| daemonoid |
 daemonoid World Chat Champion
 Posted: 11:26 - 10 Jan 2015 Post subject: Weightlifting... |
I've been 'stronglifting' for a few months now. As you'd expect I want to judge my progress, but it turns out that everyone on the internet is a super athlete who can benchpress my Monster with out even breaking a sweat.
I've finally come across https://www.exrx.net/Testing/WeightLifting/StrengthStandards.html which seems a reasonable guide with a lot less bullshit. The numbers match my reality, especially considering I started the program cold (ie. 0 fitness after years in an office job).
As it's the auntie section I guess I need some help too - overhead press is killing me... I'm hitting a wall at 42.5kg. With the barbell row I hit trouble and managed to breakthrough by doing some actual rowing (well in a rowing machine anyway). But, what cardio type or highly repetitive exercises could help with a press? ____________________ current: ducati monster 750
@thomasgarrard | www.straitjkt.com | www.racingseven.com |
| Benjums |
 Benjums Scooby Slapper
| G |
 G The Voice of Reason
 Posted: 14:13 - 10 Jan 2015 Post subject: Re: Weightlifting... |
This is another good site, as it works it out for you: https://www.strstd.com/ .
Of course it's all indivdual etc; I was surprised where I came on there when I was making an effort (have had to give it a rest for injured stuff to recover.)
I wouldn't have thought most cardio stuff would help too much.
Are you doing strong lifts as in the program? I've done starting strength, which is similar.
Have you done 'resets' where you reduce the weight and build back up? |
| daemonoid |
 Posted: 14:57 - 10 Jan 2015 Post subject: Re: Weightlifting... |
| Benjums wrote: | Doing weight lifting you are always going to hit a level at some point. When I was in the gym hitting the weights and hit a level I would always drop back a few kg and do more reps. So for argument sake your struggling at 43 kg, drop it down to 25 or 30kg and instead of 10 reps at 43 try increasing it to 20 reps, or go lighter and do as many reps as you physically can. I used to do this for a couple of weeks then build up the weights again, you usually find that you will go past your weight then. This worked for me hopefully will work for you. |
The program I'm on does de-loading, but not upping the reps past 5x5 I'm going to continue while I'm getting results in the other lifts. It's accessory exercises I'm really after.
| G wrote: | This is another good site, as it works it out for you: https://www.strstd.com/ .
Yes stronglifts 5x5, I quite like the program itself and am still progressing in general on it. The rowing really helped my barbell rows so I'm sure there's some benefit that can be found from exercises that are not directly strength related. I'm fairly convinced that cardio type accessory exercises are the way forward at my current level.
I've done two small resets - after Christmas and after a long business trip. But the other lifts are still increasing so a full program reset or switch is not yet.
The strstd is a good site, based on the same data which all seems to be from an old book, there's no modern update as far as I can tell:
https://oi53.tinypic.com/x0ph54.jpg ____________________ current: ducati monster 750
| GhostRider |
 GhostRider World Chat Champion
| Jewlio Iglesias |
 Jewlio Iglesias Banned
 Posted: 16:15 - 10 Jan 2015 Post subject: |
I imagine lb's, because 165kg, is like, well, massive  ____________________ 21:41:40 petalbriefs: look phil, I dont preach to you about bowling pins or whatever, so you stick to that and I'll stick to cars
21:38:18 Northern Monkey: chav lives in the garage with an almax on it
21:34:54 rhys99: My train got stuck in heavy traffic |
| Llama-Farmer |
 Llama-Farmer World Chat Champion
| daemonoid |
| daemonoid |
| bEN_ |
 bEN_ World Chat Champion
 Posted: 17:25 - 10 Jan 2015 Post subject: |
I tend to take everything i read about lifting in general, nutrition etc with a pinch of salt, it's different for everybody.
But as i type this, i've been a plonker and didn't do any proper warm up so i'm sat here with an ice pack on the top of my back as it feels like i've pulled something, had to drop the weights straight away  ____________________ 2010 Ducati 848 Dark
Lamp Post Enthusiast |
| Eddie Hitler |
 Eddie Hitler World Chat Champion
| GhostRider |
| G |
 Posted: 18:32 - 10 Jan 2015 Post subject: |
I got to Advanced or close in most lifts by keeping the same routine for six months .
But yes, if repeated stalling, I'd certainly consider mixing it up a bit, throwing in some 'accessory' lifts etc. |
| daemonoid |
 Posted: 19:48 - 10 Jan 2015 Post subject: |
| G wrote: | I got to Advanced or close in most lifts by keeping the same routine for six months ;).
