Flasher relay location: NSR125R
scoobiemandan
PostPosted: 13:15 - 11 Jan 2015    Post subject: Flasher relay location: NSR125R Reply with quote
Okay, so I've searched high and low and can't easily spot the flasher relay which I need to swap out! I saw on another thread someone reckoned on the newer models they were located between the tool box and rear lights but that ain't the case!
Anyone able to point me to its location and what needs to come off to access it? It's a 2001 Foxeye.
Cheers Smile
IN THE GARAGE: 2001 Fox Eye Honda NSR125R, 2004 Subaru Legacy GT Spec-B, 2013 Ford S-Max 2.0 Titanium X Sport
b422063
PostPosted: 13:21 - 11 Jan 2015    Post subject: Reply with quote
According to this it's on the left side of the bike, possibly around the seat area.
scoobiemandan
PostPosted: 13:26 - 11 Jan 2015    Post subject: Reply with quote
Thanks pal. I had a look in that area and just couldn't see it? It's most likely there but needs removal of faring and fuel tank I suspect! Trouble is, it's cold and windy outside and I don't wanna go removing things wastefully Laughing
If I can establish exactly here it is and what I need to remove I'm pretty sure I can get it done as quick as possible and with as little ill health to my wimpy self Wink
b422063
PostPosted: 13:48 - 11 Jan 2015    Post subject: Reply with quote
It's a motorbike, there aren't that many place to hide things like that. Get a set of allen keys and take the rear fairings off, the seat and you're left with most of the most significantly likely places uncovered.
stirlinggaz
PostPosted: 15:16 - 12 Jan 2015    Post subject: Reply with quote
hi,
seeing as theres only 2 relays to see, it should take you 30secs. Laughing
lift the seat, & iirtc its the rear most relay. the one nearer the battery is the starter relay.
hth.
cheers,
GAZ
bradh511
PostPosted: 20:07 - 12 Jan 2015    Post subject: Reply with quote
IF it helps identifying it its a 2 prong relay with prongs positioned in a L shape..... Shouldn't be to far from the battery
Theory 11-10-12 lets hope i get mod 1 and 2 done by the 18th of jan 2013 Smile
alains
PostPosted: 19:55 - 13 Jan 2015    Post subject: Reply with quote
on the left side (facing front when sitten) of the seat lock
stirlinggaz
PostPosted: 14:51 - 14 Jan 2015    Post subject: Reply with quote
Hi,
its under pillion seat on mine. as far back as it can go.next to the alarm. 2 pin relay.
cheers,
GAZ
scoobiemandan
PostPosted: 15:07 - 25 Jan 2015    Post subject: Reply with quote
Not there! See picture below. I had the faring undone, seat off, tank off, air filter housing off and could find nothing remotely like the relay I'm looking for.
https://i1085.photobucket.com/albums/j427/scoobiemandan/Nsr125/DSC_0617_zpsky8e9gk8.jpg
stirlinggaz wrote:
Hi,
cheers,
GAZ
Well now, whilst I had everything off looking where it's supposed to be (on the left side) I looked behind the rear light cluster and I found what appears to be the flasher relay. However, looks like a botch job with a universal unit, which doesn't help me as I have an OEM relay to replace it with??
https://i1085.photobucket.com/albums/j427/scoobiemandan/Nsr125/DSC_0616_zpstyuvg5na.jpg
Reason I'm wanting to replace is because, in cold weather, the indicators take some time to start working. Fine once they've been started and after warmed up or in warmer weather. All connections are good/tight/water resistant so I'm down to the last thing being the relay on it's way out.
I really do hate it when I find that things have been replaced with cheap after market parts! I've always been of the opinion that spend the money at the start and things will work better for longer!
stirlinggaz
PostPosted: 22:40 - 25 Jan 2015    Post subject: Reply with quote
hi,
tbh a relay is a relay.
the one you pay 20 quid for from honda will be no better thanm a generic relay from a motor factors.
just remove the old unit & replace.
im not sure i see the problem.
I would be more concerned at the state of the wiring. remove all that black tape & join the wires properly ie solder & heatshrink or bullet or spade connectors crimped on.
oh & your bikes filthy lol.
cheers,
GAZ
scoobiemandan
PostPosted: 07:46 - 26 Jan 2015    Post subject: Reply with quote
The problem is that it makes no sense to butcher something like this just to save a few pennies! Also the fact I've now gotta faff around with wiring......which is not really my strong point! Give me mechanical stuff fine, electrical and I turn all girly Embarassed
b422063
PostPosted: 15:46 - 29 Jan 2015    Post subject: Reply with quote
Genuine Honda relay for my bike is £50, replacement from Motrax or the ilk is about £5. I understand why people do it, even if I don't like it.
alains
PostPosted: 16:31 - 29 Jan 2015    Post subject: Reply with quote
what about that (genuine model)
https://www.ebay.co.uk/itm/Honda-NSR-125-R1-2001-125-CC-Indicator-Relay-/400846893174?pt=UK_Motorcycle_Parts_13&hash=item5d54563076
scoobiemandan
PostPosted: 18:20 - 29 Jan 2015    Post subject: Reply with quote
Not a genuine part alains, listed as a pattern part! Nonetheless, correct fitment for it's purpose!
b422063
PostPosted: 18:33 - 30 Jan 2015    Post subject: Reply with quote
David Silvers listing for a relay for my bike. Bargain! Laughing
alains
PostPosted: 18:50 - 30 Jan 2015    Post subject: Reply with quote
Christmas Hat
Question
Thumbs Down
The last post was made 11 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 91.14 Kb
