply with quote
With brake cleaner, spray and ride is fine. Wipe with something very clean if really dirty or not immediately moving, I use a fresh blue disposable shop towel if i need to (like kitchen paper for bikes, find in automotve shops or b&q)
Thanks Keith, I'd missed the lever ratio from the brake lever behaviour. Some voodoo required in measuring where the braking force is applied, don't measures from end of lever to pivot. 2 finger beakers should probably measure from the point between where index and middle fingers touch the lever, 4 finger brakers from under the middle finger. Brake levers aren't straight the axis of the master cylinder is often different to axis of squeeze, so just treat each force and distance as a torque about the pivot pin and the maths will all make sense again. Compounding lever and hydraulic ratios just like gear ratios.
Lever ratio is effective lever lenght / pivot distance
Hydraulic ratio is slave piston surface area / master cylinder surface area
but throw away pi, it cancels out, just add up the squares of each slave piston diameter and divide by the square of the master cylinder bore.
The numbers with a master cylinder are the bore diameter and pivot distance. The RCS system has two position can adjustable pivot distance.
If you increase disk diameter you will need to relocate the callipers, whether this is a spacer or a different mount I do not know, but it is not just the disks. Decreases the lever ratio between road and caliper, disks will lose heat faster and last longer, but increased rotating unspring mass may slow your steering and alter suspension behaviour. You'd better know what you're doing here.
Seriously, braided brake lines before you mess with master cylinders, otherwise your investment will be a waste. Improved feel, not particularly expensive.
For clarity's sake I'm riding an old bike that is not sports oriented. My front brake pad choice was about feel and response in the wet, and I dont think the particular pads fitted are much different to ebc organics on a dry day. 'Performance' pads just don't exist for my caliper. Still stops faster than I am prepared to routinely ride on the road.
If you're happy with how the bike stops but still want better, I understand that, have been there as a teen with karts and R/C. Try to reconcile this conflict before the money runs out. I think you'd get the most out of upgrades that improve feel over pure performance as you probably won't get everyhting your bike has to give unless you are racing at a high level.
I recall an issue of Ride featured an article on dedicated braking instruction days, perhaps such a short course might be of use and help you get your moneys worth out of the brakes?
Commuter_Tim
PostPosted: 18:20 - 11 Jan 2015    Post subject: Reply with quote
OP did have an off recently and was partially mocked in his thread asking for assistance...
Is it possible he is clutching at straws down the avenue of brake upgrades to boost his confidence?
mentalboy
PostPosted: 20:00 - 11 Jan 2015    Post subject: Reply with quote
Although if I understood him correctly it was probably thanks to mud on the road and in this case sharper braking would have just resulted in a quicker lock-up.
For wintry, slippery conditions I think it'd probably be better not having precise hard feel brakes because you are less likely to lock them up when you grab a handful (Obviously not too relevant if you have ABS on board!)
Make mine a Corona.
talkToTheHat
PostPosted: 01:02 - 12 Jan 2015    Post subject: Reply with quote
Having written off a 125 locking up after a goon pulled out on me and had two minor drops from being hamfisted on wet leaves and slimy post-flood roads I feel OP's pain. But sharper track focussed brakes are as said above likely to be counter productive.
Modifications for better feel mean more control. Worth doing.
Modifications for more 'bite' are likely to bite a hamfisted or inexperienced rider. Worst are brakes that don't do anything and then suddenly grab. The organics that were on mine when I got her were like that particularly in the wet, nothing then loads. I've driven a few track cars that were like that too, fortunately with fucking brutal abs. Carbon on Carbon race brakes are probably the worst for this.
Best advice though is ensure fitted hardware is connected by good lines and fluid with no air bubbles, then learn to use said hardware, with an instructor if nessarcary. Most bikes have significantly better brakes than riders.
stranger12
PostPosted: 08:16 - 13 Jan 2015    Post subject: Reply with quote
thanks, not really it is not too boost my confidence , just came to mind and wanted to upgrade it if i can .
I will leave the mc out as , as far as I understood from the posts , it is purely to change the feeling of how the bike brakes but no improvement, right?
I have ordered a hel braided lines and also castrol dot4.
I used to get brake fades in street on days that I was pushing it very hard so am narrowing this down to my poor dot 4 as brake pads are ebc sintered so all ok there.
with brake fade, is it the fluid that can cause it or the pads will also do ?
does disc also play a role ?
I should say , I changed the fluid about 3 month ago with pagid dot4 which has been setting in my garage for over 4 years in a 4 liter gallon but the lid was closed so should have not absorbed water or moisture
SV650 Red
R6 Red
evoboy
PostPosted: 10:20 - 13 Jan 2015    Post subject: Reply with quote
Change the pads.
EBC Sintered are naff. SBS, Carbon Lorraine, Brembo, Bendix, DP, all give much better initial bite which will feel like you have upgraded.
APT Motorcycles
Matt B
PostPosted: 11:10 - 13 Jan 2015    Post subject: Reply with quote
evoboy wrote:
Change the pads.
This Thumbs Up
Quick, easy, cheap and simple. SBS pads get my vote.
The last post was made 11 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 140.27 Kb
