Total power loss at high revs
Andy9934
PostPosted: 11:15 - 11 Jan 2015    Post subject: Total power loss at high revs Reply with quote
Recently ish my YBR 125 has an issue where it completely loses power at high revs , as if the clutch had been pulled in. Upon letting the revs fall to about 4k I can open the throttle again and continue as usual.
I've only noticed it happening shortly after switching the engine (and so, only in 1st or 2nd) on but it will happen whether the engine is hot or cold.
It's not really an issue because it doesn't happen accelerating away at normal speed but I am worried it could be an early warning sign of something.
Surrey
Honda Varadero XL125
PostPosted: 11:17 - 11 Jan 2015    Post subject: Reply with quote
Does it continue to rev but the speed stays the same? Clutch slipping perhaps?
Andy9934
PostPosted: 12:10 - 11 Jan 2015    Post subject: Reply with quote
It continues to rev but the engine warning light flashes and no power is delivered to the engine so the bike slows down.
If I held the throttle on I think it would just redline.
Surrey
Dave M
What oil are you using?
PostPosted: 17:30 - 11 Jan 2015    Post subject: Reply with quote
Likely won't matter.
The warning light flashes, maybe not the clutch then. How many times does it flash.
Andy9934
PostPosted: 21:09 - 11 Jan 2015    Post subject: Reply with quote
I was using some Mobil 10W40 bike oil and changed yesterday to Halfords semisyn 10W40. Happens with both.
Uh not sure about the light, I will try and reproduce it and count.
Surrey
Dave M
PostPosted: 00:53 - 12 Jan 2015    Post subject: Reply with quote
Posted same time as each other! Didn't realise warning light was coming on!
Fidge This post is not being displayed because the poster is banned. Unhide this post / all posts.
Andy9934
PostPosted: 19:30 - 18 Jan 2015    Post subject: Reply with quote
It looks like it actually has the potential to do this in any gear above around 8k rpm. Redline is at 9k.
What happens is that it loses all drive and the revs shoot all the way up. I close the throttle and the revs drop off and it will pick back up as normal.
Surrey
PostPosted: 20:29 - 18 Jan 2015    Post subject: Reply with quote
Your clutch is slipping.
Fisty
PostPosted: 20:41 - 18 Jan 2015    Post subject: Reply with quote
This.
Fatter and faster than Fret
Ariel Badger
PostPosted: 21:55 - 18 Jan 2015    Post subject: Reply with quote
FFS your clutch is slipping.
pdg
PostPosted: 21:57 - 18 Jan 2015    Post subject: Reply with quote
Just a thought, maybe your clutch is slipping?
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Jewlio Iglesias This post is not being displayed because the poster is banned. Unhide this post / all posts.
CaNsA
PostPosted: 21:59 - 18 Jan 2015    Post subject: Reply with quote
Slippage of the clutch plates.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:00 - 18 Jan 2015    Post subject: Reply with quote
Maybe your clutch plates are slipping.
Triumph Sprint ST 1050
Skoot
Clutch slippage.
el_oso
PostPosted: 09:06 - 19 Jan 2015    Post subject: Reply with quote
If you've fitted a red powerband then this is most likely slipping.
I kid I kid, sounds like clutch slip
Duke 390
Car: Jeep Wrangler 4.0L
Scootaloo
PostPosted: 10:42 - 19 Jan 2015    Post subject: Reply with quote
You sub-frame is twisted and your chain is slack...
No. Your Clutch IS slipping.
(CBF125 - 09) (CBF125 - 11) (CB-1 - 89) (CBF500 - 06) (Push Bike) (CB-1 - 90) (XL125 - 01) (VF500 - 83) (GPZ500 - 94) (GPZ500 - 95) (GPZ500 - 87) (XV535 - 94) (XV535 - 94) (GPZ500 - 87)
Andy9934
PostPosted: 14:48 - 22 Jan 2015    Post subject: Reply with quote
I think the clutch might be slipping. Just a hunch...
So check lever free-play and if that's fine then get it to a mechanic?
Is it harmful for it to be in this state (I won't rev it above 8k now)?
Surrey
pdg
PostPosted: 17:34 - 22 Jan 2015    Post subject: Reply with quote
It'll just keep getting progressively worse until you can sit idling in gear and not going anywhere.
Or, it'll assplode into a bazillion pieces while you are riding past a church full of kitten carrying nuns, killing everything in a 2 mile radius, except you - you'll have to live with yourself.........
The last post was made 11 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 106.52 Kb