Advanced in most lifts? From what start point? Surely not desk job->advanced in 6 months?
| Eddie Hitler wrote: | Am advanced on most lifts. Trick is variety in your training, don't go in and do the same old routine for 6 months. |
I've heard the exact opposite advice. Why do you say that's the trick? And what do you have to back that advice up?
Not being confrontational, it's just there's so much advice around and none of it is consistent.
| GhostRider wrote: | Went back at looked at the link in first post, seems about right, at my peak I was just under the advanced category for most exercises and I would agree with the benchmarks for the previous categories also as a roundabout figure.
GhostRider |
I've had a bit of a better look and actually, doesn't look like my press is all that bad, actually I probably just need to concentrate on the other lifts and that will come. I just hit the time when I have trouble in a shorter time because it is a difficult lift. ____________________ current: ducati monster 750
| G |
| Eddie Hitler |
| daemonoid |
| G |
 Posted: 20:57 - 10 Jan 2015 Post subject: |
The six months point was in reply to Eddie Hitler's point about not staying on the same routine for 6 months .
For me, I was surprised 'advanced' isn't THAT hard to get to - does give a nice ego boost however .
As it goes, when I was moving all the car parts, I was on pretty restricted calories and not eating enough protein - it was this that got me getting all geeky on exercise/health stuff as I realised I could probably be doing it better. |
| Eddie Hitler |
| Llama-Farmer |
| monkeybiker |
 monkeybiker World Chat Champion
| daemonoid |
| Eddie Hitler |
| daemonoid |
 Posted: 12:50 - 11 Jan 2015 Post subject: |
| Eddie Hitler wrote: | | daemonoid wrote: | I'm still looking for a more active accessory exercises that help with overhead press - anything that targets the lower back or shoulders should be good. I suppose I could start cartwheeling on the treadmills... |
I'll ask my best mate whos a personal trainer, hes also studying at uni regarding all the nutritional side of stuff. Hes actually the person who got me into fitness years ago. I should be seeing him on tuesday before I set off.
From my own opinion maybe try using single dumbells in an overpress style fashion with your wrist in a side position. Like this. I'm not at all an expert, my mate is but he has suggested this excersise to me in the past. If I was in your position I would sack off overhead pressing for a few weeks and concentrate on another excersise. I injured my rotator cuff pushing myself too far doing my push press a few months ago, not nice.
https://i.imgur.com/JupMTTQ.jpg |
Thanks.
I don't think I'm in much danger of injury though... 42.5 doesn't feel heavy, I just seem to lose all strength on some of the later sets. Friday I managed 5,5,1,5,5 nothing feels tight, I'm not pushing to what feels like the extremes of strength. I just completely lose it, which is why I feel a bit of stamina work would help, as it did with the barbell rows.
Next attempt will be Tuesday and hopefully after that I won't have to deload. It's especially odd as 40kg seems quite light and as though there's a lot left in the tank. ____________________ current: ducati monster 750
| G |
 Posted: 13:21 - 11 Jan 2015 Post subject: |
Some sauce.
Which suggests 36 hours is the figure - so 48 hours between sessions seems reasonable.
Couldn't find the actual study, I'm afraid.
| Quote: | Recently, researchers at McMaster University in Hamilton, Ontario and the Washington University School of Medicine in St. Louis made a head start on reckoning recovery times. Their subjects, six healthy young men who regularly engaged in weight training, carried out four sets each of biceps, 'concentration,' and 'preacher' curls (12 sets in all), with three to four minutes of rest between sets. Resistance (weight) was set at 80 per cent of maximum (80 per cent of the heaviest weight which could be lifted successfully one time), and each set consisted of as many reps as a subject could handle.
The unique aspect of the research was that each subject carried out the curls with only one arm; the other arm rested. The scientists could then use an isotope tracer to determine protein uptake in the exercised arm and compare it with routine protein synthesis in the arm which had not exercised.
Combining this research with a similar, past effort, the scientists determined that muscle protein synthetic rate increases by about 50 per cent four hours after a workout. This is evidence that muscles are repairing damage accrued from the workout - and also building new 'stuff' to make themselves stronger and more fatigue-resistant.
This 'repair and renew' process seems to peak about 24 hours after a workout, when muscle protein synthetic rate was up by a hefty 109 per cent in the McMaster-Washington research. However, about 36 hours after a workout, the whole process is pretty much over, and muscles are back to routine housekeeping.
It's important to point out that this study was done with experienced weight trainees; novice lifters might have required a longer recovery process. It's also important to note that the research was conducted with strength rather than endurance athletes. The recovery process might proceed with a different time frame following a more endurance-type workout. Also, there is variation between athletes. Some individuals might be all done recovering after just 30 hours or so, while others could take 40 to 48 hours. |
The last post was made 11 years, 281 days ago. Instead of replying here, would creating a new thread be more useful? |
